Home » Eclipse Projects » GEF » How to add edit part to a PolyLineConnection
How to add edit part to a PolyLineConnection [message #20712] Wed, 25 September 2002 12:06 Go to next message
In the Draw2D help, it has an example of adding a Label (IFigure) to a
PolyLineConnection.
<From the help >
PolylineConnection conn = new PolylineConnection();
Label label = new Label ("Midpoint");
label.setOpaque(true);
label.setBackgroundColor(ColorConstants.buttonLightest);
label.setBorder(new LineBorder());
conn.add(label, new MidpointLocator (conn, 0));
I would like to know how to add an edit Part (e.g. LogicLabelEditPart) to a
PolyLineConnection?
LogicLabelEditPart is NOTan implementation of IFigure, but its
createFigure() cretains a Label.
I appreciate if someone can tell me how to add the logicLabelEditPart to the
connection.
Thanks.
Sam
Re: How to add edit part to a PolyLineConnection [message #20724 is a reply to message #20712] Wed, 25 September 2002 12:12 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Treat the ConnectionEditPart as a container. Containers return
getModelChildren(), which would then be used to create an EditPart for each
label on the connection. If you want to interact with the labels, you
should represent them with EditParts.
If you just want to see a label on the connection, do what the draw2d
example does. The ConnectionEdtiPart would place the label.
"Sam Cheung" <scheung@novarra.com> wrote in message
news:amslr5$jb9$1@rogue.oti.com...
> PolyLineConnection.
> <From the help >
a
> PolyLineConnection?
the
> connection.
> Thanks.
> Sam
Re: How to add edit part to a PolyLineConnection [message #20737 is a reply to message #20724] Wed, 25 September 2002 12:51 Go to previous messageGo to next message
Thanks for your help. I want an editable label on the connection.
How can I get the ConnectionEditPart from a polyline connection. I can't
find such a method on the javadoc of polylineConnection.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:amsm5t$jie$1@rogue.oti.com...
each
> > Hi,
> > PolyLineConnection.
> > <From the help >
to
> a
> > PolyLineConnection?
> the
> > connection.
> > Thanks.
> > Sam
Re: How to add edit part to a PolyLineConnection [message #21031 is a reply to message #20737] Wed, 25 September 2002 21:59 Go to previous messageGo to next message
I don't understand the question. The ConnectionEditPart creates the
PolylineConnection. Not vice versa. You "node" EditPart should create
ConnectionEditParts. Put a breakpoint in the constructor for
ConnectionEditPart.
news:amsoeu$l63$1@rogue.oti.com...
> each
> > > Hi,
> > > PolyLineConnection.
> > > <From the help >
> to
> > a
> > > PolyLineConnection?
to
> > the
> > > connection.
> > > Thanks.
> > > Sam
Re: How to add edit part to a PolyLineConnection [message #21153 is a reply to message #21031] Thu, 26 September 2002 10:45 Go to previous messageGo to next message
Actually, I want to add a LogicalLabelEdit in the middle of the
WireEditPart.
You are correct that WireEditPart creates the Bendable wire
(PolylineConnection) in method createFigure().
But when I call getModelChildren(), it returns an empty list. How can I add
an LogicalLabelEdit in the middle of the WireEditPart? and when users move
the Wire, the logical label move along with it?
Thank you.
news:amtoh3$6qj$1@rogue.oti.com...
> ConnectionEditPart.
> > each
> > > > Hi,
a
> > > > PolyLineConnection.
> > > > <From the help >
LogicLabelEditPart)
> > to
> > > a
> > > > PolyLineConnection?
logicLabelEditPart
> to
> > > the
> > > > connection.
> > > > Thanks.
> > > > Sam
Re: How to add edit part to a PolyLineConnection [message #21169 is a reply to message #21153] Thu, 26 September 2002 10:52 Go to previous messageGo to next message
news:amv5da$umc$1@rogue.oti.com...
> WireEditPart.
add
You'd have to change the Wire model and WireEditPart for that. It sounds
like a simple change. You might want to add a label to Wires in the
constructor, since support label creation will take some extra effort.
Use a new ConnectionLocator(conn). Set that as the constraint for the
*LAYOUT*, not the Connection Router. A connection has two objects that do
two separate things. Routing comes first, then laying out of children.
conn.getLayout().setConstraint(label, new ConnectionLocator(conn));
> Thank you.
> > ConnectionEditPart.
can't
for
> > > each
you
draw2d
> > > > > Hi,
to
> a
> > > > > PolyLineConnection.
