Home » Archived » BIRT » Chart Interactivity
Chart Interactivity [message #211039] Thu, 11 January 2007 23:40 Go to next message
Originally posted by: Jeff.thisplace.com
Hi Folks:
I have a pie chart which I would like to link to a sub-report. The
sub-report has a parameter which needs to be obtained from the pie chart.
The parameter value I need to obtain is the distinct name for each item
listed in the legend. The distinct category which has been selected.
I have tried interactivity (Mouse Click, URL Redirect) on both the "value
series" and the "legend". From a value series perspective, I have tried to
set the parameter value from
1. Within the "Edit Base URL", "Report Parameters". If I set the value
manually from this location. (e.g.: "value name"), the report displays
correctly. However, I cannot figure out how to get the value dynamically.
Again, the value needs to be one of the distinct names from within the
legend.
2. Within the "URL Parameter Names". Here, I set each option to the name
of the report parameter needed on the sub-report.
From a legend perspective, I have tried to set the value just as I did in
number 1. above.
Can anyone see what I am doing wrong?
Jeff
Re: Chart Interactivity [message #211198 is a reply to message #211039] Fri, 12 January 2007 07:39 Go to previous messageGo to next message
Try this:
On the value series interactivity dialog, choose hyperlink - drillthrough
(in edit base url dialog) and pick your target report.
Go back to the interactivity dialgog, (click Advanced if you see this button),
you will see some input boxes, one is called Category Series, add the name
of the target parameter there.
David
> Hi Folks:
> chart. The parameter value I need to obtain is the distinct name for
> each item listed in the legend. The distinct category which has been
> selected.
> "value series" and the "legend". From a value series perspective, I
> have tried to set the parameter value from
> value manually from this location. (e.g.: "value name"), the report
> displays correctly. However, I cannot figure out how to get the value
> dynamically. Again, the value needs to be one of the distinct names
> from within the legend.
> name of the report parameter needed on the sub-report.
> in number 1. above.
> Jeff
Re: Chart Interactivity [message #211425 is a reply to message #211198] Sat, 13 January 2007 15:11 Go to previous messageGo to next message
Hi David:
I don't see an advanced tab where I can enter information associated with
the Category Series. (Version 2.1.1) I can however see those options from
the category series interactivity dialog, under the heading "URL Parameter
Names".
Let me explain what I am doing in more detail and maybe you can see what I
am doing wrong.
1. I have a report which has a praemeter defined. The parameter is called
LastName.
2. The report has a line graph with the following SQL for the Data Set.
select * from table1 where table1.name = ?
3. In the Edit Data Set, Parameters, I have a parameter defined as:
Data Type: String
Direction: Input
Default Value: N/A
Linked to Report Parameter: LastName
4. I have a bookmark defined for the line chart called "MyBookmark"
5. In a seprate report, I have a pie chart. The category series is
LastName.
6. In the Format Chart, Value Series, Interactivity Dialog, I have a Mouse
Click - URL Redirect created.
7. Under Edit Base URL, I have:
Select HyperLink Type: Drill-through
Step 1: I have Selected the target report described above.
- Report Parameters: Parameters: LastName, Requiered: YES, Values: NULL
(Tried LastName here, but it did not work)
Step 2: Target Bookmark set to "MyBookmark"
Step 3: "MyBookmark"
Step 4: New Window
Step 5: html
8. Back in the Interactivity dialog, URL Parameters Names: Category Series
is set to "LastName"
9. I update the report.
When I preview the report, click on a segment of the pie chart, the first
report described above is presented. However, I am asked for the parameter
LastName in a parameters dialog. (I read that if the value is being passed
on the URL, this dialog should not appear.) If I supply no parameter, the
report is blank. If I supply a valid parameter (LastName), the report is
correct.
I have concluded that the report being called from the pie chart is not
being passed the category series parameter as expected. Can you see that I
am doing anything incorrectly here?
Thanks David.
Jeff
Under data sets, parameters,
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:9c678db72668c9046630329724@news.eclipse.org...
> Try this:
> button), you will see some input boxes, one is called Category Series, add
> the name of the target parameter there.
> David
>> Hi Folks:
>> selected.
>> in number 1. above.
