Home » Archived » M2M (model-to-model transformation) » [ATL]Lazy rules questions
[ATL]Lazy rules questions [message #20611] Mon, 05 March 2007 14:49
Originally posted by: lw_mailme_00.yahoo.com
when experimenting with lazy rules I noticed that it is possible to
define several lazy rules in an ATL module that have the same name and
identical source patterns. The compiler doesn't complain, and at
run-time only one of the rules is executed. (The one that is defined
last in the source file) What is the intended behavior in such a case.
I tried to add guards to the source patterns in the lazy rules. Again,
the compiler accepts this, but at runtime they are ignored, i.e., the
rule gets executed even if the guard is false. Is this the intended
behavior?
Using ATL 2006 I tried to create a lazy rule that extends another which
caused the compiler to die with an exception. Is extension of lazy rules
allowed?
Lutz
Previous Topic:[ATL]ATL 2006 Questions
Next Topic:[ATL]Launching ATL programmatically problem
Current Time: Sun Aug 31 18:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.02482 seconds