> > > > > <From the help >
> LogicLabelEditPart)
> > > to
> > > > a
> > > > > PolyLineConnection?
> logicLabelEditPart
> > to
> > > > the
> > > > > connection.
> > > > > Thanks.
> > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #21291 is a reply to message #21169] Thu, 26 September 2002 20:15 Go to previous messageGo to next message
Sorry for keeping bothering you with this.
But if I want my label to be editable, I can't just add an label in teh
WireEditPart, I need to add a LogicLabelEditPart().
I can create the LogicLabelEditPart in the constructor of WireEditPart, but
the setConstraint() of the layout manager of the connection only take an
IFigure, and LogicLabelEditPart() is not an IFigure.
So how can I add a LogicLabelEditPart (the editable label) to the middle of
the wire?
Thank you.
news:amv5q7$uvc$1@rogue.oti.com...
> > WireEditPart.
> add
move
> > Thank you.
create
> > > ConnectionEditPart.
> can't
> for
> > > > each
> you
> draw2d
> > > > > > Hi,
(IFigure)
> to
> > a
> > > > > > PolyLineConnection.
> > > > > > <From the help >
> > LogicLabelEditPart)
> > > > to
> > > > > a
> > > > > > PolyLineConnection?
> > logicLabelEditPart
> > > to
> > > > > the
> > > > > > connection.
> > > > > > Thanks.
> > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #21515 is a reply to message #21291] Thu, 26 September 2002 21:43 Go to previous messageGo to next message
Actually, you should never "add" an EditPart. It gets added automatically
by refreshChildren() in AbstractEditPart. EditParts are kept in sync with
the corresponding model object that is returned in getModelChildren(). What
you need to do is make sure WireEditPart returns model children with a
LogicLabel.
but
Look at how the Logic example sets constraints for "normal" children. It is
in refreshVisuals(). Do the same thing, except the constraint is a locator,
not a Rectangle.
of
> the wire?
> Thank you.
> > > WireEditPart.
I
> > add
sounds
> move
do
> > > Thank you.
> create
> > > > ConnectionEditPart.
> > can't
EditPart
> > for
> > > > > each
labels,
> > you
> > draw2d
> > > > > > > Hi,
> (IFigure)
> > to
> > > a
> > > > > > > PolyLineConnection.
> > > > > > > <From the help >
> > > LogicLabelEditPart)
> > > > > to
> > > > > > a
> > > > > > > PolyLineConnection?
> > > logicLabelEditPart
> > > > to
> > > > > > the
> > > > > > > connection.
> > > > > > > Thanks.
> > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22370 is a reply to message #21515] Fri, 27 September 2002 23:24 Go to previous messageGo to next message
Thanks again.
In WireEditPart, I add a list which will be returned by getModelChildren().
And in the contructor of WireEditPart, I add a LogicLabel.
When I try this, I got the following ClassClassException:
Unhandled exception caught in event loop.
Reason:
Failed to execute runnable (java.lang.ClassCastException:
org.eclipse.draw2d.geometry.Rectangle)
*** Stack trace of contained exception ***
Reason:
And in the refreshVisuals of other EditParts of the example, they just set
color of the editPart. I don't see an example of setConstraints().
And the SetConstraints command of the code just use setLocation() method.
Thanks for your help again.
Sam
news:an0bvr$l9j$1@rogue.oti.com...
What
> LogicLabel.
> but
is
locator,
> not a Rectangle.
> of
> > the wire?
> > Thank you.
> > > > WireEditPart.
can
> I
> > > add
> sounds
users
> > move
that
> do
children.
> > > > Thank you.
the
> > create
> > > > > ConnectionEditPart.
connection.
I
> > > can't
return
> EditPart
> > > for
> > > > > > each
> labels,
> > > you
> > > draw2d
> > > > > > > > Hi,
> > (IFigure)
> > > to
> > > > a
> > > > > > > > PolyLineConnection.
> > > > > > > > <From the help >
> > > > LogicLabelEditPart)
> > > > > > to
> > > > > > > a
> > > > > > > > PolyLineConnection?
its
> > > > logicLabelEditPart
> > > > > to
> > > > > > > the
> > > > > > > > connection.
> > > > > > > > Thanks.
> > > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22391 is a reply to message #22370] Sun, 29 September 2002 00:40 Go to previous messageGo to next message
In the refreshVisuals() of WireEditPart, I try to call setLayoutConstraint()
to set the constraint of the label, like below:
setLayoutConstraint(label, figure, new ConnectionLocator ( (Connection)
getFigure() ) );
but I can't get the figure of the label from the label. The getFigure()
method also exist for the LabelEditPart, not the Label itself. And the
WireEditPart only has "Label".
