Home » Newcomers » Newcomers » newbie on workspace resource programming
newbie on workspace resource programming [message #213164] |
Thu, 31 May 2007 20:26 |
Originally posted by: psentosa.yahoo.com
Hi everyone,
I posted a similar question some times ago, but unfortunately I didn't get
any really helpful replies and still get stuck with the problem.
It is about workspace resource programming. I'd like to create a plug-in
which in turns generate another plug-in project.
Luckily I have the Java Dev. Guide to Eclipse book which gives some hints on
creating a project programmaticaly. But then I still can't find any way to
create packages within the project. In the book, there are some codes, which
more or less look like this:
IFolder myFolder = myProject.getFolder("myPackage");
myFolder.create(true,true,null);
IJavaElement myPackageFragment = JavaCore.create(myFolder);
But this only gives me a folder, and not a package.
Can anyone please give me some hints on how I can create packages using the
workspace API? And also, on how to define the src/bin separation on the
project?
Thanks in advance!
Paul
Re: newbie on workspace resource programming [message #213203 is a reply to message #213164] |
Thu, 31 May 2007 21:28 |
--------------020303030902000909090905
Paul,
Below is a block of code that does much of what you are asking for.
public static IProject createEMFProject
(IPath javaSource,
URI projectLocationURI,
List<IProject> referencedProjects,
Monitor monitor,
int style,
List<?> pluginVariables)
IProgressMonitor progressMonitor =
BasicMonitor.toIProgressMonitor(monitor);
String projectName = javaSource.segment(0);
IProject project = null;
try
List<IClasspathEntry> classpathEntries = new
UniqueEList<IClasspathEntry>();
progressMonitor.beginTask("", 10);
progressMonitor.subTask
(CodeGenEcorePlugin.INSTANCE.getString
("_UI_CreatingEMFProject_message",
new Object [] { projectName, projectLocationURI !=
null ? projectLocationURI.toString() : projectName }));
IWorkspace workspace = ResourcesPlugin.getWorkspace();
project = workspace.getRoot().getProject(projectName);
// Clean up any old project information.
if (!project.exists())
URI location = projectLocationURI;
if (location == null)
location =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).toOSString());
location = location.appendSegment(".project");
File projectFile = new File(location.toString());
if (projectFile.exists())
projectFile.renameTo(new File(location.toString() +
".old"));
IJavaProject javaProject = JavaCore.create(project);
IProjectDescription projectDescription = null;
ResourcesPlugin.getWorkspace().newProjectDescription(project Name);
if (projectLocationURI != null)
projectDescription.setLocationURI(new
java.net.URI(projectLocationURI.toString()));
project.create(projectDescription, new
SubProgressMonitor(progressMonitor, 1));
else
projectDescription = project.getDescription();
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath()));
boolean isInitiallyEmpty = classpathEntries.isEmpty();
if (referencedProjects.size() != 0 && (style &
(EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) == 0)
projectDescription.setReferencedProjects
(referencedProjects.toArray(new
IProject[referencedProjects.size()]));
for (IProject referencedProject : referencedProjects)
IClasspathEntry referencedProjectClasspathEntry =
JavaCore.newProjectEntry(referencedProject.getFullPath());
classpathEntries.add(referencedProjectClasspathEntry);
String [] natureIds = projectDescription.getNatureIds();
if (natureIds == null)
natureIds = new String [] { JavaCore.NATURE_ID };
else
boolean hasJavaNature = false;
boolean hasPDENature = false;
for (int i = 0; i < natureIds.length; ++i)
if (JavaCore.NATURE_ID.equals(natureIds[i]))
hasJavaNature = true;
if ("org.eclipse.pde.PluginNature".equals(natureIds[i]))
hasPDENature = true;
if (!hasJavaNature)
String [] oldNatureIds = natureIds;
natureIds = new String [oldNatureIds.length + 1];
System.arraycopy(oldNatureIds, 0, natureIds, 0,
oldNatureIds.length);
natureIds[oldNatureIds.length] = JavaCore.NATURE_ID;
if (!hasPDENature)
"org.eclipse.pde.PluginNature";
projectDescription.setNatureIds(natureIds);
ICommand [] builders = projectDescription.getBuildSpec();
if (builders == null)
builders = new ICommand [0];
boolean hasManifestBuilder = false;
