Home » Language IDEs » C / C++ IDE (CDT) » Qt with eclipse
Qt with eclipse [message #210955] Fri, 29 February 2008 20:36 Go to next message
Originally posted by: kevin.akev.org
Does anyone know how to set up Eclipse to work with Qt integration and
vc++ 9.0? (cl.exe) I can use it with Qt and mingw, but keep getting this
error when trying to use it with vc++ 9.0:
NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
9.0\VC\bin\cl.EXE"' : return code '0xc0000135'
Stop.
9.0\VC\bin\nmake.exe"' : return code '0x2'
Stop.
Re: Qt with eclipse [message #210963 is a reply to message #210955] Fri, 29 February 2008 23:01 Go to previous messageGo to next message
In news:5d95eceb93842ffab4d7ae499f3db3c0$1@www.eclipse.org kevin@akev.org
The c0000135 error code in general means "the application failed to
initialize" or "component not found".
Is your PATH environment variable set up correctly?
Exit status "2" from nmake is probably just a result of the compiler
exiting abnormally.
Re: Qt with eclipse [message #210971 is a reply to message #210963] Fri, 29 February 2008 23:45 Go to previous message
Yes it is in the path. (Same directory as nmake.exe)...
C:\Users\kev>echo %PATH%
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\m ysql\bin;C:\Windows\
Microsoft.NET\Framework\v2.0.50727;C:\Program Files\Microsoft SQL
Server\90\Tool
s\binn\;C:\MinGW\libexec\gcc\mingw32\3.4.2;c:\mingw\bin;c:\m asm32\bin;c:\qt-stat
ic-4.3.3\bin;C:\Program Files\Microsoft Visual Studio
9.0\VC\bin;C:\Program File
s\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio
Share
d\9.0\DLLShared\
'cl.exe' is here along with nmake.exe, which does get called from eclipse.
C:\Program Files\Microsoft Visual Studio 9.0\VC\bin
Perhaps it only works with MinGW for whatever reason...
Previous Topic:Header data is missing
Next Topic:Using Eclipse with an already existing C/C++ project
Current Time: Wed Jul 16 19:19:58 EDT 2025
Powered by FUDForum. Page generated in 0.04762 seconds
