Home » Newcomers » Newcomers » Tasks Tags
Tasks Tags [message #212703] Tue, 29 May 2007 11:35
Originally posted by: ericaramsey1.gmail.com
Hello, I do I setup Tasks to be Case Sensitive? I ask because I have
" javax.microedition.pim.ToDoList.read,javax.microedition.pim. ToDoList. ", in
my library includes in "build.xml" file, showing up as a task in my Tasks
window as TODO tasks. I went to "project properties"->"Java Compiler"->"Task
Tags" and set it to case sensitive. Then I went to "preferences"->"Java
Compiler"->"Task Tags" and set it to case sensitive. But they are still
showing in Tasks window. There is also a "project properties"->"Task Tags"
but I can't change the case sensitivity and the same thing for
"preferences"->"Task Tags". I don't want lower case task tags in ".xml",
".java fil"e or in any file that is in the project because I don't define
any lower case Task tags and if they are lower case then it just so happen
to be a Task tag.
What should I do?
Previous Topic:Can't Run a Class With Firefox Running
Next Topic:Where to find old eclipse 3.1?
Current Time: Sun Nov 09 05:39:48 EST 2025
Powered by FUDForum. Page generated in 0.09247 seconds