Thanks for any help.
Sam
news:an3680$6ft$1@rogue.oti.com...
> Thanks again.
getModelChildren().
> Reason:
> Reason:
> Sam
teh
automatically
with
> What
> > LogicLabel.
WireEditPart,
> > but
an
It
> is
> locator,
> > not a Rectangle.
middle
> > of
> > > the wire?
> > > Thank you.
> > > > > WireEditPart.
> can
> > I
> > > > add
> > sounds
effort.
> users
> > > move
the
> that
> > do
> children.
> > > > > Thank you.
> the
> > > create
> > > > > > ConnectionEditPart.
> connection.
connection.
> I
> > > > can't
> return
> > EditPart
> > > > for
> > > > > > > each
> > labels,
> > > > you
the
> > > > draw2d
> > > > > > > > > Hi,
> > > (IFigure)
> > > > to
> > > > > a
> > > > > > > > > PolyLineConnection.
> > > > > > > > > <From the help >
> > > > > LogicLabelEditPart)
> > > > > > > to
> > > > > > > > a
> > > > > > > > > PolyLineConnection?
> its
> > > > > logicLabelEditPart
> > > > > > to
> > > > > > > > the
> > > > > > > > > connection.
> > > > > > > > > Thanks.
> > > > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22414 is a reply to message #22391] Sun, 29 September 2002 19:36 Go to previous messageGo to next message
Per Randy's suggestion, I think I need to set the layout constraint for the
label (now a children of Wire),
but the setLayoutConstraint() method needs an edit part, and a IFigure as
its first 2 parameters.
From the label object, it does not have a reference to the editpart, so I
can't get a reference of LabelEditPart from the Label object.
So how can I set the layout constraint of the label in the refreshVisuals()
of the Wire method?
Thanks for any suggestion.
> getFigure() ) );
> Sam
> > Thanks again.
> getModelChildren().
> > Reason:
> > Reason:
set
method.
> > Sam
> teh
> automatically
> with
> > What
> > > LogicLabel.
> WireEditPart,
> > > but
take
> an
> It
> > is
> > locator,
> > > not a Rectangle.
> middle
> > > of
> > > > the wire?
> > > > Thank you.
> > > > > > WireEditPart.
How
> > can
> > > I
> > > > > add
> > > sounds
the
> effort.
> > users
> > > > move
> the
> > that
> > > do
> > children.
> > > > > > Thank you.
creates
> > the
should
> > > > create
> > > > > > > ConnectionEditPart.
> > connection.
> connection.
> > I
> > > > > can't
> > return
> > > EditPart
> > > > > for
> > > > > > > > each
> > > labels,
> > > > > you
> the
> > > > > draw2d
label.
> > > > > > > > > > Hi,
> > > > (IFigure)
> > > > > to
> > > > > > a
> > > > > > > > > > PolyLineConnection.
> > > > > > > > > > <From the help >
> > > > > > LogicLabelEditPart)
> > > > > > > > to
> > > > > > > > > a
> > > > > > > > > > PolyLineConnection?
but
> > its
> > > > > > logicLabelEditPart
> > > > > > > to
> > > > > > > > > the
> > > > > > > > > > connection.
> > > > > > > > > > Thanks.
> > > > > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22457 is a reply to message #22391] Sun, 29 September 2002 21:06 Go to previous messageGo to next message
This is typically done from the child EditPart. The location of the label
is generally a property of the label, and this is true in the logic example.
So, the LabelEditPart already implements refreshVisuals, except it doesn't
know that it is in a connection.
Even if you do what you are trying, you still need to override
refreshVisuals() in LabelEditPart, because it thinks that Rectangle is used
as the constraint.
news:an5v0k$4be$1@rogue.oti.com...
> getFigure() ) );
> Sam
> > Thanks again.
> getModelChildren().
> > Reason:
> > Reason:
set
method.
> > Sam
> teh
> automatically
> with
> > What
> > > LogicLabel.
> WireEditPart,
> > > but
take
> an
> It
> > is
> > locator,
> > > not a Rectangle.
> middle
> > > of
> > > > the wire?
> > > > Thank you.
> > > > > > WireEditPart.
How
> > can
> > > I
> > > > > add
> > > sounds
the
> effort.
> > users
> > > > move
> the
> > that
> > > do
> > children.
> > > > > > Thank you.
creates
> > the
should
> > > > create
> > > > > > > ConnectionEditPart.
> > connection.
> connection.
