Using environment variables in launcher ini [message #213884] |
Tue, 05 June 2007 07:52 |
Originally posted by: t.t.t.com
I'm not sure if this is the right place to ask...
I'm developing a RCP application and I would like to define the workspace
data location in the application launcher ini file. Is it possible to use
environment variables in this file? If it is possible, what is the right
format?
I have tried following formats but none of those seem to work..
-data %MY_ENV_VAR%/workspace
-data $MY_ENV_VAR$/workspace
-data $MY_ENV_VAR/workspace
-data ${env_var:MY_ENV_VAR}/workspace
Thanks in advance,
-TT
Re: Using environment variables in launcher ini [message #213897 is a reply to message #213890] |
Tue, 05 June 2007 11:59 |
> Dear TT,
> The launcher for Eclipse 3.2.x takes the lines without further
> interpretation. In case you really need the functionality feel free to get
> the C source code of the launcher add what you need.
> Bye,
> Günther
Thanks for your reply. I think I'm going to solve this problem in some other
way.
-TT
FUDForum. Page generated in 0.08038 seconds
