Home » Archived » Visual Editor (VE) » Adding new Beans to the pallete
Adding new Beans to the pallete [message #20693] Wed, 25 February 2004 01:07 Go to next message
Originally posted by: sibin.exorindia.com
Hi Everybody
Iam New to eclipse VE plugin.I want to add a new bean to the pallete.For
this purpose I created a new xmi entry so that I can append to the current
list of tools.But i have little idea about how to register the bean and
beaninfo classes.
Hope somebody will help me.
thank in advance.
Re: Adding new Beans to the pallete [message #20708 is a reply to message #20693] Wed, 25 February 2004 02:47 Go to previous messageGo to next message
sibin,
You need to create a plugin for that. There is an excellent tutorial that
can help you :
http://www-106.ibm.com/developerworks/websphere/library/tech articles/0302_wi
nchester/winchester.html
Though it's about WSAD 5 (i.e. Eclipse 2.0) it gives you a good idea about
what's to be done.
Then you just have to look at the VE plugins to make it work (basically it's
the same principle, but some class names changed, same for the XMI file).
If you need additional help, I can send you the plugin I've done for my
palette.
Hope that helps,
S
Re: Adding new Beans to the pallete [message #20732 is a reply to message #20708] Thu, 26 February 2004 05:42 Go to previous messageGo to next message
Hi Sebastien,
We have a plug-in for WSAD 5.0.1 which we would like to port to Eclipse
2.1.2 and VE 0.5.0. Is there any documentation about the migration path
one needs to take?
If you can send me your palette plug-in for Eclipse 2.1.2, it will be of
big help in finding out the changes one needs to make to an WSAD plug-in.
Many thanks for your help
- Janak
janak.mulani@canoo.com
Sébastien Alonzo wrote:
> sibin,
> can help you :
> what's to be done.
> palette.
> Hope that helps,
> Sébastien Alonzo
> mailto:salonzo@fr.ibm.com
Re: Adding new Beans to the pallete [message #20756 is a reply to message #20732] Thu, 26 February 2004 09:11 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
The JFC palette is contributed in the org.eclipse.ve.jfc plugin.
No up-to-date documentation (beyond the one noted on this thread) at
this time. ... just so many hours in a day. If you write one, we will
be more than happy to post it on the VEP site. If you get stuck in your
port, feel free to ask here or on the mailing list.
janak wrote:
> Hi Sebastien,
> one needs to take?
> - Janak
Re: Adding new Beans to the pallete [message #20798 is a reply to message #20756] Thu, 26 February 2004 12:26 Go to previous messageGo to next message
------=_NextPart_000_0030_01C3FC96.0EB36E40
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_0031_01C3FC96.0EB36E40"
------=_NextPart_001_0031_01C3FC96.0EB36E40
Content-Type: text/plain;
charset="ISO-8859-15"
Actually I've already posted a tip to port palette plugins from WSAD 5.0 =
to Eclipse 2.1.2
Here it is :
Note that the starting point is the tutorial from Joe Winchester :=20
http://www-106.ibm.com/developerworks/websphere/library/tech articles/0302=
_winchester/winchester.html
Then you need to make some changes to plugin.xml and the palette xmi =
file.
For Eclipse 2.1.2 :
1) In the plugin manifest file (plugin.xml) :
The required plugins need to be changed from "com.ibm.etools.jbcf" to =
"org.eclipse.jem.beaninfo" and "org.eclipse.ve.java.core"
and extensions points need to be changed from =
"com.ibm.etools.jbcf.registrations" to =
"org.eclipse.ve.java.core.registrations"
and from "com.ibm.etools.beaninfo.registrations" to =
"org.eclipse.jem.beaninfo.registrations".
