tcl debugging with dltk [message #20867] |
Tue, 04 March 2008 16:34  |
hi,
i happened across the DLTK plugins a few days ago and am thrilled at the
prospect of tcl debugging support in eclipse. i downloaded the 0.9.2
version of DLTK and am trying to configure tcl debugging. i couldnt find
any documentation on how to do this, but based on this post -
http://dev.eclipse.org/mhonarc/lists/dltk-dev/msg00035.html - gathered
that i need to install a tcl debugging engine separately from the DLTK
install in order to debug a tcl app. is that correct?
i downloaded a 21 day trial of ActiveStates Tcl Dev Kit but dont see a
file named dbgp_tcldebug.exe, which the aforementioned post identified as
the debugger to use with DLTK. selecting C:\TclDevKit\bin\tcldebugger.exe
didnt work.
which tcl debugger engines has DLTK been tested with, and what are the
associated debugging engines to use with DLTK? is there any documentation
i missed on how to set this up?
thanks.
-mike
FUDForum. Page generated in 0.09861 seconds