>> Thanks,
>> Jeff
Re: Chart Interactivity [message #211680 is a reply to message #211425] Tue, 16 January 2007 10:12 Go to previous messageGo to next message
Does anyone on the list here see if I am doing something incorrectly with
the steps defined below? This is a road block for me being able to utilize
BIRT for our app.
Jeff
"Jeff" <Jeff@thisplace.com> wrote in message
news:eobecn$9qn$1@utils.eclipse.org...
> Hi David:
> from the category series interactivity dialog, under the heading "URL
> Parameter Names".
> am doing wrong.
> called LastName.
> Data Type: String
> Direction: Input
> Default Value: N/A
> LastName.
> Mouse Click - URL Redirect created.
> Step 4: New Window
> Step 5: html
> Series is set to "LastName"
> parameter LastName in a parameters dialog. (I read that if the value is
> being passed on the URL, this dialog should not appear.) If I supply no
> parameter, the report is blank. If I supply a valid parameter (LastName),
> the report is correct.
> I am doing anything incorrectly here?
> Thanks David.
> Jeff
>> Try this:
>> add the name of the target parameter there.
>> Thanks,
>> David
>>> Hi Folks:
>>> selected.
>>> in number 1. above.
>>> Thanks,
>>> Jeff
Re: Chart Interactivity [message #211788 is a reply to message #211680] Tue, 16 January 2007 12:09 Go to previous messageGo to next message
Sorry for the late reply. From reading the steps you posted previously, I
think the problem is here:
>> NULL
Don't set any report parameters here.
If it doesn't work, could you get the URL when the target report opens and
paste it here, it might give is some hint of what the problem is. Normally
that url should have &LastName=clickedCategoryName
David
> with the steps defined below? This is a road block for me being able
> to utilize BIRT for our app.
> Jeff
>> Hi David:
>> with the Category Series. (Version 2.1.1) I can however see those
>> options from the category series interactivity dialog, under the
>> heading "URL Parameter Names".
>> what I am doing wrong.
>> called LastName.
>> Set.
>> Data Type: String
>> Direction: Input
>> Default Value: N/A
>> LastName.
>> NULL
>> Step 4: New Window
>> Step 5: html
>> first report described above is presented. However, I am asked for
>> the parameter LastName in a parameters dialog. (I read that if the
>> value is being passed on the URL, this dialog should not appear.) If
>> I supply no parameter, the report is blank. If I supply a valid
>> parameter (LastName), the report is correct.
>> not being passed the category series parameter as expected. Can you
>> see that I am doing anything incorrectly here?
>> Thanks David.
>> Jeff
>>> Try this:
>>> drillthrough
>>> this
>>> Series,
>>> Thanks,
>>> David
>>>> Hi Folks:
>>>> for each item listed in the legend. The distinct category which
>>>> has been selected.
>>>> I have tried to set the parameter value from
>>>> report displays correctly. However, I cannot figure out how to get
>>>> the value dynamically. Again, the value needs to be one of the
>>>> distinct names from within the legend.
>>>> the name of the report parameter needed on the sub-report.
>>>> did in number 1. above.
>>>> Thanks,
>>>> Jeff
Re: Chart Interactivity [message #211889 is a reply to message #211788] Tue, 16 January 2007 14:11 Go to previous messageGo to next message
Hi David:
I tried what you requested with the same result.
It would appear that the URL does not contain the name value pair expected.
Here is the URL generated:
http://127.0.0.1:52145/viewer/frameset?__report=%2FC%3A%2FJS T%2FNameLookup_reportTest%2Feclipse%2Fworkspace%2FName+Looku p+-+Alpha+1.0%2FPie+Drill+Down.rptdesign&__format=html&a mp;__overwrite=true&__bookmark=MyBookmark
If I add &LastName=<ValidLastName> to a URL in a browser, it works. Do you
think this is a defect?
Jeff
news:9c678db74738c907b09c74ed54@news.eclipse.org...
>>> NULL
> David
>> Thanks,
>> Jeff
>>> Hi David:
>>> called LastName.
>>> Set.
>>> Data Type: String
>>> Direction: Input
>>> Default Value: N/A
>>> LastName.
