Home » Eclipse Projects » GEF » Bugs fixed
Bugs fixed [message #20835] Wed, 25 September 2002 18:37
Originally posted by: support.omondo.com
Hi all,
As you know, there are bugs observed in our EclipseUML plug-in. I'd like
give some status:
1. impossible to create a class diagram
It is a bug in cas you haven't selected a package.
2. no more image handles
This problem may occur if you create a huge diagram.
3. Errors in the doc
omondouml-2.0.1.jar no found
4. Syntax error in plugin.xml
5. disfunction of refactoring
This is a strange behavior. We observed it doesn't work in others.
We don't know why until now. What we know, is we don't receive the event
from JDT. But it works fine in my two machines with two different jdk
(1.3.1.02 and 1.4.1_01).
Tomorrow, we will publish a new version in which the 1, 2, 3 and 4 got
fixed. But the cas 5 still open.
We tested this new version works with Eclipse 2.0.0 (build 21 May 2002).
So in general, it should work with all version Eclipe build since 21 May
2002.
Julien
Previous Topic:How do you start to write a GEF application?
Next Topic:EclipseUML bugs fixed
Current Time: Sun Aug 31 23:53:10 EDT 2025
Powered by FUDForum. Page generated in 0.06472 seconds
