Home » Newcomers » Newcomers » Problem with running eclipse 3
Problem with running eclipse 3 [message #20855] Mon, 31 January 2005 08:41 Go to next message
Originally posted by: Lukasz.Nowak.eu.org
Hello everyone,
That's my envrioment:
SuSE 9.2 on AMD 64
java-1_4_2-sun-1.4.2.06-1.1
eclipse-jdt-3.0-5.1
eclipse-platform-3.0-5.1
eclipse-source-3.0-5.1
eclipse-scripts-3.0-5.1
eclipse-pde-3.0-5.1
eclipse-gtk2-3.0-5.1
eclipse-3.0-5.1
All packages are SuSE standard. My Eclipse won't run - after splash screen
it gives my message box with log. Log is avaiable here:
http://bajtek.ankom.net/~shufla/1107178235738.log
What could be the problem? Eclipse install from Eclipse site, not SuSE
powered do not run either.
Thanks in advance,
Lukasz Nowak
Re: Problem with running eclipse 3 [message #21481 is a reply to message #20855] Mon, 31 January 2005 09:30 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Lukasz,
Are you running 64 bit linux? If so, are you using Sun's 64 bit linux
JRE? (most likely not, because I believe that they've only released a
Java 1.5 version) And finally, are you running the 64 bit version of
Eclipse?
- Jeff
Lukasz Nowak wrote:
> Hello everyone,
> SuSE 9.2 on AMD 64
> eclipse-jdt-3.0-5.1
> eclipse-pde-3.0-5.1
> eclipse-3.0-5.1
> Thanks in advance,
> Lukasz Nowak
Re: Problem with running eclipse 3 [message #21937 is a reply to message #21481] Tue, 01 February 2005 01:39 Go to previous message
> Eclipse?
You are right. Right now I'm using official Java 1.5-64 & Eclipse-GTK2-64 -
all runs fine.
I'm just shocked, that packages from SuSE do not work anymore (it has been
working few days ago on same machine! - maybe some updates damaged it).
Thank you for your help,
Lukasz
Previous Topic:How do I install plugins ?
Next Topic:Sharing a custom perspective among a group of users
Current Time: Sun Jul 27 07:13:09 EDT 2025
Powered by FUDForum. Page generated in 0.07634 seconds
