Home » Eclipse Projects » Technology Project and PMC » Problem attaching source to jar
Problem attaching source to jar [message #20799] Wed, 04 September 2002 06:44
I am having a problem getting Eclipse to recognise that a jar file has
attached source.
I am using build id: 200206271827.
I have a jar file containing com.db.Test.class
Using the Properties -> Java Source Attachment section I specify
C:/temp/source.zip in the Archive field, and leave the Root Path blank.
source.zip contains the file Test.java with the path com/db
But when I look at the Test class in a type hierarchy, I get the Class
File Editor saying "Source not found"
Am I trying to use this incorrectly?
Thanks in advance,
Dom
Previous Topic:[PDE]extend the plugin.xml dtd
Next Topic:Problem attaching source to jar
Current Time: Sat Jul 26 10:07:16 EDT 2025
Powered by FUDForum. Page generated in 0.25281 seconds
