Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Can't debug with JRuby
Can't debug with JRuby [message #20670] Fri, 08 February 2008 10:43 Go to next message
Hi, I cannot debug with JRuby. I'm using DLTK S-0.10RC1-200802011059 with
Jruby 1.1RC1 in Eclipse 3.3. I've selected jruby.bat as my interpreter
and scripts run fine. When I try to debug using either basic or fast ruby
debugging engines, I get a problem occured box with the following error
details: Debugging Engine not connected to IDE
Does anyone know how to fix this? I couldn't see any obvious args in the
preferences so not sure where to go from here. There is no additional
info in the workspace log file.
Any help greatly appreciated!
Re: Can't debug with JRuby [message #20723 is a reply to message #20670] Thu, 14 February 2008 08:41 Go to previous message
Fast debugger is working only with Generic Ruby interpreter, so it is
normal that it is failed with JRuby. In my case Basic debugger is
working fine with JRuby 1.1RC1. Please check debugger log file for
errors. You can find it in "{workspace
root}/.metadata/.plugins/org.eclipse.dltk.ruby.basicdebugger /debug_log.txt "
Timur
> with Jruby 1.1RC1 in Eclipse 3.3. I've selected jruby.bat as my
> interpreter and scripts run fine. When I try to debug using either
> basic or fast ruby debugging engines, I get a problem occured box with
> the following error details: Debugging Engine not connected to IDE
> the preferences so not sure where to go from here. There is no
> additional info in the workspace log file.
Previous Topic:Two questions - interpreter library configuration and NewSourceModulePage
Next Topic:Bug in Eclipse with XOTcl
Current Time: Sun Aug 31 14:37:59 EDT 2025
Powered by FUDForum. Page generated in 0.04162 seconds
