Home » Modeling » Epsilon » Help on the steps to follow for a model composition.
Help on the steps to follow for a model composition. [message #20353] |
Thu, 18 June 2009 13:07  |
Hi everybody.
I'm taking my first steps with Epsilon (EML mostly), and I'm trying to
compose Model A (from Metamodel A) and Model B (from Metamodel B) into
Model C (from Metamodel C). Two inputs, one output, three different
metamodels.
I have already defined the metamodels, the emfatic file with the
relationships between the input metamodels, and generated the
correspondent ecore model. I also created a ".modelink" indicating the
elements I want to combine (merge).
Now I'm wondering how to continue.
To launch a model merge I need the ".eml" that tells epsilon the source
(base), the aspect, and the target.
I guess I can add the ".modelink" (actually, the model with the
relationships resulting from it) as input, and according to the
relationships modeled in it make the ".eml" merge elements from A with
elements from B into C. Am I right?.
However, I'm not sure on what to do with the ".ecl" matching.
Do I have to make rules for matching elements in Model A with elements
in Model B?, or for matching elements in Model A with elements in Model
C, and then rules for matching elements in Model B with elements in
Model C?.
Which is the correct strategy to make such a composition?.
Thanks in advance.
Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20363 is a reply to message #20353] |
Thu, 18 June 2009 13:24   |
Hi Juan-Pedro,
ECL is used in order to establish a match trace (i.e. the
correspondences on which EML can then merge the models). Since you
already have an intermediate model, you can use ECL to "transform" it to
a match trace.
So if your metamodels are:
-- A.emf --
class A {
attr String name;
-- B.emf --
class B {
ref A a;
attr String annotation;
-- C.emf --
class C {
attr String name;
your ECL comparison will look something like this:
rule AB
match a : AModel!A
with b : BModel!B {
compare {
return b.a = a;
and your EML merging will look like this:
rule AB2C
merge a : AModel!A
with b : BModel!B
into c : CModel!C {
c.name = a.name + '_' b.annotation;
Hope this helps. If not, please let me know.
Dimitris
Juan Pedro Silva wrote:
> Hi everybody.
> metamodels.
> Model C?.
> Thanks in advance.
> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20373 is a reply to message #20363] |
Thu, 18 June 2009 14:01   |
Thank you very much Dimitris for you quick reply.
Is a little more complicated: MMA and MMB elements have no notion of
each other whatsoever.
Is a little more like this:
-- A.emf --
class A {
attr String name;
attr AComplexType propertyA;
-- B.emf --
class B {
attr String name;
attr BComplexType propertyB;
-- C.emf --
class C {
attr String name;
And the only merging would be the one that is stated in the modelink
(particular elements, not all elements from two metaclasses with each
other).
I mean, not all "class A" elements are merged with all "class B"
elements, only the particular merging that was specified.
In the ecl I matched the root elements (which are supposed to be
merged), but the rest of the elements (all from model A, only some from
model B) must be copied into model C.
(I've used ATL/AMW for some time, so I may have biased ideas, please
apologize me if such ideas are wrong!!)
From your answer I get that (not completely sure I'm right) I should
not use the model generated in the modelink for anything, but state the
same in the ecl, right?
(I get this because when you say "transform", I believe there is no
actual means of generating the ecl from the other model, and I should do
it by hand).
If so, should I check for the different ids (names) of the elements and
if thats the correct combination, return true in the compare clause?. I
believe there might be other way to do this.
Thanks for your help.
Dimitris Kolovos escribió:
> Hi Juan-Pedro,
> to a match trace.
> -- A.emf --
> class A {
> attr String name;
> -- B.emf --
> class B {
> ref A a;
> -- C.emf --
> class C {
> attr String name;
> rule AB
> match a : AModel!A
> with b : BModel!B {
> compare {
> return b.a = a;
> rule AB2C
> merge a : AModel!A
> with b : BModel!B
> into c : CModel!C {
> Cheers,
> Dimitris
>> Hi everybody.
>> to compose Model A (from Metamodel A) and Model B (from Metamodel B)
>> into Model C (from Metamodel C). Two inputs, one output, three
>> different metamodels.
>> the elements I want to combine (merge).
>> source (base), the aspect, and the target.
>> with elements from B into C. Am I right?.
>> elements in Model B?, or for matching elements in Model A with
>> elements in Model C, and then rules for matching elements in Model B
>> with elements in Model C?.
>> Thanks in advance.
>> Regards,
>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20383 is a reply to message #20373] |
Thu, 18 June 2009 14:21   |
Hi Juan Pedro,
Oh I see! Yes, in this case, you should compare the names of A and B.
