Home » Language IDEs » C / C++ IDE (CDT) » hyperlinking question
hyperlinking question [message #214360] Fri, 18 April 2008 11:18 Go to next message
The hyperlinking lets you jump to the function declaration, is there a way
to link to the actual function instead of the declaration?
jason
Re: hyperlinking question [message #214424 is a reply to message #214360] Fri, 18 April 2008 17:06 Go to previous messageGo to next message
What do you mean with hyperlink?
In my Eclipse-Europa, version 3.3.2, Suse Linux10.1, the cursor jumps to
the function when I am clicking on the function name in the Outline view
or when I click with RMB on the name in the editor window and then select
Open Declaration from the pop up menue.
In an older version of Eclipse there were two choices in the pop up menue,
either Open Declaration or Open Definition.
Maybe the behaviour depends on the Eclipse version you have.
Nikosch
Re: hyperlinking question [message #214430 is a reply to message #214424] Fri, 18 April 2008 17:42 Go to previous messageGo to next message
Guess I didn't explain that real well. Let me try again.
Preferences->General->Editors->Text Editors->Hyperlinking
When I'm working in function ComsubMenu(), located in comsub.c, and it
calls GetNumEntry(), located in entry.c, you can hold Ctrl and click the
function and it will hyperlink you to the function declaration. I would
prefer if it linked me to the actual function, not the declaration.
I'm use to CodeWright and in that IDE when you hovered over a function a
popup box allowed you to jump directly to either the declaration or the
function, which was really handy. I'm trying to find out if I can
configure Eclipse to do the same.
Re: hyperlinking question [message #214578 is a reply to message #214430] Mon, 21 April 2008 06:00 Go to previous message
(Assuming CDT >= 4.0)
The hyperlink navigates to the same location as Open Declaration (F3).
Note that Open Declaration does navigate to the function definition and
only if it can't find it, it navigates to the declaration.
See also https://bugs.eclipse.org/bugs/show_bug.cgi?id=167162
Anton Leherbauer
Wind River CDT Team, Austria
Previous Topic:Deploy a C application on embedded system
Next Topic:No symbol "XXX" in current context
Current Time: Wed Jul 30 19:11:05 EDT 2025
Powered by FUDForum. Page generated in 0.03186 seconds
