Can't Run Eclipse [message #210818] |
Tue, 15 May 2007 21:08 |
Originally posted by: mittens7922.yahoo.com
Everytime i try to run eclipse (This was after tried to install some dumb
plugin) i get this error. I have repeatedly tried to reinstall eclipse to
know avail.
This is what shows up in the log:
SESSION 2007-05-15 17:03:54.539
eclipse.buildId=M20060629-1905
java.version=1.4.1_02
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2007-05-15 17:04:02.679
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.core.runtime.compatibility (25).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.plugins.
Any clue what this issue is?
Thanks Anna
(i have been using eclipse for years and i have never had any problems
until now!!)
Re: Can't Run Eclipse [message #210826 is a reply to message #210818] |
Tue, 15 May 2007 21:57 |
Originally posted by: wharley.bea.com
"Anna" <mittens7922@yahoo.com> wrote in message
news:67a375b38691693ff3e61e33d4c19044$1@www.eclipse.org...
> know avail.
Did you first delete the existing eclipse installation, or install to a new
location? It won't work to just reinstall to the same location, because the
dumb plug-in will still be there.
Re: Can't Run Eclipse [message #210834 is a reply to message #210826] |
Tue, 15 May 2007 22:09 |
I deleted everything i could find. I deleted the previous install and the
crap it put in my 'workspace' directory too. Does eclipse hide stuff in
somewhere else?
>> know avail.
Re: Can't Run Eclipse [message #210850 is a reply to message #210834] |
Tue, 15 May 2007 23:26 |
news:040e87fe96c9d3bc41cc918664fc351c$1@www.eclipse.org...
>somewhere else?
No, just what's under the eclipse install root and the workspace.
But, I just noticed you're using a pretty ancient JVM (1.4.1_02, which dates
to Feb 2003). Is it possible that you installed something that put an old
JVM on your path? You really need to be running with at least 1.4.2. JVM
requirements are documented on the Eclipse download site.
Re: Can't Run Eclipse [message #210989 is a reply to message #210850] |
Wed, 16 May 2007 13:37 |
Thanks. I figured it was something stupid like that. I have jdk1.4.0 - 1.6
on my machine and the path i was pointing to that one. Thanks Alot :)
FUDForum. Page generated in 0.07680 seconds