2) In the palette xmi file :
The XMI file namespaces are just slightly different :=20
a.. xmlns:palette needs to be changed from "palettecde.xmi" to =
"http:///org/eclipse/ve/internal/cde/palette.ecore",=20
b.. xmlns:cdm needs to be changed from "cdm.xmi" to =
"http:///org/eclipse/ve/internal/cdm.ecore",
c.. xlmns:utility needs to be changed from "utilitycde.xmi" to =
"http:///org/eclipse/ve/internal/cde/utility.ecore"
For WSAD 5.1 :
The extension point "com.ibm.etools.beaninfo.registrations" must be =
changed into "com.ibm.etools.jbcf.registrations"
The XMI file namespaces have changed :=20
"http:///com/ibm/etools/cde/palette.ecore",=20
"http:///com/ibm/etools/cdm.ecore",
"http:///com/ibm/etools/cde/utility.ecore"
That should be enough (it actually worked fine for me)
Anyway, I noticed some differences in the new XMI files, I don't know =
what they are about but I added it to my plugins anyway (I haven't =
noticed any differences in the plugin itself) :
1) Add New namespace declaration : =
xmlns:ecore=3D"http://www.eclipse.org/emf/2002/Ecore"
2) Remove all xmi:id attributes
3) Change all xmi:type values from "cdm:KeyedString" to =
"ecore:EStringToStringMapEntry"
That's all Folks !
Hope that helps.
P.S : if not my plugin files are attached
"Gili Mendel" <mendelgili@netscape.net> wrote in message =
news:c1kuk4$l2$1@eclipse.org...
>=20
> No up-to-date documentation (beyond the one noted on this thread) at=20
> this time. ... just so many hours in a day. If you write one, we =
will=20
> be more than happy to post it on the VEP site. If you get stuck in =
your=20
>=20
>=20
>=20
>=20
> janak wrote:
>=20
> > Hi Sebastien,
> >=20
> > We have a plug-in for WSAD 5.0.1 which we would like to port to =
Eclipse
> > 2.1.2 and VE 0.5.0. Is there any documentation about the migration =
path
> > one needs to take?
> >=20
> > If you can send me your palette plug-in for Eclipse 2.1.2, it will =
be of
> > big help in finding out the changes one needs to make to an WSAD =
plug-in.
> >=20
> >=20
> > - Janak
> >=20
> > S=E9bastien Alonzo wrote:
> >=20
> >=20
>=20
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Actually I've already posted a tip to =
port palette=20
plugins from WSAD 5.0 to Eclipse 2.1.2</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Here it is :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Note that the starting point is the =
tutorial from=20
Joe Winchester&nbsp;: </FONT></DIV>
<DIV><A=20
href=3D" http://www-106.ibm.com/developerworks/websphere/library/tech artic=
les/0302_winchester/winchester.html">http://www-106.ibm.com/developerwork=
s/websphere/library/techarticles/0302_winchester/winchester. html </A><BR><=
/DIV>
<DIV><FONT face=3DArial size=3D2>Then you need to make some changes to =
plugin.xml=20
and the palette xmi file.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><U>For Eclipse 2.1.2 :</U></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1) In the plugin manifest file =
(plugin.xml)=20
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The <EM>required plugins</EM> need to =
be changed=20
