Home » Archived » BIRT » BIRT report does not display charts
BIRT report does not display charts [message #213842] Wed, 24 January 2007 18:20 Go to next message
Hi all,
I am using BIRT 2.2M4 build. I created a birt report with bar chart and
report details connecting to a DB2 database. The chart and data is displayed
and works perfectly within the Eclipse environment. I export the
project(EAR file) and deployed in a WebSphere 6.0 environment. When I run
the application in IE browser using the URL
http://localhost:9080/birt/frameset?__report=salesReport.rpt design
the data is displayed without any problem, but the chart is missing. The
format of the chart is JPG. I also tried with other formats PNG, SVG and
BMP but in vain.
Under the WebSphere 6.0 directory where the application is installed i see
all the necessary charting jar files like
org.eclipse.birt.chart.device.extension_2.2.0.v20061130.jar etc.
Also I don't see any error messages in the log file.
Is there any setting which I am missing ?
Any help is appretiated.
Thnx.
Z
Re: BIRT report does not display charts [message #214149 is a reply to message #213842] Thu, 25 January 2007 14:57 Go to previous messageGo to next message
Originally posted by: home4slc.pacbell.net
There are several wiki entries about how to successful deploy the web
viewer application to WebSphere application servers (various versions)
on the wiki. Have you looked at them?
http://wiki.eclipse.org/index.php/BIRT/FAQ/Deployment#Q:_How _do_I_install_BIRT_in_WebSphere.3F
I've gotten charts to appear in WAS 5.1 and 6.0 with 2.2M2 (on Windows),
but have not tried with 2.2M4.
Susan
zorro wrote:
> Hi all,
> BMP but in vain.
> Thnx.
> Z
Re: BIRT report does not display charts [message #214198 is a reply to message #214149] Thu, 25 January 2007 16:13 Go to previous messageGo to next message
I think I have installed BIRT properly on Websphere otherwise I will not
be able to see the data from DB2. The problem is have is only the charts
are missing. The remaining data is displayed properly and when I update
db2 tables and do a refresh...immediately i see the new data.
Only the graphs and charts are missing and there is a blank space in that
spot.
I will try 2.2M2 build and see what happens.
-zorro
Re: BIRT report does not display charts [message #214370 is a reply to message #214198] Fri, 26 January 2007 11:22 Go to previous messageGo to next message
Hi susan,
Thnx. I installed BIRT 2.2M2 build on XP box and it works fine with WAS
6.0 on XP.
I am able to see the charts in the WAS application. So it is a bug that
birt 2.2M4 does not work well with WAS 6.0 with regards to charts. Have
you created a bugzilla for WAS 6.0 and birt 2.2M4 already ?
-zorro
Re: BIRT report does not display charts [message #214395 is a reply to message #214370] Fri, 26 January 2007 12:05 Go to previous message
Hi Zorro,
No, I have not logged a bug for 2.2M4.
Susan
zorro wrote:
> Hi susan,
> 6.0 on XP.
> -zorro
Previous Topic:Cannot generate Open Reports using BIRT 2.1.2+
Next Topic:Extend BIRT using XML Data Source
Current Time: Thu Jul 17 11:39:51 EDT 2025
Powered by FUDForum. Page generated in 0.08429 seconds
