JUnit 4 Tests With Compile Errors Do Not Run [message #213908] |
Tue, 05 June 2007 17:22 |
Originally posted by: joeboccanfuso.gmail.com
I have noticed that JUnit 4 tests (i.e. test methods annotated with
@Test) that contain compile errors are not executed when the test suite
is launched in Eclipse (i.e those that compile fine execute and ones
with compile errors are skipped). However, if the tests were written
with JUnit 3, then those methods with compile errors are executed when
the test suite is launched in Eclipse. They result in error and throw
java.lang.Error with "Unresolved compilation problems:...". I have
included examples of each below.
The behaviour in JUnit 3 is what I am after, but I am not sure if that
is possible with JUnit 4. I suspect that Eclipse is doing a partial
compile of the the .java file containing the tests, stubbing those
methods with compile errors with a throw new(java.lang.Error(...));, and
removing the @Test annotation. I was able to use a decompiler to verify
the stubbing being done, however I was not able to find a decompiler
that supported annotations.
Here are the test cases. Running MyJUnit3Test in the Eclipse IDE
produces a red bar with 2 tests run and 1 error. Running MyJUnit4Test
in the Eclipse IDE produces a green bar with 1 test run and zero errors
or failures.
Is there a way to get the JUnit 3 result with JUnit 4?
import junit.framework.TestCase;
public class MyJUnit3Test extends TestCase
public void test1()
syntax error
public void test2()
import org.junit.Test;
public class MyJUnit4Test
@Test
public void test1()
syntax error
@Test
public void test2()
Thanks in advanced,
Ciao,
Joe
Re: JUnit 4 Tests With Compile Errors Do Not Run [message #213932 is a reply to message #213908] |
Tue, 05 June 2007 18:32 |
Olivier Thomann Messages: 518 Registered: July 2009 |
You should use the Eclipse disassembler :-).
Here is what I get:
// Compiled from X.java (version 1.5 : 49.0, super bit)
public class X {
Constant pool:
constant #1 class: #2 X
constant #2 utf8: "X"
constant #3 class: #4 java/lang/Object
constant #4 utf8: "java/lang/Object"
constant #5 utf8: "<init>"
constant #6 utf8: "()V"
constant #7 utf8: "Code"
constant #8 method_ref: #3.#9 java/lang/Object.<init> ()V
constant #9 name_and_type: #5.#6 <init> ()V
constant #10 utf8: "LineNumberTable"
constant #11 utf8: "LocalVariableTable"
constant #12 utf8: "this"
constant #13 utf8: "LX;"
constant #14 utf8: "test1"
constant #15 class: #16 java/lang/Error
constant #16 utf8: "java/lang/Error"
constant #17 string: #18 "Unresolved compilation problem:
\n\tSyntax error, insert ";" to complete BlockStatements\n"
constant #18 utf8: "Unresolved compilation problem: \n\tSyntax
constant #19 method_ref: #15.#20 java/lang/Error.<init>
(Ljava/lang/String;)V
constant #20 name_and_type: #5.#21 <init> (Ljava/lang/String;)V
constant #21 utf8: "(Ljava/lang/String;)V"
constant #22 utf8: "test2"
constant #23 utf8: "RuntimeInvisibleAnnotations"
constant #24 utf8: "LTest;"
constant #25 utf8: "SourceFile"
constant #26 utf8: "X.java"
// Method descriptor #6 ()V
// Stack: 1, Locals: 1
public X();
0 aload_0 [this]
1 invokespecial java.lang.Object() [8]
4 return
Line numbers:
[pc: 0, line: 3]
Local variable table:
[pc: 0, pc: 5] local: this index: 0 type: X
// Stack: 3, Locals: 1
public void test1();
0 new java.lang.Error [15]
3 dup
4 ldc <String "Unresolved compilation problem: \n\tSyntax error,
insert ";" to complete BlockStatements\n"> [17]
6 invokespecial java.lang.Error(java.lang.String) [19]
9 athrow
Line numbers:
[pc: 0, line: 6]
[pc: 0, pc: 10] local: this index: 0 type: X
// Stack: 0, Locals: 1
public void test2();
0 return
Line numbers:
[pc: 0, line: 12]
[pc: 0, pc: 1] local: this index: 0 type: X
RuntimeInvisibleAnnotations:
#24 @Test(
As you can see there is no annotation for the test1 method. This is the
problem. We don't preserve annotations for problem methods.
I opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=191090. Please
add yourself to the CC list.
Olivier
FUDForum. Page generated in 0.11020 seconds
