Home » Eclipse Projects » Eclipse Platform » Modifying the Java Editor
Modifying the Java Editor [message #215204] Wed, 24 March 2004 02:11 Go to next message
Originally posted by: solo.groupstudy.com
Can you modify the built in Java editor in Eclipse (2 or 3M) via some sort
of XML file like most other IDEs have for reference to there editors. For
example, adding or changing the exact keywords in "Keywords", or possibly
creating a "Keywords2" and assigning other keywords to it?
Eclipse is a great environment to work in. The only draw back it has is
that its actual Java editor is very little light on syntax options compared
to most others. I know there is a "Slick Edit" plug-in . . . but I am not
really up to paying for $150.00 just to make my code a bit prettier.
Brad
Re: Modifying the Java Editor [message #219553 is a reply to message #215204] Wed, 31 March 2004 18:28 Go to previous message
Originally posted by: rtayek.no.spam.freightgate.com
"Brad" <solo@groupstudy.com> wrote in message
news:c3rc0u$sgp$1@eclipse.org...
> ....very little light on syntax options compared to most others. ...
there appeats to be a rudumentary vi plugin (but it is being designed to
"know" about java).. iirc, there is one for emac.
hth
Previous Topic:Path to external folder
Next Topic:Problem summary bar 3.0M8?
Current Time: Sun Jul 27 01:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.03762 seconds
