Home » Eclipse Projects » Eclipse Platform » problems porting from 2.1 to 3m7
problems porting from 2.1 to 3m7 [message #211510] Mon, 15 March 2004 13:19 Go to next message
Originally posted by: 0043672.student.ul.ie
I have just ported across my plug-in from 2.1 to m7 and am having a
problem.
It is giving me the following error in one of my custom class files which
i cannot get to the bottom of.
"The type org.eclipse.ui.texteditor.ExtendedTextEditor cannot be resolved.
It is indirectly referenced from required .class files."
Also I cannot seem to add imported plugins to my class path. These
problems are probably related!
Has anybody had any similar type errors????????????????
Re: problems porting from 2.1 to 3m7 [message #211541 is a reply to message #211510] Mon, 15 March 2004 13:43 Go to previous messageGo to next message
Originally posted by: shimbun.gmx.de
i do not really know what's the error, but maybe it is what i already read
in an article about migrating from eclipse 2 to 3
it was written, that org.eclipse.ui moved to org.eclipse.ui.ide
maybe you should try then to change it from
to
org.eclipse.ui.ide.texteditor.ExtendedTextEditor
Niall Ross wrote:
> problem.
Re: problems porting from 2.1 to 3m7 [message #211571 is a reply to message #211541] Mon, 15 March 2004 14:22 Go to previous messageGo to next message
Importing org.eclipse.ui.ide still does not resolve any plugin refernce
problems and i'm still getting the same errors.
The thing is i have no reference whatsoever to this ExtendedTextEditor as
its new since eclipse 3.
When i try to add my imported plugins to the java build path it doesnt
work, complaining that each plugin is a duplicate entry.
Also it complains that "The project cannot be built since its build path
is incomplete. Cannot find the class file for
org.eclipse.ui.texteditor.ExtendedTextEditor"
I'm still quite puzzled! Its probably something very obvious that i'm
missing!!!
> to
> Niall Ross wrote:
> > Hi,
> > problem.
Re: problems porting from 2.1 to 3m7 [message #211822 is a reply to message #211571] Tue, 16 March 2004 03:13 Go to previous messageGo to next message
What's your workspace setup? Have you imported the
org.eclipse.ui.workbench.texteditor plug-in as a binary plug-in, or via
a PDE plug-in container?
ExtendedTextEditor is the superclass of TextEditor, which you are
probably referencing somewhere.
-tom
> missing!!!
Re: problems porting from 2.1 to 3m7 [message #212057 is a reply to message #211822] Tue, 16 March 2004 11:31 Go to previous message
Got it sorted Tom ....eventually!!
Starting from scratch seemed to get rid of the duplicate plugin error and
importing the org.eclipse.ui.editors seemed to solve the
ExtendedTextEditor indirect reference error.
Thank god!!
> -tom
> > missing!!!
Previous Topic:Standalone eclipse plugins
Next Topic:Creat a resource like this/nested/resource
Current Time: Sat Jul 26 07:39:42 EDT 2025
Powered by FUDForum. Page generated in 1.04861 seconds
