Home » Newcomers » Newcomers » HTTP 404 Not Found with Help Contents
HTTP 404 Not Found with Help Contents [message #20686] Sat, 29 January 2005 14:37 Go to next message
Originally posted by: plutz.it.rit.edu
When I select Help -> Help Contents, I get an HTTP 404 Not Found error.
This is
with a brand new installation of Eclipse 3.0.1. Happens even with my
firewall turned off and McAfee's On Access Scan turned off.
Any Pointers??? I have been all over the web with no success.
Pete
Re: HTTP 404 Not Found with Help Contents [message #27641 is a reply to message #20686] Wed, 16 February 2005 11:25 Go to previous messageGo to next message
Originally posted by: Jwyatt1980.adelphia.net
> This is
> Pete
Pete,
Try this.
Open up Eclipse. Go to Window->Preferences->Help->Helpserver.
In the Hostname or IP address field enter: 127.0.0.1
This should fix your problem. It worked for me once, although I forget
the exact nature of the problem though.
John
Re: HTTP 404 Not Found with Help Contents [message #149942 is a reply to message #20686] Wed, 26 April 2006 20:36 Go to previous messageGo to next message
Originally posted by: mchambers.nospam.objectmastery.com
> This is
> Pete
Peter,
Did you find a solution to this problem? I have the same symptom.
Mark Chambers
Re: HTTP 404 Not Found with Help Contents [message #150347 is a reply to message #149942] Sat, 29 April 2006 15:18 Go to previous messageGo to next message
I've had this problem a time ago. Help in Eclipse runs as web applicatio=
n =
with tomcat (a lot of html files well organized). Unfortuned if U have a=
plugin with another version of commons-logging.jar tomcat refuse to star=
t =
and generate error (blame jakarta loggin... :-( ). This was the case I =
faced with, because of Hibernate Tools beta 4 plugin that has a differen=
t =
version of common loggin jar file. So if U've installed a plugin with =
common loggin jar archive, uninstall it... For me works disable and enab=
le =
again the plugin with problematic jar. I hope this help. Best.
On Thu, 27 Apr 2006 03:36:29 +0300, mdc =
<mchambers@nospam.objectmastery.com> wrote:
> Peter Lutz wrote:
>> When I select Help -> Help Contents, I get an HTTP 404 Not Found erro=
r. =
>> This is
>> with a brand new installation of Eclipse 3.0.1. Happens even with my =
>> Pete
> Peter,
> Mark Chambers
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: HTTP 404 Not Found with Help Contents [message #150354 is a reply to message #149942] Sat, 29 April 2006 17:31 Go to previous message
Originally posted by: dcurry.glic.com
I was having this problem at work, but not at home. Turns out the web
proxy at work was missing an entry in its configuration script (the
wpad.dat file) to tell the browser to make a direct connection to
"127.0.0.1". If you're using a web proxy, try going into IE's
Tools->Internet Options->Connections->LAN Settings and turning all the
proxy stuff off. Then see if Eclipse Help works.
--Dave
Previous Topic:Launch Failure on WinXP
Next Topic:Bug Tracking in Eclipse?
Current Time: Sat Jul 12 19:41:25 EDT 2025
Powered by FUDForum. Page generated in 0.07837 seconds