from "<FONT color=3D#008080><STRONG>com.ibm.etools.jbcf</STRONG></FONT >" =
to=20
"<STRONG><FONT color=3D#008080>org.eclipse.jem.beaninfo</FONT></STRONG>" =
and=20
"<STRONG><FONT =
color=3D#008080>org.eclipse.ve.java.core</FONT></STRONG>" <BR>and=20
<EM>extensions points</EM> need to be changed from "<FONT=20
color=3D#008080><STRONG>com.ibm.etools.jbcf.registrations</STRONG ></FONT>=
" to=20
"<STRONG><FONT=20
color=3D#008080>org.eclipse.ve.java.core.registrations</FONT ></STRONG>"</=
FONT></DIV>
<DIV><FONT face=3DArial size=3D2>and from "<FONT=20
color=3D#008080><STRONG>com.ibm.etools.beaninfo.registrations </STRONG></F=
ONT>" to=20
"<STRONG><FONT=20
color=3D#008080>org.eclipse.jem.beaninfo.registrations</FONT ></STRONG>".<=
BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2) In the palette xmi file =
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The XMI file namespaces are just =
slightly different=20
: </FONT></DIV>
<UL>
<LI><FONT face=3DArial size=3D2>xmlns:palette needs to be changed from =
"<FONT=20
color=3D#0000ff><STRONG>palettecde.xmi</STRONG></FONT>" to =
"<STRONG><FONT=20
color=3D#0000ff>http:///org/eclipse/ve/internal/cde/palette.ecore</FONT><=
/STRONG></FONT><FONT=20
face=3DArial size=3D2>", </FONT></LI>
<LI><FONT face=3DArial size=3D2>xmlns:cdm needs to be changed from =
"<STRONG><FONT=20
color=3D#0000ff>cdm.xmi</FONT></STRONG>" to "<STRONG><FONT=20
color=3D#0000ff>http:///org/eclipse/ve/internal/cdm.ecore</FONT></STRONG>=
",</FONT></LI>
<LI><FONT face=3DArial size=3D2>xlmns:utility needs to be changed from =
"<STRONG><FONT color=3D#0000ff>utilitycde.xmi</FONT></STRONG>" to =
"<STRONG><FONT=20
color=3D#0000ff>http:///org/eclipse/ve/internal/cde/utility.ecore</FONT><=
face=3DArial size=3D2>"</FONT></LI></UL>
<DIV><FONT face=3DArial size=3D2><U>For WSAD 5.1 :</U></FONT></DIV>
(plugin.xml)=20
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The extension point "<FONT=20
ONT>"=20
must be changed into "<FONT=20
"</FONT></DIV>
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The XMI file namespaces have changed :=20
</FONT></DIV>
<UL>
"<FONT=20
"<STRONG><FONT=20
color=3D#0000ff>http:///com/ibm/etools/cde/palette.ecore</FONT></STRONG><=
/FONT><FONT=20
"<STRONG><FONT=20
color=3D#0000ff>http:///com/ibm/etools/cdm.ecore</FONT></STRONG>",</FONT>=
</LI>
"<STRONG><FONT=20
color=3D#0000ff>http:///com/ibm/etools/cde/utility.ecore</FONT></STRONG><=
/FONT><FONT=20
<DIV><FONT face=3DArial size=3D2>That should be enough (it actually =
worked fine for=20
me)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT><FONT face=3DArial =
size=3D2></FONT><FONT=20
face=3DArial size=3D2></FONT><FONT face=3DArial size=3D2></FONT><FONT =
face=3DArial=20
<DIV><FONT face=3DArial size=3D2>Anyway, I&nbsp;noticed some differences =
in the new=20
XMI files, I don't know what they are about but I added it to my plugins =
anyway=20
(I haven't noticed any differences in the plugin itself) :</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1) Add New namespace declaration : =
xmlns:ecore=3D"<A=20
href=3D"http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf=
