Home » Eclipse Projects » Eclipse Platform » Help! Spontaneous refusal of Eclipse2.1 to start up
Help! Spontaneous refusal of Eclipse2.1 to start up [message #214680] Tue, 23 March 2004 00:12 Go to next message
R2.1, WinXp
Normal shutdown; several hours later went to start up, and got this
log-file, which makes no sense to me at all ... In the interval I
changed precisely nothing.
Paul
!SESSION Mar 23, 2004 00:06:57.948
java.version=1.4.2_03
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/Ekleipsis/eclipse/
!ENTRY org.eclipse.core.runtime 2 1 Mar 23, 2004 00:06:57.948
!MESSAGE Problems encountered loading the plug-in registry.
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 23, 2004 00:06:57.948
!MESSAGE Plug-in descriptor "com.ibm.etools.java" not found for fragment
"com.ibm.etools.java.nl1". Fragment ignored.
!MESSAGE Plug-in "org.eclipse.ui" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ui.editors".
!MESSAGE Plug-in "org.eclipse.jdt.junit" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ui".
!MESSAGE Unable to satisfy prerequisite constraint from
"org.eclipse.update.ui" to "org.eclipse.ui".
"org.eclipse.search" to "org.eclipse.ui".
!MESSAGE Plug-in "org.eclipse.help.ui" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.search".
"org.eclipse.ui.externaltools" to "org.eclipse.ui".
"org.eclipse.pde.runtime" to "org.eclipse.ui".
"com.opnworks.tableviewer.example" to "org.eclipse.ui".
"com.ibm.etools.xml.encoding" to "org.eclipse.ui".
!MESSAGE Plug-in "com.ibm.sed.preferences" was disabled due to missing
or disabled prerequisite plug-in "com.ibm.etools.xml.encoding".
!MESSAGE Plug-in "com.ibm.sed.model" was disabled due to missing or
disabled prerequisite plug-in "com.ibm.sed.preferences".
!MESSAGE Plug-in "com.ibm.sed.editor" was disabled due to missing or
disabled prerequisite plug-in "com.ibm.sed.model".
!MESSAGE Plug-in "com.ibm.etools.xsdeditor" was disabled due to missing
or disabled prerequisite plug-in "com.ibm.sed.editor".
"org.eclipse.team.cvs.ui" to "org.eclipse.ui".
"com.ibm.watson.toyJavaEditor" to "org.eclipse.ui".
"org.eclipse.pde.ui" to "org.eclipse.ui".
"org.eclipse.platform.doc.isv" to "org.eclipse.ui".
"org.eclipse.contribution.spider" to "org.eclipse.ui".
"org.eclipse.core.tools" to "org.eclipse.ui".
"com.ibm.etools.b2butil" to "org.eclipse.ui".
!MESSAGE Plug-in "com.ibm.etools.validate.xml" was disabled due to
missing or disabled prerequisite plug-in "com.ibm.etools.b2butil".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 23, 2004 00:06:57.958
!MESSAGE Plug-in "com.ibm.etools.sed.tabletree" was disabled due to
missing or disabled prerequisite plug-in "com.ibm.etools.validate.xml".
"org.eclipse.swt.sleak" to "org.eclipse.ui".
"com.ibm.etools.b2bgui" to "com.ibm.etools.b2butil".
!MESSAGE Plug-in "com.ibm.etools.xmlbuilder" was disabled due to missing
or disabled prerequisite plug-in "com.ibm.etools.b2bgui".
"com.ibm.debug.javascript" to "org.eclipse.ui".
"org.eclipse.update.ui.forms" to "org.eclipse.ui".
"org.eclipse.jdt.ui" to "org.eclipse.ui".
"com.ibm.etools.deviceprofile" to "org.eclipse.ui".
"org.eclipse.team.ui" to "org.eclipse.ui".
"org.eclipse.jdt.debug.ui" to "org.eclipse.ui".
"com.ibm.sed.editor.extensions" to "org.eclipse.ui".
"com.ibm.etools.xsd.utility" to "com.ibm.etools.b2butil".
"com.ibm.etools.xml.common.ui" to "com.ibm.etools.b2bgui".
"org.eclipse.compare" to "org.eclipse.ui".
"com.ibm.etools.xsdmodel" to "org.eclipse.ui".
"org.eclipse.gef" to "org.eclipse.ui".
"com.ibm.etools.actionhandler" to "org.eclipse.ui".
"com.ibm.etools.xml.gef.util" to "org.eclipse.gef".
"org.eclipse.debug.ui" to "org.eclipse.ui".
"com.ibm.etools.dtdmodel" to "com.ibm.etools.b2butil".
"com.ibm.debug.common" to "org.eclipse.debug.ui".
"com.ibm.etools.dtdparser" to "com.ibm.etools.b2butil".
!MESSAGE Unknown extension point "org.eclipse.ui.commands" specified in
plug-in "org.eclipse.ui.workbench.texteditor".
!MESSAGE Unknown extension point "org.eclipse.ui.actionSets" specified
in plug-in "org.eclipse.ui.workbench.texteditor".
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 23, 2004 24:06:58.108
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.IllegalArgumentException: Application not found:
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:843)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
... 7 more
!SESSION Mar 23, 2004 00:09:23.867
!ENTRY org.eclipse.core.runtime 2 1 Mar 23, 2004 00:09:23.867
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 23, 2004 00:09:23.867
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 23, 2004 00:09:23.877
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 23, 2004 00:09:23.887
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 23, 2004 24:09:23.968
!STACK
... 7 more
Re: Help! Spontaneous refusal of Eclipse2.1 to start up: solved: .lock file [message #214691 is a reply to message #214680] Tue, 23 March 2004 00:37 Go to previous message
There was a ".lock" file in the .metadata directory whose date-stamp closely matched
the .log file, so I deleted it, and viola! all is well. STill no clue what happened
Paul
"Paul T. Keyser" wrote:
> R2.1, WinXp
> Paul
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !SESSION
> !STACK
> at
> ... 7 more
> !SESSION
> !STACK
> at
> ... 7 more
Previous Topic:[ANN] Multi Project Import/Export plugin
Next Topic:Console: how to print to console view
Current Time: Sat Jul 26 16:01:50 EDT 2025
Powered by FUDForum. Page generated in 0.07249 seconds
