Problem debugging imported project [message #210775] |
Mon, 25 July 2005 05:47 |
Originally posted by: campbell.shaun.gmail.com
I've got a webapp running through Eclipse which makes use of some open
source components. These are downloaded automatically as jar files to my
maven repository.
I'm now trying to debug some of these components using a process I used
before. I basically download the source to a location on my hard drive
(not in the Eclipse workspace), run maven eclipse to make a project file
and then import the project into Eclipse.
The problem I have is that I believe Eclipse is still running the code in
the jar file from my maven repository. If I put breakpoints in the java
files I have imported the debugger brings up the class file, sometimes
with the source displayed and sometimes with a button prompting to attach
the source.
If I make a change to the source then I get a message from Tomcat to say
that the source is out of date and it terminates. In any case, it doesn't
appear to run my code.
I've checked and unchecked lots of settings in the project properties and
in Windows preferences but I can't seem to get it to work. I've had this
working in the past and didn't seem to have any problem. Anybody got any
ideas on how I can get this to work reliably?
FUDForum. Page generated in 0.34229 seconds
