Canned Report questions [message #211253] |
Fri, 12 January 2007 10:45 |
Originally posted by: jeff.scott.rationalsystems.com
Hi Lisa, here are a few more questions I had by report number.
13)
-What makes a meter an Appalachian meter?
15)
-Are the meter quantities the gross quantities? And then where is the
"gross deducts" value coming from?
16)
-What is the "Statement No:" in the title referring to?
-Is the Pressure base constant across the pipe? I'm almost positive we
don't keep track of this on a meter level right now.
-Is the "BTU Water Content lb/mmcf" always dry since we've only imported
the dry data?
-In each meter's header there are two fields like "TURBO"&"TP-90" or
"ROOTS"&"2.0M" what are these referring to?
-As for grouping it looks like this is grouped by the given Operator,
then meters they operate, then the data. But there are a couple mid
report summaries that seem somewhat arbitrarily placed.
17)
-What makes a point an non-FSS-balanced location?
18)
-If "Int Fact" is always 100% does that mean the "Producer Portion" MCF
and Dth will always equal "MCF" and "Dth"?
27)
-What's the difference between "GL INJ" and "Gross INJ" ?
33)
-What's an "intermediate service provider"?
Thanks, Jeff
FUDForum. Page generated in 0.03087 seconds