/2002/Ecore</A>"</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2) Remove all <STRONG>xmi:id</STRONG>=20
attributes</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>3) Change =
all&nbsp;<STRONG>xmi:type</STRONG> values=20
from "<FONT color=3D#008080><STRONG>cdm:KeyedString</STRONG></FONT>" to=20
"<STRONG><FONT=20
color=3D#008080>ecore:EStringToStringMapEntry</FONT></STRONG >"</FONT></DI=
V>
<DIV><FONT face=3DArial size=3D2>That's all Folks !</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Hope that helps.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>P.S : if not my plugin files are=20
attached</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"Gili Mendel" &lt;</FONT><A=20
href=3D"mailto:mendelgili@netscape.net"><FONT face=3DArial=20
size=3D2>mendelgili@netscape.net</FONT></A><FONT face=3DArial =
size=3D2>&gt; wrote in=20
message </FONT><A href=3D"news:c1kuk4$l2$1@eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:c1kuk4$l2$1@eclipse.org</FONT></A><FONT face=3DArial=20
size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>&gt; The JFC =
palette is=20
contributed in the org.eclipse.ve.jfc plugin.<BR>&gt; <BR>&gt; No =
up-to-date=20
documentation (beyond the one noted on this thread) at <BR>&gt; this =
time.&nbsp;=20
.... just so many hours in a day.&nbsp; If you write one, we will =
<BR>&gt; be=20
more than happy to post it on the VEP site.&nbsp; If you get stuck in =
your=20
<BR>&gt; port, feel free to ask here or on the mailing list.<BR>&gt; =
<BR>&gt;=20
<BR>&gt; <BR>&gt; <BR>&gt; janak wrote:<BR>&gt; <BR>&gt; &gt; Hi=20
Sebastien,<BR>&gt; &gt; <BR>&gt; &gt; We have a plug-in for WSAD 5.0.1 =
which we=20
would like to port to Eclipse<BR>&gt; &gt; 2.1.2 and VE 0.5.0.&nbsp; Is =
there=20
any documentation about the migration path<BR>&gt; &gt; one needs to=20
take?<BR>&gt; &gt; <BR>&gt; &gt; If you can send me your palette plug-in =
for=20
Eclipse 2.1.2, it will be of<BR>&gt; &gt; big help in finding out the =
changes=20
one needs to make to an WSAD plug-in.<BR>&gt; &gt; <BR>&gt; &gt; Many =
thanks for=20
your help<BR>&gt; &gt; <BR>&gt; &gt; - Janak<BR>&gt; &gt;&nbsp;&nbsp; =
</FONT><A=20
href=3D"mailto:janak.mulani@canoo.com"><FONT face=3DArial=20
size=3D2>janak.mulani@canoo.com</FONT></A><BR><FONT face=3DArial =
size=3D2>&gt; &gt;=20
<BR>&gt; &gt; S=E9bastien Alonzo wrote:<BR>&gt; &gt; <BR>&gt; &gt; =
<BR>&gt;=20
\<BR>&gt; </FONT></BODY></HTML>
------=_NextPart_001_0031_01C3FC96.0EB36E40--
Content-Type: application/octet-stream;
name="Palette.zip"
Content-Disposition: attachment;
filename="Palette.zip"
UEsDBBQAAAAIAC2OWjDT5eH73gIAANQcAAAdAAAAY2FseXBzb3BhbGV0dGVf RWNsaXBzZTIxMi54
bWnNmU9vmzAYh8+ZtO+AvDtOe9gBkUotSqdK7Q5tp/XqgEOdGhvZJn++/Qx2 WiBE69CklxMKvP69
DzyOEyDeFyx6ebgL6u2WKs2kWKDLcI7sHi50ZPcv0KsxZYTxbrcLZZGHUuXY jkFfvwS+iqZS0U4d
TTkrNW1qabHGl/P5JV7WZSj4GFcSTo35GImbcjcUbylmwlAlCMdpRrEvDptm reZpVnwmoPADW+0r
wzgzh8+198U+5SqwObPYM0UJMTSX6pAUZXMpWbZAKTEX6MpWzeLUH74nK8qD vWaROZT2tH1mlEih
DRHmySgmchToZrtACeGHUsvgN8tyajTCPq4ofyhZlboVdSRpDlgM17mpXQob R4eKr4WQxrJliaLE
