Problem installing Glassfish server adapter to Eclipse R3.4M6/WTP 3.0M6 [message #212417] |
Wed, 16 April 2008 15:28  |
Originally posted by: jmordax.terra.es
It shows an error when trying to install:
The site is not updateable: file:/D:/eclipse-SDK-3.4M6a-win32/.
Following is the complete error message from Product Configuration:
Current configuration contains errors that are not corrected by the
requested operation and more errors would be introduced. See details for
more information.
----- Current configuration problems -----
WST Web Services Core (3.0.0.v200804012222-7D7CECWEB7sQS8R9bGheoE)
requires plug-in "org.eclipse.xsd (2.3.0)", or compatible.
WST Web Services UI (3.0.0.v200804012222-7B2EDkBqiaacbumnZouVIjJuS4fp)
requires plug-in "org.eclipse.xsd (2.2.0)", or compatible.
JST Enterprise UI (3.0.0.v200804020355-7Y7BFCwEPOwQJGL-ANhrqTNfSqjT)
Eclipse XML Editors and Tools
(3.0.0.v200804020355-7C2EC_Cnfcx2hmpktkvWZdz0j9s_) requires plug-in
"org.eclipse.xsd.edit (2.2.0)", or compatible.
WST XML Core (3.0.0.v200804020355-7A7NEFGE7QYGHMHkHrP9TW) requires
Java Persistence API Tools (2.0.0.v200802270000-7938aCYQCD4CZHcCCCD)
requires plug-in "org.eclipse.xsd".
----- Configuration problems after the operation -----
GlassFish Java EE 5 Server (1.0.2) The site is not updateable:
Any idea about the origin of this problem?
Thanks in advance,
Chemi.
FUDForum. Page generated in 0.05195 seconds