boolean hasSchemaBuilder = false;
for (int i = 0; i < builders.length; ++i)
if
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName()))
hasManifestBuilder = true;
if
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName()))
hasSchemaBuilder = true;
if (!hasManifestBuilder)
ICommand [] oldBuilders = builders;
builders = new ICommand [oldBuilders.length + 1];
System.arraycopy(oldBuilders, 0, builders, 0,
oldBuilders.length);
builders[oldBuilders.length] =
projectDescription.newCommand();
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuilder ");
if (!hasSchemaBuilder)
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilder ");
projectDescription.setBuildSpec(builders);
project.open(new SubProgressMonitor(progressMonitor, 1));
project.setDescription(projectDescription, new
IContainer sourceContainer = project;
if (javaSource.segmentCount() > 1)
sourceContainer =
project.getFolder(javaSource.removeFirstSegments(1).makeAbso lute());
if (!sourceContainer.exists())
((IFolder)sourceContainer).create(false, true, new
if (isInitiallyEmpty)
IClasspathEntry sourceClasspathEntry =
JavaCore.newSourceEntry(javaSource);
for (Iterator<IClasspathEntry> i =
classpathEntries.iterator(); i.hasNext(); )
IClasspathEntry classpathEntry = i.next();
if (classpathEntry.getPath().isPrefixOf(javaSource))
i.remove();
classpathEntries.add(0, sourceClasspathEntry);
IClasspathEntry jreClasspathEntry =
JavaCore.newVariableEntry
(new Path(JavaRuntime.JRELIB_VARIABLE), new
Path(JavaRuntime.JRESRC_VARIABLE), new
Path(JavaRuntime.JRESRCROOT_VARIABLE));
if
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th()))
i.remove();
String jreContainer = JavaRuntime.JRE_CONTAINER;
String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);
if ("1.5".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";
else if ("1.6".equals(complianceLevel))
jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";
classpathEntries.add(JavaCore.newContainerEntry(new
Path(jreContainer)));
if ((style & EMF_EMPTY_PROJECT_STYLE) == 0)
if ((style & EMF_PLUGIN_PROJECT_STYLE) != 0)
Path("org.eclipse.pde.core.requiredPlugins")));
// Remove variables since the plugin.xml should
provide the complete path information.
if (classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_VARIABLE &&
!JavaRuntime.JRELIB_VARIABLE.equals(classpathEntry.getPath() .toString())
IClasspathEntry.CPE_PROJECT)
i.remove();
else
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries ,
"ECLIPSE_CORE_RUNTIME", "org.eclipse.core.runtime");
"ECLIPSE_CORE_RESOURCES", "org.eclipse.core.resources");
"EMF_COMMON", "org.eclipse.emf.common");
"EMF_ECORE", "org.eclipse.emf.ecore");
if ((style & EMF_XML_PROJECT_STYLE) != 0)
"EMF_ECORE_XMI", "org.eclipse.emf.ecore.xmi");
if ((style & EMF_MODEL_PROJECT_STYLE) == 0)
"EMF_EDIT", "org.eclipse.emf.edit");
if ((style & EMF_EDIT_PROJECT_STYLE) == 0)
"ECLIPSE_SWT", "org.eclipse.swt");
"ECLIPSE_JFACE", "org.eclipse.jface");
"ECLIPSE_UI_VIEWS", "org.eclipse.ui.views");
"ECLIPSE_UI_EDITORS", "org.eclipse.ui.editors");
"ECLIPSE_UI_IDE", "org.eclipse.ui.ide");
"ECLIPSE_UI_WORKBENCH", "org.eclipse.ui.workbench");
"EMF_COMMON_UI", "org.eclipse.emf.common.ui");
"EMF_EDIT_UI", "org.eclipse.emf.edit.ui");
if ((style & EMF_XML_PROJECT_STYLE) == 0)
if ((style & EMF_TESTS_PROJECT_STYLE) != 0)
"JUNIT", "org.junit");
if (pluginVariables != null)
for (Iterator<?> i = pluginVariables.iterator();
i.hasNext(); )
Object variable = i.next();
if (variable instanceof IClasspathEntry)
classpathEntries.add((IClasspathEntry)variable);
else if (variable instanceof String)
String pluginVariable = (String)variable;
String name;
String id;
int index = pluginVariable.indexOf("=");
if (index == -1)
name =
pluginVariable.replace('.','_').toUpperCase();
id = pluginVariable;
else
name = pluginVariable.substring(0, index);
id = pluginVariable.substring(index + 1);
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , name, id);
javaProject.setRawClasspath
(classpathEntries.toArray(new
IClasspathEntry[classpathEntries.size()]),
javaProject.setOutputLocation(new Path("/" +
javaSource.segment(0) + "/bin"), new
catch (Exception exception)
exception.printStackTrace();
CodeGenEcorePlugin.INSTANCE.log(exception);
finally
progressMonitor.done();
return project;
Paul Sentosa wrote:
> Hi everyone,
> project?
> Thanks in advance!
