Home » Eclipse Projects » DTP » Could not connect; Native Library loaded in another classloader
Could not connect; Native Library loaded in another classloader [message #20455] Wed, 23 August 2006 03:05 Go to next message
Originally posted by: sjeeva.eclipse.org
Under connectivity preferances, I added a Generic JDBC driver for my
database - TimesTen (in memory database; a product of Oracle corp.)
In the Data Source Explorer view added a new Database of SQL Model JDBC
Connection; and specified the above driver.
But when I try connecting, I get
Could not connect to TimesTen.
Error creating SQL Model Connection connection to TimesTen. (Error: Native
Library C:\WINDOWS\system32\ttJdbc60.dll already loaded in another
classloader)
Any clues will be appreciated.
~g1
PS:
I am using Eclipse Calisto - Version: 3.2.0; Build id: M20060629-1905
Via the update manager,
I installed everything available under the Eclipse DataTools platform
(Version: 0.9.0.200606161; Build id: 0.9.0.200606161)
Re: Could not connect; Native Library loaded in another classloader [message #20456 is a reply to message #20455] Wed, 23 August 2006 03:08 Go to previous messageGo to next message
and the .log file has the following trace
!ENTRY org.eclipse.datatools.connectivity 4 -1 2006-08-23 11:28:30.277
!MESSAGE Error creating SQL Model Connection connection to TimesTen.
(Error: Native Library C:\WINDOWS\system32\ttJdbc60.dll already loaded in
another classloader)
!STACK 0
java.sql.SQLException: Native Library C:\WINDOWS\system32\ttJdbc60.dll
already loaded in another classloader
com.timesten.jdbc.JdbcOdbcConnection.connect(JdbcOdbcConnect ion.java:1704)
at com.timesten.jdbc.TimesTenDriver.connect(TimesTenDriver.java :362)
at com.timesten.jdbc.TimesTenDriver.connect(TimesTenDriver.java :218)
org.eclipse.datatools.connectivity.db.generic.JDBCConnection .createConnection(JDBCConnection.java:88)
org.eclipse.datatools.connectivity.DriverConnectionBase.inte rnalCreateConnection(DriverConnectionBase.java:103)
org.eclipse.datatools.connectivity.DriverConnectionBase.open (DriverConnectionBase.java:53)
org.eclipse.datatools.connectivity.db.generic.JDBCConnection . <init>(JDBCConnection.java:48)
org.eclipse.datatools.connectivity.db.generic.JDBCConnection Factory.createConnection(JDBCConnectionFactory.java:51)
org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:85 )
org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:69 )
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:304)
org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionInfoImpl. <init>(ConnectionInfoImpl.java:622)
org.eclipse.datatools.connectivity.sqm.internal.core.connect ion.ConnectionFactory.createConnection(ConnectionFactory.jav a:36)
org.eclipse.datatools.connectivity.sqm.core.SQMConnectionFac tory.createConnection(SQMConnectionFactory.java:45)
org.eclipse.datatools.connectivity.internal.ConnectionFactor yAdapterProvider.createConnection(ConnectionFactoryAdapterPr ovider.java:79)
org.eclipse.datatools.connectivity.internal.CreateConnection Job.run(CreateConnectionJob.java:55)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.datatools.connectivity 4 -1 2006-08-23 11:28:31.964
!MESSAGE Could not connect to TimesTen.
!SUBENTRY 1 org.eclipse.datatools.connectivity 4 -1 2006-08-23 11:28:31.964
!STACK 0
!SUBENTRY 1 org.eclipse.core.runtime 2006-08-23 11:28:31.964
!MESSAGE OK
Re: Could not connect; Native Library loaded in another classloader [message #21955 is a reply to message #20456] Tue, 03 October 2006 15:04 Go to previous messageGo to next message
Originally posted by: adidas28.yahoo.com
I'm having the same issue with DB2 V7. The db2jdbc.dll file gives me the
same error.. Has anyone resolved this?
"jeevan" <sjeeva@eclipse.org> wrote in message
news:626da2914d1e70cc5087f796d9b9c9d0$1@www.eclipse.org...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 11:28:31.964
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE OK
Re: Could not connect; Native Library loaded in another classloader [message #22133 is a reply to message #20455] Mon, 16 October 2006 11:44 Go to previous messageGo to next message
Originally posted by: john.graham.sybase.com
jeevan wrote:
> Library C:WINDOWSsystem32ttJdbc60.dll already loaded in another
> classloader)
> ~g1
> PS:
Hi Jeevan:
We'd appreciate a Bugzilla entry for this problem, so we can track the
issue with our Connectivity project team.
John Graham
Eclipse Data Tools Platform PMC Chair
Re: Could not connect; Native Library loaded in another classloader [message #22299 is a reply to message #21955] Mon, 23 October 2006 14:52 Go to previous messageGo to next message
Please review the following BZ entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=130799
Rob
Re: Could not connect; Native Library loaded in another classloader [message #22999 is a reply to message #20455] Fri, 10 November 2006 11:15 Go to previous message
There were general problems using drivers that had dependencies on native
libraries. A patch for this problem has been applied which improves
support.
Note, you will still have problems if you have more than one driver
definition that references the same native library (e.g. if you have two
driver definitions that reference the same native library and connection
profiles which reference one or the other, you will be able to connect to
those profiles referencing the same driver definition as the one used for
the first connection, but the profiles referencing the other driver
definition will fail).
(The technical problem: each driver definition manages its own class
loader. This class loader is shared among connections. If you have two
driver definitions, there will be two different class loaders and if both
have a dependency on the same native library, the second class loader that
is used will fail to load the native library.)
Thanks to Brian for checking in the fix.
Rob
Re: Could not connect; Native Library loaded in another classloader [message #581869 is a reply to message #20455] Wed, 23 August 2006 03:08 Go to previous message
!STACK 0
!STACK 0
!MESSAGE OK
Re: Could not connect; Native Library loaded in another classloader [message #582527 is a reply to message #20456] Tue, 03 October 2006 15:04 Go to previous message
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 11:28:31.964
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE OK
Re: Could not connect; Native Library loaded in another classloader [message #582625 is a reply to message #20455] Mon, 16 October 2006 11:44 Go to previous message
jeevan wrote:
> classloader)
> ~g1
> PS:
Hi Jeevan:
John Graham
Re: Could not connect; Native Library loaded in another classloader [message #582691 is a reply to message #21955] Mon, 23 October 2006 14:52 Go to previous message
Rob
Re: Could not connect; Native Library loaded in another classloader [message #583018 is a reply to message #20455] Fri, 10 November 2006 11:15 Go to previous message
support.
Rob
Previous Topic:Connecting to Derby via Embedded Driver
Next Topic:TPTP Profiling .ear file
Current Time: Sat Jun 07 20:59:41 EDT 2025
Powered by FUDForum. Page generated in 0.04297 seconds