>>> NULL
>>> Step 4: New Window
>>> Step 5: html
>>> Thanks David.
>>> Jeff
>>>> Try this:
>>>> drillthrough
>>>> this
>>>> Series,
>>>> Thanks,
>>>> David
>>>>> Hi Folks:
>>>>> has been selected.
>>>>> Thanks,
>>>>> Jeff
Re: Chart Interactivity [message #212006 is a reply to message #211889] Wed, 17 January 2007 05:43 Go to previous messageGo to next message
It could be a defect indeed, but we have tested this, so maybe it happens
only with a particular chart type. Does it work for other types? You can
go ahead and file a bugzilla entry.
David
> Hi David:
> expected.
> okup_reportTest%2Feclipse%2Fworkspace%2FName+Lookup+-+Alpha+ 1.0%2FPie+
> Drill+Down.rptdesign&__format=html&__overwrite=true& amp;__bookmark=MyBookm
> ark
> Do you think this is a defect?
> Jeff
>> previously, I think the problem is here:
>>>> NULL
>> opens and paste it here, it might give is some hint of what the
>> problem is. Normally that url should have
>> Thanks,
>> David
>>> able to utilize BIRT for our app.
>>> Thanks,
>>> Jeff
>>>> Hi David:
>>>> associated with the Category Series. (Version 2.1.1) I can
>>>> however see those options from the category series interactivity
>>>> dialog, under the heading "URL Parameter Names".
>>>> is
>>>> called LastName.
>>>> Set.
>>>> as:
>>>> Data Type: String
>>>> Direction: Input
>>>> Default Value: N/A
>>>> "MyBookmark"
>>>> is
>>>> LastName.
>>>> a
>>>> NULL
>>>> Step 4: New Window
>>>> Step 5: html
>>>> Category
>>>> If
>>>> you see that I am doing anything incorrectly here?
>>>> Thanks David.
>>>> Jeff
>>>>> Try this:
>>>>> drillthrough
>>>>> this
>>>>> Series,
>>>>> Thanks,
>>>>> David
>>>>>> Hi Folks:
>>>>>> The sub-report has a parameter which needs to be obtained from
>>>>>> the pie chart. The parameter value I need to obtain is the
>>>>>> distinct name for each item listed in the legend. The distinct
>>>>>> the "value series" and the "legend". From a value series
>>>>>> perspective, I have tried to set the parameter value from
>>>>>> the value manually from this location. (e.g.: "value name"), the
>>>>>> get the value dynamically. Again, the value needs to be one of
>>>>>> the distinct names from within the legend.
>>>>>> I did in number 1. above.
>>>>>> Thanks,
>>>>>> Jeff
Re: Chart Interactivity [message #212160 is a reply to message #212006] Wed, 17 January 2007 11:53 Go to previous messageGo to next message
I tried to change the chart type from 2d with depth to 2d with the same
problem. I have a bar chart as well, but the interactivity button is not
enabled. What is the URL to bugzilla?
Jeff
news:9c678db74f48c90843d018af18@news.eclipse.org...
> David
>> Hi David:
>> expected.
>> ark
>> Jeff
>>>>> NULL
>>> Thanks,
>>> David
>>>> Thanks,
>>>> Jeff
>>>>> Hi David:
>>>>> is
>>>>> called LastName.
>>>>> Set.
>>>>> as:
>>>>> Data Type: String
>>>>> Direction: Input
>>>>> Default Value: N/A
>>>>> "MyBookmark"
>>>>> is
>>>>> LastName.
>>>>> a
>>>>> NULL
>>>>> Step 4: New Window
>>>>> Step 5: html
>>>>> Category
>>>>> If
>>>>> Thanks David.
>>>>> Jeff
>>>>>> Try this:
>>>>>> drillthrough
>>>>>> this
>>>>>> Series,
>>>>>> Thanks,
>>>>>> David
>>>>>>> Hi Folks:
>>>>>>> Thanks,
>>>>>>> Jeff
Re: Chart Interactivity [message #212363 is a reply to message #212160] Thu, 18 January 2007 10:50 Go to previous messageGo to next message
What do you mean the interactivity button is not enabled? did you check the
interactivity box in Chart Area node of the builder? It should be checked.