> Regards
> Paul
<html>
<head>
</head>
Paul,<br>
<br>
Below is a block of code that does much of what you are asking for.<br>
<br>
<blockquote><small> public static IProject createEMFProject</small><br>
<small> (IPath javaSource,</small><br>
<small> URI projectLocationURI,</small><br>
<small> List<IProject> referencedProjects,</small><br>
<small> Monitor monitor,</small><br>
<small> int style,</small><br>
<small> List<?> pluginVariables)</small><br>
<small> {</small><br>
<small> IProgressMonitor progressMonitor =
BasicMonitor.toIProgressMonitor(monitor);</small><br>
<small> String projectName = javaSource.segment(0);</small><br>
<small> IProject project = null;</small><br>
<small> try</small><br>
<small> List<IClasspathEntry> classpathEntries = new
UniqueEList<IClasspathEntry>();</small><br>
<small> </small><br>
<small> progressMonitor.beginTask("", 10);</small><br>
<small> progressMonitor.subTask</small><br>
<small> (CodeGenEcorePlugin.INSTANCE.getString</small><br>
<small> ("_UI_CreatingEMFProject_message", </small><br>
<small> new Object [] { projectName, projectLocationURI
!= null ? projectLocationURI.toString() : projectName }));</small><br>
<small> IWorkspace workspace = ResourcesPlugin.getWorkspace();</small><br>
<small> project = workspace.getRoot().getProject(projectName);</small><br>
<small> // Clean up any old project information.</small><br>
<small> //</small><br>
<small> if (!project.exists())</small><br>
<small> URI location = projectLocationURI;</small><br>
<small> if (location == null)</small><br>
<small> location =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).toOSString()); </small><br>
<small> }</small><br>
<small> location = location.appendSegment(".project");</small><br>
<small> File projectFile = new File(location.toString());</small><br>
<small> if (projectFile.exists())</small><br>
<small> projectFile.renameTo(new File(location.toString()
+ ".old"));</small><br>
<small> IJavaProject javaProject = JavaCore.create(project);</small><br>
<small> IProjectDescription projectDescription = null;</small><br>
<small> projectDescription =
ResourcesPlugin.getWorkspace().newProjectDescription(project Name); </small><br>
<small> if (projectLocationURI != null)</small><br>
<small> projectDescription.setLocationURI(new
java.net.URI(projectLocationURI.toString()));</small><br>
<small> project.create(projectDescription, new
SubProgressMonitor(progressMonitor, 1));</small><br>
<small> else </small><br>
<small> projectDescription = project.getDescription();</small><br>
<small>
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath())); </small><br>
<small> boolean isInitiallyEmpty = classpathEntries.isEmpty();</small><br>
<small> if (referencedProjects.size() != 0 && (style
& (EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) == 0)</small><br>
<small> projectDescription.setReferencedProjects</small><br>
<small> (referencedProjects.toArray(new
IProject[referencedProjects.size()]));</small><br>
<small> for (IProject referencedProject :
referencedProjects)</small><br>
<small> IClasspathEntry referencedProjectClasspathEntry
= JavaCore.newProjectEntry(referencedProject.getFullPath());</small ><br>
<small>
classpathEntries.add(referencedProjectClasspathEntry);</small ><br>
<small> String [] natureIds =
projectDescription.getNatureIds();</small><br>
<small> if (natureIds == null)</small><br>
<small> natureIds = new String [] { JavaCore.NATURE_ID };</small><br>
<small> else</small><br>
<small> boolean hasJavaNature = false;</small><br>
<small> boolean hasPDENature = false;</small><br>
<small> for (int i = 0; i < natureIds.length; ++i)</small><br>
<small> if (JavaCore.NATURE_ID.equals(natureIds[i]))</small><br>
<small> hasJavaNature = true;</small><br>
<small> if
("org.eclipse.pde.PluginNature".equals(natureIds[i]))</small ><br>
<small> hasPDENature = true;</small><br>
<small> if (!hasJavaNature)</small><br>
<small> String [] oldNatureIds = natureIds;</small><br>
<small> natureIds = new String [oldNatureIds.length + 1];</small><br>
<small> System.arraycopy(oldNatureIds, 0, natureIds, 0,
oldNatureIds.length);</small><br>
<small> natureIds[oldNatureIds.length] =
JavaCore.NATURE_ID;</small><br>
<small> if (!hasPDENature)</small><br>
"org.eclipse.pde.PluginNature";</small><br>
<small> projectDescription.setNatureIds(natureIds);</small><br>
<small> ICommand [] builders =
projectDescription.getBuildSpec();</small><br>
<small> if (builders == null)</small><br>
<small> builders = new ICommand [0];</small><br>
<small> boolean hasManifestBuilder = false;</small><br>
<small> boolean hasSchemaBuilder = false;</small><br>
<small> for (int i = 0; i < builders.length; ++i)</small><br>
<small> if
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName())) </small><br>
