assert & export [message #211279] |
Mon, 15 March 2004 10:14  |
Originally posted by: skywalker6.gmx.net
I am developing an eclipse-plugin which sometimes uses assert(). When I
run it in runtim-workspace it workes fine. No I want to export it. But I
always get Errors. When I don't use assert() I dont get this Errors.
I tried many things to change this, but nothing worked. I tried:
- adding 2 lines to build.xml:
<property name="javacSource" value="1.4">
<property name="javacTarget" value="1.4"> (I tried 1.2 too)
- run ant... on build.xml and select Properties, add Property, Name:
javacSource Value: 1.4
- under Window>Preferences>java>compiler>Compliance and Classfiles>
Compiler compliance level is 1.4
...but nothing worked.
I use eclipse 2.1.2 and java 1.4.2
any ideas? thanks, Steven
Re: assert & export [message #211299 is a reply to message #211279] |
Mon, 15 March 2004 10:31   |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Steven wrote:
Yes, I reported a bug about this (54042). Ant does not seem to like the
keyword assert. The exports do however seem to be exported fine though.
I also use eclipse 2.1.2 but on java 1.4.1 generally.
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: assert & export [message #211563 is a reply to message #211299] |
Mon, 15 March 2004 14:20  |
CL [dnoyeb] Gilbert wrote:
> Steven wrote:
> > Hi,
My export doesn't work fine :( .
Steven
FUDForum. Page generated in 0.03651 seconds