WPd16QEFLJXi4vtPUtS1nJi1VEWES17lTOC1CtmqCFPHFu4cG67HaHxTGVOP DXO29gizWK42NDWd
HgMwy4fbY8mzlNyhuIRZ6g8knGj96/FugTZkS6I+S16xb47AXyrbfEt4VZ98 cezXCIyW7lo/S7d9
IKU/9zdqJ4SdCO9TeEvD40QI7UQI6+GhsNeGiVQWpdSsJkNB02iB2HbTR6B1 8r+674bE+EMkjNlr
peQOXm8LA9TxIMco0QNJ8LaTV5q+3cg9pOojA6jnU4hRkvsx8Iaf6d7cMsoz SMXvEKCOByhGST7J
mYblaxsGLblmAHfchRituB0zgZX6nmkDukzXALBrdJdg3ALdzpiAVVmsJPTv r2eAdXsCMU5vL2YC
K7OiFHRVtv1hV+QOwLjVuBUxAaNkxWGV1gCwTrsE46S2M06sNjvc0w/3ecIP Q5r2kBOiAQCdED2C
UROikwH/NXeTagL3xx0QeMv/6U55MAve+iPJmHRPacC/1n0WUPfnYUbpPxcH PwOebFylb4iCVP8O
Aep8gGKU7JMceMu3tvJOlJVpliAKKrvPAur8PMwo9efi/vaHLz6+B2y/c7MH YuxfZV79AVBLAwQU
AAAACAArjlowmqmJBdcCAAD/GwAAGQAAAGNhbHlwc29wYWxldHRlX1dTQUQ1 MS54bWnNmc1vmzAY
xs+ZtP8BsTvuetgBkUotSqZK7Q5tp+3qgEOd+gPZJh///YztNEBIp6EJc0LB r5/nwT/nTYBkT3H8
+/E+qI9bJCTmbB5eR1ehPkOYjPX5efiqVBkDsNvtIk6LiIsC6Dnh50+Bq0IZ F6hVhzKCS4lMLaJr
cH11dQ0WdVkYnOaVkCClTjNBxinAKwqQ4pxIkOUIuJrIeDQ8s5x+MI+6+oZZ pTDB6vChmatxk28C
PX2WuARxChUquDiktDTrhfN5mEJyKCX/hfMCKRne6PpZkrnCB7hCJNhLHKtD qa/SqccpZ1JBpp6V
wKwIA2mO72LBUQ04OVp+F7wqZUPqmMkM6EDW2dQumJZDfcW3jHGls+WpQFBp 1HXpIQxwxtnXbz8g
rWsJVGsuaAxKUhWYgbWI9CJFmc0W7Ww2UM+R4K5Sqp4bFXjtIswSvtqgTLU8 esIsHpfHkhe9/jaK
VZhlbiAlUMqfT/fzcAO3MO5mKSr8xSZwS6XNt5BU9cXTo59BGS/sWr9we3yE pbv2N6R3hN4JRtju
hEjvhIjp1cBMD5Rc4jpLGBjpeYi3m64pqrX+lXZbJAEndH5Y3grBd/6BNmKM TLXXeRDaHiX/fNNX
lL3d8b1PuMcMI5M9tx2EtSvjn+kL2qslRiT3CfU9xMhUe3wHYT3TmQbXWy3m G2udwQPVtu1gqE2Z
CfTfByyV1+ZbBxi787Y9h7XdpsYEOHK64r5/R12GsWme2Q4D2pGZQL8VCHnt tdp/7D7bshzWYxsS
E2AIV8QvxDrA2BTbnsMwNjXOOJoT9vmD/TzhxxHG3ucWMAFG3gIdz0FboKXh /6tst9EE7ldbQXxw
/U93rr1a/jk/wRxz+5zE+1e3m2Vk2pftBwG/JOef+bOWq+QdFD5hv4cYmXKP 7yC8Zzr+uS515T0r
K2XaDPKKt5tlZMqX7QfBviT3t79qyfHdWfPNlR5IgHvrd/MHUEsDBBQAAAAI AE1JNDByHHSs9gEA
ADYGAAAVAAAAcGx1Z2luX0VjbGlwc2UyMTIueG1srVVNb9swDD23QP+DoXul 7TYUsYvV+0CBDSuQ
DkFPhWIzLlNb8iglzfrrJ0txYsfOlmHzyRT5+PH0aE+uN1UZrYEMahWzt/wN i0BlOkdVxOz7/afL
d+w6uTif1OWqQHVxHkUR5jFbEMd5xTNZ/qyN5i+YF2AN834lK/h9RLeeq+jP atJrzIEuA/z25mt0
k06Zq+3dE1opixUkwRJ9k+DHCglMMJsTrGpNNgptx0xTwSErsTbAl1DxOUiF aqGZOAmydii5ljzT
BCdClrnlK2yDXcP7FtuRYGNBNUS0+RoaNCp7vF9OUKCxJK2DGbbvZC0J5byE Tqomm7RPMUvff3m4
m357nN1++PzxfrpHNcA2s0n60J2jfxyeZ1ROBGFsNhYQCotxEYg5KrF9f3Q0 LSWxZJBlYkBS9tRk
Gqvgi2TPsjiqtf0ljyQX++yHg4sW1+NJDImaiJb19pJ3N5r83Q17rfCslMY0 HaVaWYkK6M6N17nk
8YDWfXYWVicNNESz7sp5v8cPlO3aAVKyDBJ/wVdJOU/bUjNvN3WuDnXU5+34 Z+HPg4nxiH+ktbu1
/2VxDmNKsBYyaU2zC9IuNFVXImzFMelv7S2Wbyrsr6MfLR/odfu5i1lndfze DCKNXlHmAg1lux1z
7/wV636lwGp+oprdL2A7mTN+AVBLAwQUAAAACAC3cDowB8+v8OMBAADABQAA EQAAAHBsdWdpbl9X
U0FENTEueG1stVRdb5swFH1upf4H5Pfa29tUhVQr+1ClTauUTlGfKmNu6E3B Ztcmy/rrZzAkkJB1
mjSesO8959xPz663ZRFtgCwaHbO3/A2LQCuToc5j9v3+0+U7dj2/OJ9VRZ2j vjiPogizmK2IY1py
JYtflTX8J2Y5OMtau5Yl/NljqOcV27uKzAYzoMsAv735Gt0kC+a1W/OMau2w hHk4ifGR4EeNBDYc
mxssK0MuCmHHTJmyDQecMYXl61StmNhx7dG9Gmwd6CbGnrCJ0KB2k1ScIEfr SDqPsGwfxUYSyrSA
AUtDJN1TzJL3Xx7uFt8el7cfPn+8X+xRDTAFqVGvjJ2PoTvD+Dp8z6h9a0LK bMohCIvp1ogUtej+
HzPH15LY/IhlZkGSemqYphRaEfUs85MTwPsMpsjFnv0wcdHjRnUSx4Waib7q fX93zZy/2lxDOQdV
YGWBr30RauSqkNY2ESVGO4ka6M6nN2jytENvPjsLA52EMkTL4SK09hY/PVc+ JiAtC570Gkt8kZQ1
AleHAzQu2OktfT0jMe3xD/X8X8ty6FOAc6Cks838S7cyVF6JsAmnxr07d1i+ LXG8gm1W2dGMdg9P