<small> hasManifestBuilder = true;</small><br>
<small> if
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName())) </small><br>
<small> hasSchemaBuilder = true;</small><br>
<small> if (!hasManifestBuilder)</small><br>
<small> ICommand [] oldBuilders = builders;</small><br>
<small> builders = new ICommand [oldBuilders.length + 1];</small><br>
<small> System.arraycopy(oldBuilders, 0, builders, 0,
oldBuilders.length);</small><br>
<small> builders[oldBuilders.length] =
projectDescription.newCommand();</small><br>
<small>
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuilder ");</small><br>
<small> if (!hasSchemaBuilder)</small><br>
<small>
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilder ");</small><br>
<small> projectDescription.setBuildSpec(builders);</small><br>
<small> project.open(new SubProgressMonitor(progressMonitor,
1));</small><br>
<small> project.setDescription(projectDescription, new
<small> IContainer sourceContainer = project;</small><br>
<small> if (javaSource.segmentCount() > 1)</small><br>
<small> sourceContainer =
project.getFolder(javaSource.removeFirstSegments(1).makeAbso lute()); </small><br>
<small> if (!sourceContainer.exists())</small><br>
<small> ((IFolder)sourceContainer).create(false, true,
new SubProgressMonitor(progressMonitor, 1));</small><br>
<small> if (isInitiallyEmpty)</small><br>
<small> IClasspathEntry sourceClasspathEntry = </small><br>
<small> JavaCore.newSourceEntry(javaSource);</small><br>
<small> for (Iterator<IClasspathEntry> i =
classpathEntries.iterator(); i.hasNext(); )</small><br>
<small> IClasspathEntry classpathEntry = i.next();</small><br>
<small> if
(classpathEntry.getPath().isPrefixOf(javaSource))</small><br >
<small> i.remove();</small><br>
<small> classpathEntries.add(0, sourceClasspathEntry);</small><br>
<small> IClasspathEntry jreClasspathEntry =</small><br>
<small> JavaCore.newVariableEntry</small><br>
<small> (new Path(JavaRuntime.JRELIB_VARIABLE), new
Path(JavaRuntime.JRESRCROOT_VARIABLE));</small><br>
<small> if
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th())) </small><br>
<small> String jreContainer = JavaRuntime.JRE_CONTAINER;</small><br>
<small> String complianceLevel =
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);</small ><br>
<small> if ("1.5".equals(complianceLevel))</small><br>
<small> jreContainer +=
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";</small><br>
<small> else if ("1.6".equals(complianceLevel))</small><br>
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";</small><br>
<small>
Path(jreContainer)));</small><br>
<small> if ((style & EMF_EMPTY_PROJECT_STYLE) == 0)</small><br>
<small> if ((style & EMF_PLUGIN_PROJECT_STYLE) != 0)</small><br>
<small>
Path("org.eclipse.pde.core.requiredPlugins")));</small><br >
<small> // Remove variables since the plugin.xml should
provide the complete path information.</small><br>
<small> if (classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_VARIABLE && </small><br>
<small>
||</small><br>
<small> classpathEntry.getEntryKind() ==
IClasspathEntry.CPE_PROJECT)</small><br>
<small>
"ECLIPSE_CORE_RUNTIME", "org.eclipse.core.runtime");</small><br>
<small>
"ECLIPSE_CORE_RESOURCES", "org.eclipse.core.resources");</small><br>
<small>
"EMF_COMMON", "org.eclipse.emf.common");</small><br>
<small>
"EMF_ECORE", "org.eclipse.emf.ecore");</small><br>
<small> if ((style & EMF_XML_PROJECT_STYLE) != 0)</small><br>
<small>
"EMF_ECORE_XMI", "org.eclipse.emf.ecore.xmi");</small><br>
<small> if ((style & EMF_MODEL_PROJECT_STYLE) == 0)</small><br>
<small>
"EMF_EDIT", "org.eclipse.emf.edit");</small><br>
<small> if ((style & EMF_EDIT_PROJECT_STYLE) == 0)</small><br>
<small>
"ECLIPSE_SWT", "org.eclipse.swt");</small><br>
<small>
"ECLIPSE_JFACE", "org.eclipse.jface");</small><br>
<small>
"ECLIPSE_UI_VIEWS", "org.eclipse.ui.views");</small><br>
<small>
"ECLIPSE_UI_EDITORS", "org.eclipse.ui.editors");</small><br>
<small>
"ECLIPSE_UI_IDE", "org.eclipse.ui.ide");</small><br>
<small>
"ECLIPSE_UI_WORKBENCH", "org.eclipse.ui.workbench");</small><br>
<small>
Re: newbie on workspace resource programming [message #213419 is a reply to message #213203] |
Sat, 02 June 2007 14:36 |
------=_NextPart_000_0013_01C7A534.28A80190
charset="iso-8859-1"
Hi Ed,
thanks for the code and sorry for the late reply.
I already had a look at the code when you told me last time about this =
method. But somehow I overlook some important parts so I couldn't get =
the result I wanted.
But after I get the very same answer from you, I gave it a try once more =
and now it works.
Thanks again and sorry for the double post. Hope you don't get bored =
with this kind of newbie question.
Have a nice weekend!
Paul
"Ed Merks" <merks@ca.ibm.com> schrieb im Newsbeitrag =
news:f3nels$b99$1@build.eclipse.org...