> > I
> > > > > can't
> > return
> > > EditPart
> > > > > for
> > > > > > > > each
> > > labels,
> > > > > you
> the
> > > > > draw2d
label.
> > > > > > > > > > Hi,
> > > > (IFigure)
> > > > > to
> > > > > > a
> > > > > > > > > > PolyLineConnection.
> > > > > > > > > > <From the help >
> > > > > > LogicLabelEditPart)
> > > > > > > > to
> > > > > > > > > a
> > > > > > > > > > PolyLineConnection?
but
> > its
> > > > > > logicLabelEditPart
> > > > > > > to
> > > > > > > > > the
> > > > > > > > > > connection.
> > > > > > > > > > Thanks.
> > > > > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22590 is a reply to message #22457] Mon, 30 September 2002 19:21 Go to previous messageGo to next message
Thanks for the suggestion. I add the following code in refreshVisuals of the
LogicLabelEditPart, but I got an exception saying "Figure is not a child".
EditPart parent = getParent();
if (parent instanceof WireEditPart) {
WireEditPart wire = (WireEditPart)parent;
// this should be LogicLabelEditPart, getFigure should return Label
setLayoutConstraint(this, getFigure(), new ConnectionLocator
((Connection)wire.getFigure()));
The exception:
Reason:
IWAG0004E Figure.setConstraint(..): Figure is not a child
Thanks for any advice.
news:an86s0$2a1$1@rogue.oti.com...
example.
used
> as the constraint.
(Connection)
> > getFigure() ) );
> > Sam
> > > Thanks again.
> > getModelChildren().
> > > Reason:
> > > Reason:
> set
> method.
> > > Sam
in
> > teh
> > automatically
sync
> > with
getModelChildren().
> > > What
a
> > > > LogicLabel.
> > WireEditPart,
> > > > but
> take
> > an
children.
> > It
> > > is
> > > locator,
> > > > not a Rectangle.
> > middle
> > > > of
> > > > > the wire?
> > > > > Thank you.
the
> > > > > > > WireEditPart.
> How
> > > can
> > > > I
> > > > > > add
It
> > > > sounds
> the
> > effort.
when
> > > users
> > > > > move
for
> > the
objects
> > > that
> > > > do
> > > children.
> > > > > > > Thank you.
> creates
> > > the
> should
> > > > > create
for
> > > > > > > > ConnectionEditPart.
> > > connection.
> > connection.
> > > I
> > > > > > can't
message
> > > return
an
> > > > EditPart
> > > > > > for
> > > > > > > > > each
the
> > > > labels,
> > > > > > you
what
> > the
> > > > > > draw2d
> label.
> > > > > > > > > > > Hi,
Label
> > > > > (IFigure)
> > > > > > to
> > > > > > > a
> > > > > > > > > > > PolyLineConnection.
> > > > > > > > > > > <From the help >
> > > > > > > LogicLabelEditPart)
> > > > > > > > > to
> > > > > > > > > > a
> > > > > > > > > > > PolyLineConnection?
> but
> > > its
> > > > > > > logicLabelEditPart
> > > > > > > > to
> > > > > > > > > > the
> > > > > > > > > > > connection.
> > > > > > > > > > > Thanks.
> > > > > > > > > > > Sam
Re: How to add edit part to a PolyLineConnection [message #22633 is a reply to message #22590] Tue, 01 October 2002 09:44 Go to previous messageGo to next message
news:anal23$dni$1@rogue.oti.com...
the
Did you call this method on the parent (the wire)? I guess the method isn't
ideally named "setLayoutConstaintForChild", but if you think about it, there
would be no reason to pass this if you are calling the method on yourself.
it should be wire.setLayoutConstraint(this, getFigure(), locator)
Re: How to add edit part to a PolyLineConnection [message #24445 is a reply to message #22633] Sun, 06 October 2002 17:27 Go to previous message
Originally posted by: sy_cheung2.yahoo.com
Randy,
Thanks again. I am now able to add a Logic Label in the middle of a
connection. However, that label does not respond to the mouse select event,
mouse drag event and mouse popup event (right-mouse click). It does respond
to mouse double-click event so that I can edit the label content.
Do you have any idea why this happens? I add the same logic label in other
part of a diagram, i can move, right mouse click that label.
Thank you.
news:anc7ki$v7s$1@rogue.oti.com...
> the
child".
isn't
there
Previous Topic:Make Label in LogicEditor example resizble
Next Topic:Change the cursor in GEF
Current Time: Wed Jul 02 20:09:15 EDT 2025
Powered by FUDForum. Page generated in 0.05586 seconds
