Home » Eclipse Projects » Subversive » "Share project" not available
"Share project" not available [message #20747] Wed, 11 June 2008 08:32 Go to next message
Hi there,
I have several Projects in my workspace, all already under version
control with command line svn or subclipse.
Now I deleted subclipse and installed subversive. For most projects it
was perfectly possible to get them run with subversive by clicking
"Team->Share Project->SVN->use project settings"
.... and everything is fine out of the box.
Nevertheless for three of the projects selecting the context menu "Team"
only reveals "Apply patch..." but no "share project" at all. What can be
wrong with those projects? The folders already contain the .svn dirs and
running command line svn is no problem.
Hauke
Re: "Share project" not available [message #20841 is a reply to message #20747] Thu, 12 June 2008 09:26 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Hauke,
It is well-known problem. Really you have not disconnected your projects
before uninstalling previous SVN Team Provider. So all projects are still
connected to the removed plug-in. In that case Team Services does not show
"Share Project" menu item.
So, now the only way to reconnect these projects is to remove them from
workspace (without content deletion) then reimport these projects into
workspace.
Re: "Share project" not available [message #21408 is a reply to message #20841] Mon, 16 June 2008 16:43 Go to previous messageGo to next message
What about he situation where you pull the project with the svn command
line. You can import the project into the workspace.
How do I get subversive to recognize it as an svn project?
Ray
Alexander Gurov wrote:
> Hello Hauke,
> still connected to the removed plug-in. In that case Team Services does
> not show "Share Project" menu item. So, now the only way to reconnect
> these projects is to remove them from workspace (without content
> deletion) then reimport these projects into workspace.
Re: "Share project" not available [message #21416 is a reply to message #21408] Tue, 17 June 2008 02:25 Go to previous message
Yes, see thread "Re: How to attach Subversive to an externally checked out working copy?"
> In my experience, it is sufficient to open the view "SVN Repository Exploring" and add your SVN
> repository. Then, File/Import/Existing Projects into Workspace should do the job.
Cheers, Jörg
>> Hello Hauke,
>> projects before uninstalling previous SVN Team Provider. So all
>> projects are still connected to the removed plug-in. In that case Team
>> Services does not show "Share Project" menu item. So, now the only way
>> to reconnect these projects is to remove them from workspace (without
>> content deletion) then reimport these projects into workspace.
Previous Topic:subversive asks 100 times a day for password
Next Topic:Can't download Subversive
Current Time: Tue Aug 05 02:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.03500 seconds