zAbr0u7Kkac1NSnvaEnt9sr/8xesxkqhoNlfTrB/jLvM/OE3UEsBAhQAFAAA AAgALY5aMNPl4fve
AgAA1BwAAB0AAAAAAAAAAQAgALaBAAAAAGNhbHlwc29wYWxldHRlX0VjbGlw c2UyMTIueG1pUEsB
AhQAFAAAAAgAK45aMJqpiQXXAgAA/xsAABkAAAAAAAAAAQAgALaBGQMAAGNh bHlwc29wYWxldHRl
X1dTQUQ1MS54bWlQSwECFAAUAAAACABNSTQwchx0rPYBAAA2BgAAFQAAAAAA AAABACAAtoEnBgAA
cGx1Z2luX0VjbGlwc2UyMTIueG1sUEsBAhQAFAAAAAgAt3A6MAfPr/DjAQAA wAUAABEAAAAAAAAA
AQAgALaBUAgAAHBsdWdpbl9XU0FENTEueG1sUEsFBgAAAAAEAAQAFAEAAGIK AAAAAA==
------=_NextPart_000_0030_01C3FC96.0EB36E40--
Re: Adding new Beans to the pallete [message #20811 is a reply to message #20798] Thu, 26 February 2004 12:53 Go to previous message
------=_NextPart_000_0040_01C3FC99.CE618800
Well, I seem to have press "Send" a bit sooner than I should have ...
There are some steps missing (some important, some very important ;-))
In the plugin manifest (plugin.xml) you should change the extension =
point for Eclipse 2.1.2 "org.eclipse.jdt.ui.classpathContainerPage" :
"com.ibm.etools.jbcf.internal.ClasspathWizardPage" becomes =
"org.eclipse.ve.internal.java.wizard.ClasspathWizardPage"
(nothing to change for WSAD 5.1)
In the palette XMI file : the key attribute for the <values> tag is =
different for Eclipse 2.1.2 :
"com.ibm.etools.cde.nameincomposition" becomes =
"org.eclipse.ve.internal.cde.core.nameincomposition"
(again, nothing to change for WSAD)
Now, that's all (really)
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Well, I seem to have press "Send" a bit =
sooner than=20
I&nbsp;should have ...</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>There are&nbsp;some steps missing (some =
important,&nbsp;some very important ;-))</FONT></DIV>
<DIV>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>In the plugin manifest =
(plugin.xml)&nbsp;you should=20
change&nbsp;the extension point for Eclipse=20
2.1.2&nbsp;"<STRONG>org.eclipse.jdt.ui.classpathContainerPage </STRONG>"=20
:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>"<STRONG><FONT=20
color=3D#008080>com.ibm.etools.jbcf.internal.ClasspathWizardPage </FONT></=
STRONG>"=20
becomes "<STRONG><FONT=20
color=3D#008080>org.eclipse.ve.internal.java.wizard.ClasspathWizardPage </=
FONT></STRONG>"</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>(nothing to&nbsp;change for WSAD =
5.1)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>In the palette XMI file : the =
<STRONG>key</STRONG>=20
attribute for the <STRONG>&lt;values&gt;</STRONG> tag is different for =
Eclipse=20
2.1.2 :</FONT></DIV>
color=3D#008080>com.ibm.etools.cde.nameincomposition</FONT ></STRONG>" =
becomes=20
"<STRONG><FONT=20
color=3D#008080>org.eclipse.ve.internal.cde.core.nameincomposition </FONT>=
<DIV><FONT face=3DArial size=3D2>(again, nothing to change for =
WSAD)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Now, that's all =
(really)</FONT></DIV></BODY></HTML>
------=_NextPart_000_0040_01C3FC99.CE618800--
Re: Adding new Beans to the pallete [message #582389 is a reply to message #20693] Wed, 25 February 2004 02:47 Go to previous message
sibin,
can help you :
what's to be done.