Paul,
(IPath javaSource,
Monitor monitor,
int style,
IProgressMonitor progressMonitor =3D =
String projectName =3D javaSource.segment(0);
IProject project =3D null;
try
List<IClasspathEntry> classpathEntries =3D new =
=20
("_UI_CreatingEMFProject_message",=20
new Object [] { projectName, projectLocationURI !=3D =
IWorkspace workspace =3D ResourcesPlugin.getWorkspace();
project =3D workspace.getRoot().getProject(projectName);
=20
URI location =3D projectLocationURI;
if (location =3D=3D null)
location =3D =
URI.createFileURI(workspace.getRoot().getLocation().append(p rojectName).t=
oOSString());
location =3D location.appendSegment(".project");
File projectFile =3D new File(location.toString());
projectFile.renameTo(new File(location.toString() + =
".old"));
=20
IJavaProject javaProject =3D JavaCore.create(project);
IProjectDescription projectDescription =3D null;
projectDescription =3D =
if (projectLocationURI !=3D null)
projectDescription.setLocationURI(new =
project.create(projectDescription, new =
else=20
projectDescription =3D project.getDescription();
=20
boolean isInitiallyEmpty =3D classpathEntries.isEmpty();
=20
if (referencedProjects.size() !=3D 0 && (style & =
(EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) =3D=3D 0)
(referencedProjects.toArray(new =
IClasspathEntry referencedProjectClasspathEntry =3D =
=20
String [] natureIds =3D projectDescription.getNatureIds();
if (natureIds =3D=3D null)
natureIds =3D new String [] { JavaCore.NATURE_ID };
else
boolean hasJavaNature =3D false;
boolean hasPDENature =3D false;
for (int i =3D 0; i < natureIds.length; ++i)
hasJavaNature =3D true;
if =
hasPDENature =3D true;
if (!hasJavaNature)
String [] oldNatureIds =3D natureIds;
natureIds =3D new String [oldNatureIds.length + 1];
System.arraycopy(oldNatureIds, 0, natureIds, 0, =
natureIds[oldNatureIds.length] =3D JavaCore.NATURE_ID;
if (!hasPDENature)
natureIds[oldNatureIds.length] =3D =
=20
ICommand [] builders =3D =
if (builders =3D=3D null)
builders =3D new ICommand [0];
boolean hasManifestBuilder =3D false;
boolean hasSchemaBuilder =3D false;
for (int i =3D 0; i < builders.length; ++i)
if =
hasManifestBuilder =3D true;
if =
hasSchemaBuilder =3D true;
ICommand [] oldBuilders =3D builders;
builders =3D new ICommand [oldBuilders.length + 1];
System.arraycopy(oldBuilders, 0, builders, 0, =
builders[oldBuilders.length] =3D =
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.ManifestBuil=
der");
builders[oldBuilders.length].setBuilderName("org.eclipse.pde.SchemaBuilde=
r");
=20
project.setDescription(projectDescription, new =
=20
IContainer sourceContainer =3D project;
sourceContainer =3D =
((IFolder)sourceContainer).create(false, true, new =
=20
IClasspathEntry sourceClasspathEntry =3D=20
for (Iterator<IClasspathEntry> i =3D =
IClasspathEntry classpathEntry =3D i.next();
i.remove();
=20
IClasspathEntry jreClasspathEntry =3D
(new Path(JavaRuntime.JRELIB_VARIABLE), new =
Path(JavaRuntime.JRESRC_VARIABLE), new =
if =
i.remove();
=20
String jreContainer =3D JavaRuntime.JRE_CONTAINER;
String complianceLevel =3D =
jreContainer +=3D =
jreContainer +=3D =
classpathEntries.add(JavaCore.newContainerEntry(new =
=20
if ((style & EMF_EMPTY_PROJECT_STYLE) =3D=3D 0)
if ((style & EMF_PLUGIN_PROJECT_STYLE) !=3D 0)
=20
// Remove variables since the plugin.xml should =
if (classpathEntry.getEntryKind() =3D=3D =
IClasspathEntry.CPE_VARIABLE &&=20
!JavaRuntime.JRELIB_VARIABLE.equals(classpathEntry.getPath() .toString()) =
i.remove();
else
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , =
=20
if ((style & EMF_XML_PROJECT_STYLE) !=3D 0)
=20
if ((style & EMF_MODEL_PROJECT_STYLE) =3D=3D 0)
=20
if ((style & EMF_EDIT_PROJECT_STYLE) =3D=3D 0)
if ((style & EMF_XML_PROJECT_STYLE) =3D=3D 0)
=20
if ((style & EMF_TESTS_PROJECT_STYLE) !=3D 0)
CodeGenUtil.EclipseUtil.addClasspathEntries(classpathEntries , "JUNIT", =
"org.junit");
=20
if (pluginVariables !=3D null)
for (Iterator<?> i =3D pluginVariables.iterator(); =
i.hasNext(); )
Object variable =3D i.next();
String pluginVariable =3D (String)variable;
String name;
String id;
int index =3D pluginVariable.indexOf("=3D");
if (index =3D=3D -1)
name =3D =
id =3D pluginVariable;
else
name =3D pluginVariable.substring(0, index);
id =3D pluginVariable.substring(index + 1);
=20
(classpathEntries.toArray(new =
=20
javaProject.setOutputLocation(new Path("/" + =
javaSource.segment(0) + "/bin"), new SubProgressMonitor(progressMonitor, =
1));
finally
=20
return project;
Paul Sentosa wrote:=20
Hi everyone,
I posted a similar question some times ago, but unfortunately I didn't =
get
Luckily I have the Java Dev. Guide to Eclipse book which gives some =
hints on
creating a project programmaticaly. But then I still can't find any way =
to
create packages within the project. In the book, there are some codes, =
which
IFolder myFolder =3D myProject.getFolder("myPackage");
IJavaElement myPackageFragment =3D JavaCore.create(myFolder);
Can anyone please give me some hints on how I can create packages using =
the
project?
