Home » Archived » BIRT » Report item in library ignores theme changes
Report item in library ignores theme changes [message #214604] Sat, 27 January 2007 07:57 Go to next message
Originally posted by: carlos.sinixtek.com
Here is what I do:
- I create a report item in library A, and set its style to 'Style1'.
- I create a theme in library B, and define the style 'Style1'.
- I create a report design. I import both libraries. I import the report
item from library A. I set the report theme to the theme defined in
library B.
The result is that the report item has the style defined in library A,
i.e., the style belonging to the theme with which it was defined.
Is this a bug or the expected behaviour?
The reason why I do things that way is because I want to create a shared
library of report items, and combine it with different layouts and
themes to create different reports.
Thanks for your help!
Re: Report item in library ignores theme changes [message #214612 is a reply to message #214604] Sat, 27 January 2007 08:00 Go to previous message
I forgot to say I'm using the RCP designer of birt 2.1.2RC. The same
results are observed when using 2.2M4.
Carlos Gómez escribió:
> Here is what I do:
> library B.
Previous Topic:select image based on report parameter
Next Topic:Best-fit algorithm for column sizing for Design Engine
Current Time: Sat Jul 26 19:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.03412 seconds
