Home » Language IDEs » Java Development Tools (JDT) » Bug in org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsAction?
Bug in org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsAction? [message #212264] Fri, 12 August 2005 11:38 Go to next message
I develope a plugin for automated debugging of java programs for
eclipse. My plugin launches several tests in an additional vm and use
the tools of eclipse to set breakpoints etc.
During the execution of my tool i get the following error:
!ENTRY org.eclipse.ui 4 0 2005-08-12 17:08:52.535
!MESSAGE Failed to execute runnable
(org.eclipse.jface.util.Assert$AssertionFailedException: null argument;)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2844)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2575)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.eclipse.jface.util.Assert$AssertionFailedException: null
argument;
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:149)
at org.eclipse.jface.util.Assert.isNotNull(Assert.java:125)
org.eclipse.jface.viewers.StructuredSelection.<init>(StructuredSelection.java:66)
org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsA ction$1.run(ShowSystemThreadsAction.java:103)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
I debugged the application and found that in ShowSystemThreadsAction at
line 102 the top stack frame of the current thread will assigned to the
variable tos. After that this frame should present to the user with a
StructuredSelection. But unfortunately the method getTopStackFrame can
return null. This cause an AssertionFailedException in the constructor
of the StructuredSelection.
Code snippet from ShowSystemThreadsAction (line 102-103):
tos = thread.getTopStackFrame();
getStructuredViewer().setSelection(new StructuredSelection(tos));
Can it be that this is a bug from the eclipse workbench? It is necessary
to check that the top stack frame is not null before the
StructuredSelction will be initialised?
The exception affect not the execution of my plugin. But the effect that
the error will displayed in the error log isn't very fine for me. The
consequence of this exception is still an unhandeld event loop exception
which will already logged in the error log.
FYI:
I use eclipse 3.1. The bug occurs on the windows, linux and mac machines.
Re: Bug in org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsAction? [message #212272 is a reply to message #212264] Fri, 12 August 2005 11:43 Go to previous messageGo to next message
If you can provide a test case and the stack traces you provide here it
would be great if you would log a bug report against JDT Debug
Darins
"Karsten Lehmann" <KarstenLehmann@web.de> wrote in message
news:ddifpr$gj4$1@news.eclipse.org...
> Hi
> !STACK 0
> at
> at
> at
java:226)
> at
> at
> at
> at
..java:25)
> argument;
> at
a:66)
> at
> at
> ... 18 more
> FYI:
Re: Bug in org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsAction? [message #212296 is a reply to message #212272] Fri, 12 August 2005 11:56 Go to previous messageGo to next message
Sorry
Because my plugin is yet not public i cannot provide a special test
case. But if you inspect the code at my given position under the fact
that the method getTopStackFrame can return null i be sure that this is
a bug.
Should i always enter it as bug report if i cannot give a detailed test
case?
Best regards
Karsten
> Thanks
> Darins
>>Hi
>>!STACK 0
>>at
>>at
>>at
> java:226)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
> .java:25)
>>argument;
>>at
> a:66)
>>at
>>at
>>... 18 more
>>FYI:
Re: Bug in org.eclipse.jdt.internal.debug.ui.actions.ShowSystemThreadsAction? [message #212303 is a reply to message #212296] Fri, 12 August 2005 12:01 Go to previous message
Yes please still enter the bug report
news:ddigrd$hnj$1@news.eclipse.org...
> Sorry
> a bug.
> case?
> Best regards
> Karsten
> > Thanks
> > Darins
> >>Hi
> >>!STACK 0
> >>at
> >>at
> >>at
> >>at
> > java:226)
> >>at
> >>at
> >>at
> >>at
> > .java:25)
> >>argument;
> >>at
> > a:66)
> >>at
> >>at
> >>... 18 more
> >>FYI:
machines.
Previous Topic:Skipping over app server generated code
Next Topic:Adding classpath entry to a JavaProject
Current Time: Mon Jul 14 13:21:59 EDT 2025
Powered by FUDForum. Page generated in 0.05189 seconds