Thanks in advance!
Paul
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1561" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>thanks for the code and sorry for the =
late=20
reply.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I already had a look at the code =
when you told=20
me last time about this method. But somehow I overlook some important =
parts so I=20
couldn't get the result I wanted.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>But after I get the very same answer =
from you, I=20
gave it a try once more and now it works.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks again and sorry for the double =
post. Hope=20
you don't get bored with this kind of newbie question.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice weekend!</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Regards</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
schrieb im Newsbeitrag <A=20
href=3D"news:f3nels$b99$1@build.eclipse.org">news:f3nels$b99$1@build.ecli=
pse.org</A>...</DIV>Paul,<BR><BR>Below=20
is a block of code that does much of what you are asking for.<BR><BR>
<BLOCKQUOTE><SMALL> public static IProject=20
createEMFProject</SMALL><BR><SMALL> =
(IPath=20
javaSource,</SMALL><BR><SMALL> =
URI=20
projectLocationURI,</SMALL><BR><SMALL>  =
;=20
List<IProject>=20
referencedProjects,</SMALL><BR><SMALL>  =
;=20
Monitor =
monitor,</SMALL><BR><SMALL> int=20
style,</SMALL><BR><SMALL> =
List<?>=20
pluginVariables)</SMALL><BR><SMALL> =20
{</SMALL><BR><SMALL> IProgressMonitor=20
progressMonitor =3D=20
BasicMonitor.toIProgressMonitor(monitor);</SMALL><BR><SMALL > &=
nbsp; =20
String projectName =3D=20
javaSource.segment(0);</SMALL><BR><SMALL> =20
IProject project =3D =
null;</SMALL><BR><SMALL> =20
try</SMALL><BR><SMALL> =20
{</SMALL><BR><SMALL> =20
List<IClasspathEntry> classpathEntries =3D new=20
UniqueEList<IClasspathEntry>();</SMALL><BR><SMALL > =20
progressMonitor.beginTask("",=20
10);</SMALL><BR><SMALL> =20
progressMonitor.subTask</SMALL><BR><SMALL> &=
nbsp; =20
(CodeGenEcorePlugin.INSTANCE.getString</SMALL><BR><SMALL> &nbs=
p; &nbs p; =20
=20
new Object [] { projectName, projectLocationURI !=3D null ?=20
projectLocationURI.toString() : projectName=20
}));</SMALL><BR><SMALL> =
IWorkspace=20
workspace =3D=20
ResourcesPlugin.getWorkspace();</SMALL><BR><SMALL>  =
; =20
project =3D=20
workspace.getRoot().getProject(projectName);</SMALL><BR><SMALL > =20
</SMALL><BR><SMALL> // =
Clean up=20
any old project=20
information.</SMALL><BR><SMALL> =
=20
//</SMALL><BR><SMALL> if=20
(!project.exists())</SMALL><BR><SMALL>  =
; =20
;=20
URI location =3D=20
projectLocationURI;</SMALL><BR><SMALL>  =
; =20
if (location =3D=3D=20
null)</SMALL><BR><SMALL> &=
nbsp;=20
; =20
location =3D=20
oOSString());</SMALL><BR><SMALL>  =
; =20
}</SMALL><BR><SMALL>  =
;=20
location =3D=20
location.appendSegment(".project");</SMALL><BR><SMALL> &=
nbsp; =20
File projectFile =3D new=20
File(location.toString());</SMALL><BR><SMALL> &nbs=
p; =20
if=20
(projectFile.exists())</SMALL><BR><SMALL> &n=
bsp; =20
; =20
projectFile.renameTo(new File(location.toString() +=20
".old"));</SMALL><BR><SMALL> &nb=
sp; =20
}</SMALL><BR><SMALL> =20
IJavaProject=20
javaProject =3D=20
JavaCore.create(project);</SMALL><BR><SMALL>  =
; =20
IProjectDescription projectDescription =3D=20
