Home » Archived » M2M (model-to-model transformation) » [ATL] AM3 Ant task problem
[ATL] AM3 Ant task problem [message #20520] Sun, 04 March 2007 14:01 Go to next message
Originally posted by: milanmilanovich.yahooo.com
Hi all,
I've installed Eclipse 3.1.2 and latest ATL binary version from site. But,
when I run AM3 ANT task, which PERFECTLY worked on my previous
installation, I got an error. Load is done O.K., but in line am3.atl...
BUILD FAILED
C:\Program Files\eclipse\workspace\megaproject\build.xml:11:: The
following error occurred while executing this line:
java.lang.NoSuchMethodError:
org.atl.eclipse.engine.AtlModelHandler.getHandler(Lorg/atl/e ngine/vm/nativelib/ASMModel;)Ljava/lang/Sting;
The same error is generated when I change model handler to EMF or MDR.
What is the problem here, please ?
Re: [ATL] AM3 Ant task problem [message #20617 is a reply to message #20520] Mon, 05 March 2007 14:58 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Hi Milan,
It seems your version of AM3 ant tasks is not compatible with your
version of ATL.
Freddy.
Milan Milanovic a écrit :
> Hi all,
> But, when I run AM3 ANT task, which PERFECTLY worked on my previous
> BUILD FAILED C:\Program
> Files\eclipse\workspace\megaproject\build.xml:11:: The following error
Re: [ATL] AM3 Ant task problem [message #21547 is a reply to message #20617] Tue, 06 March 2007 06:23 Go to previous messageGo to next message
Hi Freddy,
I've installed latest binary version of ATL from site (june 2006.). Which
version of AM3 Ant task (and from where) I should install ?
Best regards, Milan Milanovic
Freddy Allilaire wrote:
> Hi Milan,
> version of ATL.
> Freddy.
>> Hi all,
>> BUILD FAILED C:Program
>> Fileseclipseworkspacemegaprojectbuild.xml:11:: The following error
Re: [ATL] AM3 Ant task problem [message #21593 is a reply to message #21547] Tue, 06 March 2007 09:07 Go to previous messageGo to next message
Hi Milan,
An "unofficial" binary version is available from our team web site. It
contains ATL, AM3 & AM3 ant tasks.
This version is reachable here:
http://www.sciences.univ-nantes.fr/lina/atl/www/atldemo/adt_ am3.zip
Otherwise, if you really want to use the ATL binary version of june 2006
you should checkout the AM3 ant tasks from Eclipse CVS by using a date
tag (e.g 2006/06/30).
Freddy.
> Hi Freddy,
> Which version of AM3 Ant task (and from where) I should install ?
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] AM3 Ant task problem [message #21638 is a reply to message #21593] Tue, 06 March 2007 12:02 Go to previous messageGo to next message
Hi Freddy,
thank you on this. I will use this version, even I checked out it from
source
today.
> Hi Milan,
> Freddy.
>> Hi Freddy,
Re: [ATL] ATL 2006 compile problem [message #21957 is a reply to message #21638] Wed, 07 March 2007 15:00 Go to previous messageGo to next message
Hi Freddy,
I've installed ADT unofficial bundle, but now when I put first line
in my transformation like: --@atlcompiler atl2006, and save transformation
it is not dumped to the ASM, i.e. ATL file is not compiled ?
Milan Milanovic wrote:
> Hi Freddy,
> source
> today.
Re: [ATL] ATL 2006 compile problem [message #22222 is a reply to message #21957] Thu, 08 March 2007 05:45 Go to previous messageGo to next message
Hi Milan,
I tested this (with "--@atlcompiler atl2006") and my ATL file is compiled.
Does your project have the ATL nature?
Otherwise, do you have a report in the error log and something like that?
Freddy.
> Hi Freddy,
Re: [ATL] ATL 2006 compile problem [message #22702 is a reply to message #22222] Fri, 09 March 2007 14:34 Go to previous message
Hi Freddy,
Yes, I created a new ATL project and copied in it all files. When I remove
"--@atlcompiler atl2006" then ATL transformation is dumped to ASM.
With "--@atlcompiler atl2006" and when I click on save, I got an error log
below. Please help...thank you!
!SESSION 2006-09-03 20:48:28.671
eclipse.buildId=M20060118-1600
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sr
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
This is a continuation of log file C:\Program
Files\eclipse\workspace\.metadata\.bak_2.log
Created Time: 2006-09-03 20:50:20.578
!ENTRY org.eclipse.ui.console 4 120 2006-09-03 20:50:20.578
!MESSAGE Error logged from Console plug-in:
!STACK 0
java.io.IOException: Output Stream is closed
org.eclipse.ui.console.IOConsoleOutputStream.encodedWrite(IO ConsoleOutputStream.java:223)
org.eclipse.ui.console.IOConsoleOutputStream.write(IOConsole OutputStream.java:218)
org.eclipse.ui.console.MessageConsoleStream.print(MessageCon soleStream.java:49)
org.eclipse.ui.console.MessageConsoleStream.println(MessageC onsoleStream.java:74)
org.atl.eclipse.adt.ui.OutputStreamRedirector.println(Output StreamRedirector.java:34)
at org.atl.engine.vm.ExecEnv.printStackTrace(ExecEnv.java:58)
at org.atl.engine.vm.SimpleDebugger.error(SimpleDebugger.java:1 46)
at org.atl.engine.vm.StackFrame.printStackTrace(StackFrame.java :85)
at org.atl.engine.vm.StackFrame.printStackTrace(StackFrame.java :77)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:157)
at org.atl.engine.vm.ASMExecEnv.getHelperValue(ASMExecEnv.java: 297)
at org.atl.engine.vm.nativelib.ASMOclAny.getHelper(ASMOclAny.ja va:90)
org.atl.engine.repositories.mdr4atl.ASMMDRModelElement.get(A SMMDRModelElement.java:237)
at org.atl.engine.vm.ASMOperation.realExec(ASMOperation.java:27 2)
at org.atl.engine.vm.ASMOperation.exec(ASMOperation.java:155)
Previous Topic:EMF M1 model transformation with ATL
Next Topic:[ATL] New ATL use case: From UML Activity Diagram to Project Management Software
Current Time: Sat Jul 26 00:16:12 EDT 2025
Powered by FUDForum. Page generated in 0.33226 seconds
