Home » Eclipse Projects » Subversive » NOOB problem
NOOB problem [message #20773] Wed, 11 June 2008 21:25 Go to next message
I have not had any prior experience with Subversion, and the Eclipse
project in which I participate has switched its repository from CVS to
SVN. So, I am using the Subversive plug-in to access the repository.
So far, it has worked out pretty well, I can browse the repository,
check out projects, do comparisons, etc. However, when it came time to
perform my first commit back into the SVN repository, I received the
following error message:
Some of selected resources were not committed.
svn: Commit failed (details follow):
svn: MKACTIVITY of
'/svnroot/technology/!svn/act/a485986c-1a01-0010-bab6-6d7bc9 66c039':
403 Forbidden (http://dev.eclipse.org)
I cannot see any information in the message that helps me understand
what to do differently. Every time I try, I get the same result. I
selected a single source file in a project, and then Team > Commit...
If anyone can shed any light on what I might have done wrong, I would
appreciate it. Is there some configuration issue that I missed?
Other committers in the project are successfully committing, so the
repository cannot be completely out of whack.
-- Mike
Re: NOOB problem [message #20815 is a reply to message #20773] Thu, 12 June 2008 09:04 Go to previous messageGo to next message
> svn: MKACTIVITY of
I'm not an expert, but 403 sounds like a "permission denied" error at
the http-request. Somewhere in the svn repository the permissions of all
users must be configured and I would assume you are not enabled writing
to the repository, only reading. You should ask the repository admin to
check this for you.
Hauke
Re: NOOB problem [message #20828 is a reply to message #20773] Thu, 12 June 2008 09:08 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Hello Mike,
It looks like you have no permissions to perform a commits.
So, please ensure that you specified secure URL in order to access
repository (https or svn+ssh), because access to repository using http
protocol is not configured for write access. Then please check if you
entered your username and password correctly. If so, I think it will be
good to ask Web-masters.
Previous Topic:UI Problems
Next Topic:Integration for the Mylyn Project not compatable with Mylyn 2.3.2
Current Time: Tue Jul 22 12:04:32 EDT 2025
Powered by FUDForum. Page generated in 0.03592 seconds
