Home » Eclipse Projects » SWTBot » can I both use and modify swtbot
can I both use and modify swtbot [message #20591] Wed, 11 February 2009 08:29 Go to next message
I'm not used to eclipse very much.
Is a there a way so that I can both use and modify swtbot?
For instance, while developping my code to test an RCP app, I'd like to be
able to add a method to one of the provided classes (like
SWTBotTable.class)
I installed swtbot via update manager, but it is therfore read-only, isn't
it?
Could someone guide me to configure eclipse this way?
thanks for your help
Marc
Re: can I both use and modify swtbot [message #23671 is a reply to message #20591] Mon, 23 February 2009 05:56 Go to previous message
--------------010806070608040703040507
Content-Type: text/plain; charset=ISO-8859-15
Marc schrieb:
> to be able to add a method to one of the provided classes (like
> SWTBotTable.class)
> isn't it?
You can check out the source code from the repository into your
workspace and use your local version of SWTBot. In fact you are invited
to modify it, it's open-source!
A link to the source code repository is here
http://www.eclipse.org/projects/project_summary.php?projecti d=technology.swtbot
Frank.
Dr. Frank Gerhardt
Gerhardt Informatics Kft.
Eclipse Foundation member
fg@gerhardtinformatics.com <mailto:fg@gerhardtinformatics.com>
www.gerhardtinformatics.com <http://www.gerhardtinformatics.com>
SENS-Experte www.SoftwareExperts.de <http://www.SoftwareExperts.de>
I'm speaking at EclipseCon 2009
Adam u. 9, 6753 Szeged, Hungary. Registergericht/Domicile and Court of
Registry: Szeged, Hungary. HRB-Nr./Commercial Registery No.:
06-09-010204. Umsatzsteuer-Id/VAT registration number: HU 13592417.
Gesch
Previous Topic:looking for suggesting to locate/interact with the context menu of a source editor
Next Topic:SWTBotStyledText#navigateTo, line number vs. line index
Current Time: Sun Aug 31 14:37:58 EDT 2025
Powered by FUDForum. Page generated in 0.03657 seconds
