Home » Eclipse Projects » Eclipse Platform » Path to external folder
Path to external folder [message #214305] Mon, 22 March 2004 03:05 Go to next message
Originally posted by: borov333.netscape.net
I am trying to setup my java project point to external folder where I
store configuration files, but no matter what I tried I always get
exception: "(The system cannot find the file specified)". It can only
find file if I put it right in the project directory.
Does anyone knows how to set up eclipse to find files located in
external folders? I tried to setup path for my computer and created
variables pointing to a folder, but it didn't work.
Please help.
Thanks.
Re: Path to external folder [message #214658 is a reply to message #214305] Mon, 22 March 2004 22:51 Go to previous messageGo to next message
Can anyone please help me to find out how to reference configuration
files that are outside of project directory. I have external folder
named "config" where I place all my configuration files and would like
to set a reference from eclipse V3.0, but instead always get an error
(check original message for details)
Igor wrote:
> Hello,
> Please help.
> Thanks.
Re: Path to external folder [message #219547 is a reply to message #214305] Wed, 31 March 2004 18:23 Go to previous message
Originally posted by: rtayek.no.spam.freightgate.com
"Igor" <borov333@netscape.net> wrote in message
news:c3m6ga$psk$1@eclipse.org...
> Hello,
> find file if I put it right in the project directory. ...
i have the same problem with ant. how do you know where here or there. here
is easy, use get recouse. there is harder and i ended up looiking in user
dir or pass into ant as a property from however. so if eclipse can taka a
property or an environmet ariable. there is that stuff for ant somewhere
like iscelipserunning.
thanks
Previous Topic:3.0 M8: Problems view doesn't pop up
Next Topic:Modifying the Java Editor
Current Time: Sat Jul 19 04:26:38 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
