Unable to View Report in Viewer [message #214180] |
Thu, 25 January 2007 15:43 |
Originally posted by: lmundt.rogers.com
When I try to view my report as a PDF from the RCP Designer I get a
"File is damaged and could not be repaired" error dialogue from Adobe
acrobat reader. I can view the report as HTML. I can also view the
report in the report viewer, but if I try to render to PDF I get the
same message.
This is after I unembedded the two images my report contains. While
they were imbedded the report viewer would give out of memory errors.
If I remove my Master Page which contains an image in the header and a
grid contain page numbers and date in the footer I can render to PDF
once. On subsequent renders the same error message appears. I have to
restart BIRT Designer before it will render again.
I have 2 images. I have added no scripts. I have 17 charts in my
report that draw from 26 datasets. Most datasets produce less than 10
result a couple produce 500 entries or so.
I only noticed this problem after a while developing my chart as it did
render to PDF originally.
There are no errors in the log file for the report viewer either.
I don't know how my report could be blowing the memory of the virtual
machine if that is the problem. Please advise.
Lester
FUDForum. Page generated in 0.05651 seconds