palette.
Hope that helps,
S
Re: Adding new Beans to the pallete [message #582418 is a reply to message #20708] Thu, 26 February 2004 05:42 Go to previous message
Hi Sebastien,
one needs to take?
- Janak
> sibin,
> can help you :
> what's to be done.
> palette.
> Hope that helps,
> Sébastien Alonzo
Re: Adding new Beans to the pallete [message #582461 is a reply to message #20732] Thu, 26 February 2004 09:11 Go to previous message
janak wrote:
> Hi Sebastien,
> one needs to take?
> - Janak
Re: Adding new Beans to the pallete [message #582515 is a reply to message #20756] Thu, 26 February 2004 12:26 Go to previous message
to Eclipse 2.1.2
Here it is :
file.
For Eclipse 2.1.2 :
For WSAD 5.1 :
That's all Folks !
Hope that helps.
>=20
will=20
your=20
>=20
>=20
>=20
>=20
> janak wrote:
>=20
> > Hi Sebastien,
> >=20
Eclipse
path
> > one needs to take?
> >=20
be of
plug-in.
> >=20
> >=20
> > - Janak
> >=20
> >=20
> >=20
>=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<BODY>
port palette=20
tutorial from=20
<DIV><A=20
/DIV>
plugin.xml=20
(plugin.xml)=20
:</FONT></DIV>
be changed=20
to=20
and=20
"<STRONG><FONT =
" to=20
"<STRONG><FONT=20
FONT></DIV>
ONT>" to=20
"<STRONG><FONT=20
BR></FONT></DIV>
:</FONT></DIV>
: </FONT></DIV>
<UL>
"<FONT=20
"<STRONG><FONT=20
"<STRONG><FONT=20
",</FONT></LI>
"<STRONG><FONT=20
(plugin.xml)=20
:</FONT></DIV>
ONT>"=20
"</FONT></DIV>
:</FONT></DIV>
</FONT></DIV>
<UL>
"<FONT=20
"<STRONG><FONT=20
/FONT><FONT=20
"<STRONG><FONT=20
</LI>
"<STRONG><FONT=20
/FONT><FONT=20
worked fine for=20
me)</FONT></DIV>
face=3DArial=20
in the new=20
anyway=20
"<STRONG><FONT=20
V>
face=3DArial=20
palette is=20
up-to-date=20
time.&nbsp;=20
<BR>&gt; be=20
your=20
<BR>&gt;=20
which we=20
there=20
for=20
changes=20
thanks for=20
</FONT><A=20
<BR>&gt;=20
name="Palette.zip"
Re: Adding new Beans to the pallete [message #582525 is a reply to message #20798] Thu, 26 February 2004 12:53 Go to previous message
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
sooner than=20
<DIV>&nbsp;</DIV>
<DIV>&nbsp;</DIV>
:</FONT></DIV>
STRONG>"=20
5.1)</FONT></DIV>
Eclipse=20
becomes=20
"<STRONG><FONT=20
WSAD)</FONT></DIV>
Previous Topic:New to VE
Next Topic:Install Problems
Current Time: Sat Jul 26 00:16:09 EDT 2025
Powered by FUDForum. Page generated in 0.06028 seconds