if=20
; =20
;=20
ResourcesPlugin.getWorkspace().newProjectDescription(project Name); </SMALL=
><BR><SMALL> =20
if (projectLocationURI !=3D=20
nbsp;=20
; =20
projectDescription.setLocationURI(new=20
java.net.URI(projectLocationURI.toString()));</SMALL><BR><SMALL > &nb=
sp; &nb sp; =20
;=20
SubProgressMonitor(progressMonitor,=20
1));</SMALL><BR><SMALL> =20
}</SMALL><BR><SMALL> else=20
;=20
project.getDescription();</SMALL><BR><SMALL>  =
; =20
classpathEntries.addAll(Arrays.asList(javaProject.getRawClas spath())); </S=
boolean=20
isInitiallyEmpty =3D =
classpathEntries.isEmpty();</SMALL><BR><SMALL> =20
;=20
if (referencedProjects.size() !=3D 0 && (style &=20
(EMF_PLUGIN_PROJECT_STYLE | EMF_EMPTY_PROJECT_STYLE)) =3D=3D=20
0)</SMALL><BR><SMALL> &nbs=
p;=20
; =20
projectDescription.setReferencedProjects</SMALL><BR><SMALL > &n=
bsp; &n bsp; =20
(referencedProjects.toArray(new=20
IProject[referencedProjects.size()]));</SMALL><BR><SMALL> &nbs=
p; &nbs p; =20
for (IProject referencedProject :=20
referencedProjects)</SMALL><BR><SMALL>  =
; =20
; =20
IClasspathEntry referencedProjectClasspathEntry =3D=20
JavaCore.newProjectEntry(referencedProject.getFullPath());</SMALL ><BR><SM=
ALL> &nb=
sp; =20
classpathEntries.add(referencedProjectClasspathEntry);</SMALL ><BR><SMALL>=
=20
;=20
=20
String [] natureIds =3D=20
projectDescription.getNatureIds();</SMALL><BR><SMALL> &n=
bsp; =20
if (natureIds =3D=3D=20
nbsp;=20
; =20
natureIds =3D new String [] { JavaCore.NATURE_ID=20
};</SMALL><BR><SMALL> &nbs=
p;=20
;=20
else</SMALL><BR><SMALL> &n=
bsp;=20
; =20
boolean hasJavaNature =3D=20
false;</SMALL><BR><SMALL> =
=20
boolean hasPDENature =3D=20
=20
for (int i =3D 0; i < natureIds.length;=20
++i)</SMALL><BR><SMALL> &n=
bsp; =20
; =20
if=20
(JavaCore.NATURE_ID.equals(natureIds[i]))</SMALL><BR><SMALL > &=
nbsp; & nbsp; =20
;   ;=20
true;</SMALL><BR><SMALL> &=
nbsp; =20
; =20
if=20
("org.eclipse.pde.PluginNature".equals(natureIds[i]))</SMALL ><BR><SMALL>&=
nbsp; & nbsp; & n=
bsp;=20
;   ;=20
hasPDENature =3D=20
nbsp; =20
; =20
; =20
if=20
(!hasJavaNature)</SMALL><BR><SMALL> &n=
bsp; =20
; =20
String [] oldNatureIds =3D=20
natureIds;</SMALL><BR><SMALL> &n=
bsp; =20
natureIds =3D new String [oldNatureIds.length +=20
1];</SMALL><BR><SMALL> &nb=
sp; =20
System.arraycopy(oldNatureIds, 0, natureIds, 0,=20
oldNatureIds.length);</SMALL><BR><SMALL> &nb=
sp; &nb sp; =20
natureIds[oldNatureIds.length] =3D=20
JavaCore.NATURE_ID;</SMALL><BR><SMALL>  =
; =20
; =20
if=20
(!hasPDENature)</SMALL><BR><SMALL> &nb=
sp; =20
; =20
bsp; =20
sp; =20
sp; &nb sp; =20
"org.eclipse.pde.PluginNature";</SMALL><BR><SMALL>  =
;   ; =20
;=20
;=20
projectDescription.setNatureIds(natureIds);</SMALL><BR><SMALL > =
=20
ICommand [] builders =3D=20
projectDescription.getBuildSpec();</SMALL><BR><SMALL> &n=
bsp; =20
if (builders =3D=3D=20
nbsp;=20
; =20
builders =3D new ICommand=20
[0];</SMALL><BR><SMALL> &n=
bsp;=20
;=20
boolean hasManifestBuilder =3D=20
=20
boolean hasSchemaBuilder =3D=20
=20
for (int i =3D 0; i < builders.length;=20
bsp;=20
; =20
if=20
("org.eclipse.pde.ManifestBuilder".equals(builders[i].getBuilderName())) <=
nbsp; =20
; =20
nbsp; =20
; =20
if=20
("org.eclipse.pde.SchemaBuilder".equals(builders[i].getBuilderName())) </S=
sp; =20
; =20
nbsp; =20
;=20
;=20
if=20
