Home » Modeling » M2T (model-to-text transformation) » running jet application
running jet application [message #20695] |
Wed, 06 June 2007 02:49  |
Originally posted by: alexjaquet.gmail.com
I would like to know to run jet from a gmf application.
Alexandre
Re: running jet application [message #20771 is a reply to message #20695] |
Wed, 06 June 2007 08:48   |
JET has an API:
JET2Platform.runTransformOnObject(transformID, documentRoot,
progressMonitor)
Get the EMF Resource object for your GMF model, and use that as the
documentRoot value.
If you JET transform uses the predefined variable
org.eclipse.jet.resource.project.name, it will not be defined when using
this API. You can define it yourself, however:
Map variables = new HashMap();
variables.put("org.eclipse.jet.resource.project.name",
theNameOfTheProjectContainingTheEMFResource);
JET2Platform.runTransformOnObject(transformID, documentRoot, variables,
progressMonitor)
Paul
"Alexandre Jaquet" <alexjaquet@gmail.com> wrote in message
news:f45ldt$r60$1@build.eclipse.org...
> Alexandre
Re: running jet application [message #25247 is a reply to message #20771] |
Sun, 08 July 2007 12:15   |
Originally posted by: woodri.us.ibm.com
Paul,
Thanks, that worked. I was able to load and run a template.
But there is a classloader problem. Another project that does work on a
model (call it com.xyz.myproject) uses templates to do part of the work.
A JET2 project manages the templates (call this project jet2test) - so
com.xyz.myproject runs a jet2test template.
When com.xyz.myproject passes one of its objects into the template's
generate() method via JET2Context's setVariable(), the template's
classloader can't find the object. The classloader is a
DefaultClassLoader, whose delegate is a BundleLoader. I looked at the
JET2 APIs, and didn't see access to classloader in JET2TemplateManager,
JET2TemplateLoader, or JET2Context.
Here's the setup:
- the context object is part of com.xyz.myproject, which exports package
com.xyz.myproject.stuff.
- the template is in project jet2test, which sees com.xyz.myproject as a
required project on the build path.
I'm debugging com.xyz.myproject, which loads a template from jet2test:
<%@ jet package="library.Writer.name" class="template1"
imports="com.xyz.myproject.stuff.MyClass" %>
<% MyClass instance = (MyClass) context.getVariable("MyClass"); %>
<%= instance.getSomeValue() %>
this compiles to:
import com.xyz.myproject.stuff.MyClass;
public void generate(final JET2Context context, final JET2Writer
__out) {
JET2Writer out = __out;
out.write( instance.getSomeValue() );
out.write(NL);
When context.getVariable("MyClass") runs, the classloader throws this
exception:
java.lang.NoClassDefFoundError: com.xyz.myproject.stuff.MyClass
at library.Writer.name.template1.generate(template1.java)
org.eclipse.jet.JET2TemplateManager$TemplateRunnerImpl.gener ate(JET2TemplateManager.java)
at com.xyz.myproject.template.Jet2Template$1.run(Jet2Template.j ava:52)
at org.eclipse.jet.JET2TemplateManager.run(JET2TemplateManager. java:147)
at com.xyz.myproject.template.Jet2Template.generate(Jet2Templat e.java:47)
at ...
Paul Elder wrote:
> JET has an API:
> progressMonitor)
> documentRoot value.
> progressMonitor)
> Paul
>> Thanks,
>> Regards,
>> Alexandre
Re: running jet application [message #25289 is a reply to message #25247] |
Sun, 08 July 2007 12:16  |
Whoa - sorry, replied to the wrong message. Should have been "invoke
template from java with string return?"
- Rick
Rick Wood wrote:
> Paul,
> Here's the setup:
> this compiles to:
> __out) {
> out.write(NL);
> exception:
> at
> at
> at
> at ...
> Paul Elder wrote:
>> JET has an API:
>> progressMonitor)
>> documentRoot value.
>> using this API. You can define it yourself, however:
>> variables, progressMonitor)
>> Paul
>>> Hi,
>>> Thanks,
>>> Regards,
>>> Alexandre
Current Time: Sun Aug 31 23:39:57 EDT 2025
Powered by FUDForum. Page generated in 0.05842 seconds