David
> same problem. I have a bar chart as well, but the interactivity
> button is not enabled. What is the URL to bugzilla?
> Jeff
>> happens only with a particular chart type. Does it work for other
>> types? You can go ahead and file a bugzilla entry.
>> Thanks,
>> David
>>> Hi David:
>>> expected.
>>> Lo
>>> e+
>>> km ark
>>> Jeff
>>>>>> Values:
>>>>>> NULL
>>>> Thanks,
>>>> David
>>>>> incorrectly with the steps defined below? This is a road block
>>>>> for me being able to utilize BIRT for our app.
>>>>> Thanks,
>>>>> Jeff
>>>>>> Hi David:
>>>>>> see what I am doing wrong.
>>>>>> is
>>>>>> called LastName.
>>>>>> Data
>>>>>> Set.
>>>>>> as:
>>>>>> Data Type: String
>>>>>> Direction: Input
>>>>>> Default Value: N/A
>>>>>> "MyBookmark"
>>>>>> is
>>>>>> LastName.
>>>>>> have
>>>>>> a
>>>>>> Values:
>>>>>> NULL
>>>>>> Step 4: New Window
>>>>>> Step 5: html
>>>>>> Category
>>>>>> the
>>>>>> for
>>>>>> the
>>>>>> If
>>>>>> is
>>>>>> Thanks David.
>>>>>> Jeff
>>>>>>> Try this:
>>>>>>> drillthrough
>>>>>>> this
>>>>>>> Series,
>>>>>>> Thanks,
>>>>>>> David
>>>>>>>> Hi Folks:
>>>>>>>> the report displays correctly. However, I cannot figure out
>>>>>>>> how to get the value dynamically. Again, the value needs to be
>>>>>>>> one of the distinct names from within the legend.
>>>>>>>> to the name of the report parameter needed on the sub-report.
>>>>>>>> as I did in number 1. above.
>>>>>>>> Thanks,
>>>>>>>> Jeff
Re: Chart Interactivity [message #212518 is a reply to message #212363] Thu, 18 January 2007 13:50 Go to previous message
I missed that on the bar chart. When I check the box, interactivity is
enabled. Thank you.
I get the same result with the bar chart. The name value pair is not passed
to the drill through report causing the report to display a dialog asking
for the parameter. So this is happening for a bar chart and a pie chart in
the same report.
Jeff
news:9c678db76168c90937eeff94a6@news.eclipse.org...
> the interactivity box in Chart Area node of the builder? It should be
> checked.
> David
>> Thanks,
>> Jeff
>>> Thanks,
>>> David
>>>> Hi David:
>>>> expected.
>>>> Lo
>>>> e+
>>>> km ark
>>>> Jeff
>>>>>>> Values:
>>>>>>> NULL
>>>>> Thanks,
>>>>> David
>>>>>> Thanks,
>>>>>> Jeff
>>>>>>> Hi David:
>>>>>>> is
>>>>>>> called LastName.
>>>>>>> Data
>>>>>>> Set.
>>>>>>> as:
>>>>>>> Data Type: String
>>>>>>> Direction: Input
>>>>>>> Default Value: N/A
>>>>>>> "MyBookmark"
>>>>>>> is
>>>>>>> LastName.
>>>>>>> have
>>>>>>> a
>>>>>>> Values:
>>>>>>> NULL
>>>>>>> Step 4: New Window
>>>>>>> Step 5: html
>>>>>>> Category
>>>>>>> the
>>>>>>> for
>>>>>>> the
>>>>>>> If
>>>>>>> is
>>>>>>> Thanks David.
>>>>>>> Jeff
>>>>>>>> Try this:
>>>>>>>> drillthrough
>>>>>>>> this
>>>>>>>> Series,
>>>>>>>> Thanks,
>>>>>>>> David
>>>>>>>>> Hi Folks:
>>>>>>>>> Thanks,
>>>>>>>>> Jeff
Previous Topic:Problems with birt-report-designer-all-in-one 2.1.1 installation
Next Topic:ONMOUSEOUT_LITERAL trigger not implemented?
Current Time: Sat Jul 26 03:08:29 EDT 2025
Powered by FUDForum. Page generated in 0.06810 seconds
