Home » Archived » OHF » Error in org.eclipse.ohf.ihe.common.ebxml._2._1.query
Error in org.eclipse.ohf.ihe.common.ebxml._2._1.query [message #20822] Wed, 18 October 2006 09:18
When attempting to run the XDS Document Consumer Query method using this
line of code:
docList = c.query(query, false, "BlueWare");
I am getting an error in org.eclipse.ohf.ihe.common.ebxml._2._1.query.
1)Does anyone have any idea what is causing this error? Am I possibly
missing a required JAR file? I am currently referencing
org.eclipse.emf.common_2.2.1 and org.eclipse.emf_2.2.0.
2) Are there bundled XDS Consumer JAR files that are precompiled so I
don't need to grab from the CVS source?
Exception in thread "main" java.lang.NoSuchMethodError:
org.eclipse.emf.common.util.AbstractEnumerator: method
<init>(ILjava/lang/String;Ljava/lang/String;)V not found
org.eclipse.ohf.ihe.common.ebxml._2._1.query.ReturnTypeType. <init>(ReturnTypeType.java:240)
org.eclipse.ohf.ihe.common.ebxml._2._1.query.ReturnTypeType. <clinit>(ReturnTypeType.java:119)
at org.eclipse.ohf.ihe.xds.consumer.Consumer.query(Consumer.jav a:221)
com.blueware.interoperability.queryXDSRegistry.queryMetadata (queryXDSRegistry.java:113)
com.blueware.interoperability.queryXDSRegistry.main(queryXDS Registry.java:84)
Previous Topic:Error in org.eclipse.ohf.ihe.common.ebxml._2._1.query
Next Topic:Use of OHF plugins only from RCP environment or using SOAP through the bridg
Current Time: Thu Jul 17 21:48:04 EDT 2025
Powered by FUDForum. Page generated in 0.07389 seconds
