Home » Language IDEs » C / C++ IDE (CDT) » Eclipse+Qt+GDB
Eclipse+Qt+GDB [message #214010] Tue, 15 April 2008 19:41 Go to next message
Originally posted by: eric.fowler.gmail.com
I am unable to get the Eclipse+Qt plugin to build a debug application.
Here is the procedure:
-New Project --> Qt Console Project. Make bare minimum "Hello World!" app in
project.
-Choose Build All. Get release version of project built. Release branch of
project tree populates with object code and other created files. Debug
branch does not.
- Choose Debug (F11). Debug build appears to run. Program executes but I get
warning 'no source available for main()'. Program breaks and I get
disassembly but no variables, symbols, etc.
I have been looking for the magic button to push to get a real debug build
but can't find it.
Anyone know how to do this?
Eric
Re: Eclipse+Qt+GDB [message #214018 is a reply to message #214010] Tue, 15 April 2008 21:01 Go to previous messageGo to next message
Gonna add to this: the menu item under Project Explorer --> right click
project --> Build Configurations ---> Set Active is gray.
It's active for non-Qt projects, and has always worked fine.
Eric
Re: Eclipse+Qt+GDB [message #214026 is a reply to message #214010] Wed, 16 April 2008 02:46 Go to previous messageGo to next message
> project.
> branch does not.
> but can't find it.
> Thanks
> Eric
All versions of Qt before 4.4.x don't have debugging mode on Windows, so
I think you're using Qt's version before 4.4.x.
Any way, this issue related to Qt, so I suggest to add your question to
Qt' maillist.
Best Regards تحياتي
Muhammad Bashir Al-Noimi محمد بشير النعيمي
My Blog مدونتي
http://mbnoimi.net/
Re: Eclipse+Qt+GDB [message #214143 is a reply to message #214026] Wed, 16 April 2008 18:31 Go to previous messageGo to next message
>> in project.
>> of project tree populates with object code and other created files. Debug
>> branch does not.
>> get warning 'no source available for main()'. Program breaks and I get
>> build but can't find it.
>> Thanks
>> Eric
> Qt' maillist.
Hm, I am using 4.3.4 but I am on Linux (Fedora).
But I will try the Qt mailing list, thanks.
Eric
Re: Eclipse+Qt+GDB [message #214268 is a reply to message #214143] Thu, 17 April 2008 16:41 Go to previous messageGo to next message
>>> in project.
>>> branch does not.
>>> Thanks
>>> Eric
>> Qt' maillist.
> Eric
sorry, I meant 4.3.x version don't work on debugging mode, but 4.4.x
work on debug mode.
Best Regards تحياتي
My Blog مدونتي
http://mbnoimi.net/
Re: Eclipse+Qt+GDB [message #214276 is a reply to message #214268] Thu, 17 April 2008 17:00 Go to previous messageGo to next message
> work on debug mode.
For Windows only, or also Linux?
Eric
Re: Eclipse+Qt+GDB [message #214352 is a reply to message #214276] Fri, 18 April 2008 09:56 Go to previous message
>> work on debug mode.
> Eric
I'm not sure exactly, but I think for Windows only.
Any way, it better to ask your questions at Qt mail-list
Best Regards تحياتي
My Blog مدونتي
http://mbnoimi.net/
Previous Topic:C Code Folding
Next Topic:extend line to mouse click
Current Time: Thu Jul 17 19:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.22999 seconds
