Home » Language IDEs » Java Development Tools (JDT) » getDictionaryLocation
getDictionaryLocation [message #212628] Mon, 15 August 2005 19:21 Go to next message
Originally posted by: ppagee.yahoo.com
Hi!
Can anybody tell me what would this method return on standard Eclipse
3.1 setup:
public static URL getDictionaryLocation() throws MalformedURLException {
final JavaPlugin plugin= JavaPlugin.getDefault();
if (plugin != null)
return plugin.getBundle().getEntry("/" +
DICTIONARY_LOCATION); //$NON-NLS-1$
return null;
Where DICTIONARY_LOCATION is "dictionaries/".
Mike
Re: getDictionaryLocation [message #212652 is a reply to message #212628] Tue, 16 August 2005 04:31 Go to previous messageGo to next message
That depends on whether you have imported the JDT UI plugin into your
workspace and are running in self-hosting mode.
If you have just installed Eclipse and are calling this method from one of
your plugins, this method returns a URL to a JAR entry (the JDT UI plugin is
a single JAR). If you have imported JDT UI into your workspace and are
running an Eclipse Application, this will give you a file URL to the
"dictionaries" directory in the org.eclipse.jdt.ui plugin project.
Cheers
Tobias
"Mike Mimic" <ppagee@yahoo.com> wrote in message
news:ddr855$mvm$1@news.eclipse.org...
> Hi!
> 3.1 setup:
> if (plugin != null)
> return null;
> Mike
Re: getDictionaryLocation [message #212659 is a reply to message #212652] Tue, 16 August 2005 07:04 Go to previous messageGo to next message
Hi!
Thanks for the reply.
This method is called from Eclipse JDT itself (or I at least think so).
I would like to discover where does Eclipse spelling looks for the
dictionaries. So I looked into the source code and found in:
org.eclipse.jdt.internal.ui.text.spelling.SpellCheckEngine
class that it looks into the directory returned by getDictionaryLocation
for them.
So then it is returning the URL to a JAR? But where does
DICTIONARY_LOCATION then come into account?
Mike
Re: getDictionaryLocation [message #212807 is a reply to message #212659] Thu, 18 August 2005 07:12 Go to previous messageGo to next message
I have to correct myself. Obviously the method does not return a URL to a
JAR entry, but to the directory where the JAR'ed plugin is located. So the
same is true as with the self-hosting case: Just put your dictionary into a
subdirectory "dictionaries" of the plugin directory. Remember to use the
correct format for the dictionary name (language_COUNTRY.dictionary)
Cheers
Tobias
news:ddshbd$ud2$1@news.eclipse.org...
> Hi!
>> of your plugins, this method returns a URL to a JAR entry (the JDT UI
>> plugin is a single JAR). If you have imported JDT UI into your workspace
>> and are running an Eclipse Application, this will give you a file URL to
>> the "dictionaries" directory in the org.eclipse.jdt.ui plugin project.
> for them.
> Mike
Re: getDictionaryLocation [message #212897 is a reply to message #212807] Thu, 18 August 2005 19:13 Go to previous messageGo to next message
Hi!
I have tried but it does not work. I have created "dictionaries"
directory in the "plugins" directory. And there I created a list of
words with "en_UK.dictionary" filename. Eclipse just does not recognize
it.
Mike
Re: getDictionaryLocation [message #212951 is a reply to message #212897] Fri, 19 August 2005 09:08 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Mike Mimic wrote:
> Hi!
>> to a JAR entry, but to the directory where the JAR'ed plugin is
>> located. So the same is true as with the self-hosting case: Just put
>> your dictionary into a subdirectory "dictionaries" of the plugin
>> directory. Remember to use the correct format for the dictionary name
> it.
You must not add it to the plug-ins directory but to the
'org.eclipse.jdt.ui' plug-in because that's the one who contributes the
spelling engine (Eclipse allows more than one engine).
HTH
Dani
> Mike
Re: getDictionaryLocation [message #213016 is a reply to message #212951] Sun, 21 August 2005 12:24 Go to previous messageGo to next message
Hi!
I have added the "dictionaries" directory to the jar and it still does
not find it. I tryed with creating "org.eclipse.jdt.ui_3.1.0" directory
in "plugins" and put it there but with no luck.
I will probably wait until Eclipse ships the dictionary by itself.
Mike
Re: getDictionaryLocation [message #213069 is a reply to message #213016] Mon, 22 August 2005 09:57 Go to previous message
Mike Mimic wrote:
> Hi!
>> the spelling engine (Eclipse allows more than one engine).
> directory in "plugins" and put it there but with no luck.
This works for me using R3.1. Make sure you use all lower case for the
file, e.g. dictionaries/de_ch.dictionary.
Note: The easiest for you is to simply assign your dictionary as user
dictionary.
Dani
> Mike
Previous Topic:Installing platform dictionary
Next Topic:How to obtain source folders for a project
Current Time: Mon Jul 14 09:24:24 EDT 2025
Powered by FUDForum. Page generated in 0.31902 seconds