(!hasManifestBuilder)</SMALL><BR><SMALL> &nb=
sp; =20
; =20
ICommand [] oldBuilders =3D=20
builders;</SMALL><BR><SMALL> &nb=
sp; =20
builders =3D new ICommand [oldBuilders.length +=20
sp; =20
System.arraycopy(oldBuilders, 0, builders, 0,=20
oldBuilders.length);</SMALL><BR><SMALL> &nbs=
p; =20
builders[oldBuilders.length] =3D=20
projectDescription.newCommand();</SMALL><BR><SMALL> &nbs=
p; &nbs p; =20
der");</SMALL><BR><SMALL> =
=20
;=20
if=20
(!hasSchemaBuilder)</SMALL><BR><SMALL>  =
; =20
; =20
sp; =20
sp; =20
p; =20
p; &nbs p; =20
r");</SMALL><BR><SMALL> &n=
bsp;=20
;=20
projectDescription.setBuildSpec(builders);</SMALL><BR><SMALL > =20
=20
project.open(new SubProgressMonitor(progressMonitor,=20
1));</SMALL><BR><SMALL> &n=
bsp;=20
project.setDescription(projectDescription, new=20
SubProgressMonitor(progressMonitor, 1));</SMALL><BR><SMALL> =20
=20
IContainer sourceContainer =3D=20
project;</SMALL><BR><SMALL> &nbs=
p; =20
if (javaSource.segmentCount() >=20
1)</SMALL><BR><SMALL> &nbs=
p;=20
; =20
project.getFolder(javaSource.removeFirstSegments(1).makeAbso lute()); </SMA=
LL><BR><SMALL>  =
; =20
if=20
(!sourceContainer.exists())</SMALL><BR><SMALL> &nb=
sp; &nb sp;=20
; =20
((IFolder)sourceContainer).create(false, true, new=20
bsp; =20
;=20
if=20
(isInitiallyEmpty)</SMALL><BR><SMALL> =
=20
; =20
=20
JavaCore.newSourceEntry(javaSource);</SMALL><BR><SMALL> =
=20
classpathEntries.iterator();=20
i.hasNext();=20
; =20
; =20
IClasspathEntry classpathEntry =3D=20
i.next();</SMALL><BR><SMALL> &nb=
sp; =20
if=20
(classpathEntry.getPath().isPrefixOf(javaSource))</SMALL><BR ><SMALL> =
=20
;   ;=20
i.remove();</SMALL><BR><SMALL> &=
nbsp; =20
; =20
; =20
classpathEntries.add(0, =
sourceClasspathEntry);</SMALL><BR><SMALL> =20
=20
IClasspathEntry jreClasspathEntry=20
=3D</SMALL><BR><SMALL> &nb=
sp; =20
JavaCore.newVariableEntry</SMALL><BR><SMALL>  =
;   ; =20
(new Path(JavaRuntime.JRELIB_VARIABLE), new=20
Path(JavaRuntime.JRESRC_VARIABLE), new=20
Path(JavaRuntime.JRESRCROOT_VARIABLE));</SMALL><BR><SMALL > &nb=
sp; &nb sp; =20
i.hasNext();=20
; =20
; =20
sp; =20
if=20
(classpathEntry.getPath().isPrefixOf(jreClasspathEntry.getPa th())) </SMALL=
><BR><SMALL> &=
nbsp; =20
;   ;=20
nbsp; =20
; =20
=20
String jreContainer =3D=20
JavaRuntime.JRE_CONTAINER;</SMALL><BR><SMALL> &nbs=
p; &nbs p;=20
String complianceLevel =3D=20
CodeGenUtil.EclipseUtil.getJavaComplianceLevel(project);</SMALL ><BR><SMAL=
L> =20
if=20
("1.5".equals(complianceLevel))</SMALL><BR><SMALL>  =
;   ; =20
; =20
jreContainer +=3D=20
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J 2SE-1.5 ";</S=
sp; =20
; =20
else if=20
("1.6".equals(complianceLevel))</SMALL><BR><SMALL>  =
;   ; =20
; =20
" /org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/J avaSE-1.6 ";<=
nbsp; =20
; =20
classpathEntries.add(JavaCore.newContainerEntry(new=20
Path(jreContainer)));</SMALL><BR><SMALL> &nb=
sp; =20
if=20
((style & EMF_EMPTY_PROJECT_STYLE) =3D=3D=20
p;=20
; =20
if ((style & EMF_PLUGIN_PROJECT_STYLE) !=3D=20
p; =20
; =20
Path("org.eclipse.pde.core.requiredPlugins")));</SMALL><BR ><SMALL> =
=20
// Remove variables since the plugin.xml should provide the complete =
path=20
=20
//</SMALL><BR><SMALL> &nbs=
p; =20
i.hasNext();=20
; =20<
Current Time: Wed Sep 25 09:57:33 GMT 2024
Powered by FUDForum. Page generated in 0.09280 seconds
