Home » Modeling » M2T (model-to-text transformation) » running jet application
running jet application [message #20695] Wed, 06 June 2007 02:49 Go to next message
Originally posted by: alexjaquet.gmail.com
I would like to know to run jet from a gmf application.
Alexandre
Re: running jet application [message #20771 is a reply to message #20695] Wed, 06 June 2007 08:48 Go to previous messageGo to next message
JET has an API:
JET2Platform.runTransformOnObject(transformID, documentRoot,
progressMonitor)
Get the EMF Resource object for your GMF model, and use that as the
documentRoot value.
If you JET transform uses the predefined variable
org.eclipse.jet.resource.project.name, it will not be defined when using
this API. You can define it yourself, however:
Map variables = new HashMap();
variables.put("org.eclipse.jet.resource.project.name",
theNameOfTheProjectContainingTheEMFResource);
JET2Platform.runTransformOnObject(transformID, documentRoot, variables,
progressMonitor)
Paul
"Alexandre Jaquet" <alexjaquet@gmail.com> wrote in message
news:f45ldt$r60$1@build.eclipse.org...
> Alexandre
Re: running jet application [message #20807 is a reply to message #20771] Wed, 06 June 2007 09:50 Go to previous messageGo to next message
Thanks Paul,
Alexandre
"Paul Elder" <pelder@ca.ibm.com> a
Re: running jet application [message #25247 is a reply to message #20771] Sun, 08 July 2007 12:15 Go to previous messageGo to next message
Originally posted by: woodri.us.ibm.com
Paul,
Thanks, that worked. I was able to load and run a template.
But there is a classloader problem. Another project that does work on a
model (call it com.xyz.myproject) uses templates to do part of the work.
A JET2 project manages the templates (call this project jet2test) - so
com.xyz.myproject runs a jet2test template.
When com.xyz.myproject passes one of its objects into the template's
generate() method via JET2Context's setVariable(), the template's
classloader can't find the object. The classloader is a
DefaultClassLoader, whose delegate is a BundleLoader. I looked at the
JET2 APIs, and didn't see access to classloader in JET2TemplateManager,
JET2TemplateLoader, or JET2Context.
Here's the setup:
- the context object is part of com.xyz.myproject, which exports package
com.xyz.myproject.stuff.
- the template is in project jet2test, which sees com.xyz.myproject as a
required project on the build path.
I'm debugging com.xyz.myproject, which loads a template from jet2test:
<%@ jet package="library.Writer.name" class="template1"
imports="com.xyz.myproject.stuff.MyClass" %>
<% MyClass instance = (MyClass) context.getVariable("MyClass"); %>
<%= instance.getSomeValue() %>
this compiles to:
import com.xyz.myproject.stuff.MyClass;
public void generate(final JET2Context context, final JET2Writer
__out) {
JET2Writer out = __out;
out.write( instance.getSomeValue() );
out.write(NL);
When context.getVariable("MyClass") runs, the classloader throws this
exception:
java.lang.NoClassDefFoundError: com.xyz.myproject.stuff.MyClass
at library.Writer.name.template1.generate(template1.java)
org.eclipse.jet.JET2TemplateManager$TemplateRunnerImpl.gener ate(JET2TemplateManager.java)
at com.xyz.myproject.template.Jet2Template$1.run(Jet2Template.j ava:52)
at org.eclipse.jet.JET2TemplateManager.run(JET2TemplateManager. java:147)
at com.xyz.myproject.template.Jet2Template.generate(Jet2Templat e.java:47)
at ...
Paul Elder wrote:
> JET has an API:
> progressMonitor)
> documentRoot value.
> progressMonitor)
> Paul
>> Thanks,
>> Regards,
>> Alexandre
Re: running jet application [message #25289 is a reply to message #25247] Sun, 08 July 2007 12:16 Go to previous message
Whoa - sorry, replied to the wrong message. Should have been "invoke
template from java with string return?"
- Rick
Rick Wood wrote:
> Paul,
> Here's the setup:
> this compiles to:
> __out) {
> out.write(NL);
> exception:
> at
> at
> at
> at ...
> Paul Elder wrote:
>> JET has an API:
>> progressMonitor)
>> documentRoot value.
>> using this API. You can define it yourself, however:
>> variables, progressMonitor)
>> Paul
>>> Hi,
>>> Thanks,
>>> Regards,
>>> Alexandre
Previous Topic:Content assist/Locating error in JETEditor
Next Topic:Re: invoke template from java with string return?
Current Time: Sat Jul 26 10:07:36 EDT 2025
Powered by FUDForum. Page generated in 0.05679 seconds
