Home » Language IDEs » C / C++ IDE (CDT) » [CDT Internal Builder] how to handling several tools with the same input
[CDT Internal Builder] how to handling several tools with the same input [message #212229] Fri, 21 March 2008 08:22 Go to next message
Hi all,
I would like to use MBS in the following way:
We have 4 file extensions (ext_a, ext_b, ext_c & ext_d)
and 3 tools:
ext_a --> ext_b (intermediate tool)
ext_b --> ext_c (final tool 1)
ext_b --> ext_d (final tool 2)
I declare "final tool 1" as the target tool of my toolchain, and I use the
secondaryOutputs attribute to require the "ext_d" file generation.
I create a new CDT project using this toolchain, and I create a
"test.ext_a" source file. When I launch the build, "test.ext_b" and
"test.ext_c" files are correctly generated, but nothing is done for
"test.ext_d".
I noticed that if I go to the project properties --> C/C++ build --> Tool
chain editor --> Select Tools, the UI warns me about a tool conflict
between "final tool 1" & "final tool 2"
I guess it is due to the fact that they require the same file extension as
an input... I surely missed something in the configuration...
But know, how can I tune MBS in order to make it do what I want?
Thanks in advance.
Please find below an extract of my plugin.xml
<extension
point="org.eclipse.cdt.managedbuilder.core.buildDefinitions ">
<tool
command="cmd /c copy"
commandLinePattern="${COMMAND} ${INPUTS} ${OUTPUT}"
id="DummyMBSExtender.toolbase"
isAbstract="true"
name="Base tool">
</tool>
<projectType
buildArtefactType="org.eclipse.cdt.build.core.buildArtefactType.exe "
id="DummyMBSExtender.projectType1"
isAbstract="false">
<configuration
artifactExtension="ext_c"
id="DummyMBSExtender.configuration1"
name="Dummy Configuration">
<toolChain
id="DummyMBSExtender.toolChain1"
isAbstract="false"
name="Dummy Toolchain"
secondaryOutputs="DummyMBSExtender.outputType.ext_d"
targetTool="DummyMBSExtender.finalTool1">
<builder
id="DummyMBSExtender.builder1"
isAbstract="false"
isVariableCaseSensitive="false"
superClass="org.eclipse.cdt.build.core.internal.builder">
</builder>
<tool
id="DummyMBSExtender.finalTool1"
isAbstract="false"
name="Final Tool"
superClass="DummyMBSExtender.toolbase">
<inputType
id="DummyMBSExtender.inputType.ext_b"
name="ext_b input"
primaryInput="true"
sources="ext_b">
</inputType>
<outputType
id="DummyMBSExtender.outputType.ext_c"
name="ext_c output"
outputs="ext_c"
primaryOutput="true">
</outputType>
</tool>
<tool
id="DummyMBSExtender.tool3"
isAbstract="false"
name="Intermediate tool"
<inputType
id="DummyMBSExtender.inputType.ext_a"
name="ext_a input"
primaryInput="true"
sources="ext_a">
</inputType>
<outputType
id="DummyMBSExtender.outputType.ext_b"
name="ext_b output"
outputs="ext_b"
</outputType>
</tool>
<tool
id="DummyMBSExtender.finalTool2"
isAbstract="false"
name="Other Final Tool"
<inputType
id="DummyMBSExtender.inputType.ext_b.2"
name="ext_b input"
primaryInput="true"
sources="ext_b">
</inputType>
<outputType
id="DummyMBSExtender.outputType.ext_d"
name="ext_d output"
outputs="ext_d"
</outputType>
</tool>
</toolChain>
</configuration>
</projectType>
</extension>
Re: [CDT Internal Builder] how to handling several tools with the same input [message #212535 is a reply to message #212229] Tue, 25 March 2008 04:42 Go to previous message
Maybe MBS is not able to handle that Use Case?
So what is the goal of the secondaryOutputs attribute of a toolchain?
Previous Topic:gdb non termination
Next Topic:How to reconnect svn repository after ip address changed?
Current Time: Sun Jul 27 06:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.19740 seconds