EML will then only merge those pairs of A-B that have been found to be
matching. Now, non-matched instances of A and B will go to the transform
rules of EML which are responsible for handling elements for which no
match has been found. For example your ECL comparison could look
rule AB
match a : AModel!A
with b : BModel!B {
compare : a.name = b.name
and your EML merging like this
rule AB2C
merge a : AModel!A
with b : BModel!B
into c : CModel!C {
c.name = a.name;
-- more merging code here
rule A2A
transform s : BModel!A
to t : CModel!A {
-- no guard needed as all A need to be transformed/copied
-- add the transform/copy code here
rule B2B
transform s : BModel!B
to t : CModel!B {
guard: -- specify which instances of non-matched B should be
transformed/copied
Dimitris
> -- A.emf --
> class A {
> attr String name;
> -- B.emf --
> class B {
> attr String name; attr BComplexType propertyB;
> -- C.emf --
> class C {
> attr String name;
> other).
> it by hand).
>> Hi Juan-Pedro,
>> to a match trace.
>> -- A.emf --
>> class A {
>> attr String name;
>> -- B.emf --
>> class B {
>> ref A a;
>> -- C.emf --
>> class C {
>> attr String name;
>> rule AB
>> match a : AModel!A
>> with b : BModel!B {
>> compare {
>> return b.a = a;
>> rule AB2C
>> merge a : AModel!A
>> with b : BModel!B
>> into c : CModel!C {
>> Cheers,
>> Dimitris
>>> Hi everybody.
>>> Thanks in advance.
>>> Regards,
>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20392 is a reply to message #20383] |
Thu, 18 June 2009 14:34   |
Dimitris, you rock. ;-)
Thanks for your answer.
One more doubt (this one is kind of rhetoric, but just in case): I could
feed the link model to an ETL and use that information, can't I?. I see
that as a bit more elegant (and reusable) than using name matching in
ECL and then EML.
One great add-on to Epsilon in this aspect would be the automatic
generation of an ECL from a modelink. Is it planned?, should I file an
enhancement request into bugzilla for it?.
Regards and thank you,
Juan Pedro.
> Hi Juan Pedro,
> transform rules of EML which are responsible for handling elements for
> which no match has been found. For example your ECL comparison could
> rule AB
> match a : AModel!A
> with b : BModel!B {
> rule AB2C
> merge a : AModel!A
> with b : BModel!B
> into c : CModel!C {
> c.name = a.name;
> rule A2A
> to t : CModel!A {
> rule B2B
> to t : CModel!B {
> transformed/copied
> Cheers,
> Dimitris
>> -- A.emf --
>> class A
>> { attr
>> String name;
>> -- B.emf --
>> class B {
>> -- C.emf --
>> class C {
>> attr String name;
>> other).
>> from model B) must be copied into model C.
>> the same in the ecl, right?
>> do it by hand).
>> and if thats the correct combination, return true in the compare
>> clause?. I believe there might be other way to do this.
>>> Hi Juan-Pedro,
>>> it to a match trace.
>>> -- A.emf --
>>> class A {
>>> attr String name;
>>> -- B.emf --
>>> class B {
>>> ref A a;
>>> -- C.emf --
>>> class C {
>>> attr String name;
>>> rule AB
>>> match a : AModel!A
>>> with b : BModel!B {
>>> compare {
>>> return b.a = a;
>>> rule AB2C
>>> merge a : AModel!A
>>> with b : BModel!B
>>> into c : CModel!C {
>>> Cheers,
>>> Dimitris
>>>> Hi everybody.
>>>> B) into Model C (from Metamodel C). Two inputs, one output, three
>>>> B with elements in Model C?.
>>>> Thanks in advance.
>>>> Regards,
>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20401 is a reply to message #20392] |
Thu, 18 June 2009 14:42   |
Hi Juan Pedro,
Sure. You can use the model from any language of Epsilon. It's probably
a matter of taste more than anything else, but I find it a bit more
flexible to split the process in to: first find the correspondences, and
then do the merging. I've found that this is particularly useful for
debugging complex compositions.
Your idea on generating ECL from a modelink sounds interesting. Could
you please post a concrete example which we can then discuss on?
Dimitris
> ECL and then EML.
> Juan Pedro.
>> Hi Juan Pedro,
>> rule AB
>> match a : AModel!A
>> with b : BModel!B {
>> rule AB2C
>> merge a : AModel!A
>> with b : BModel!B
>> into c : CModel!C {
>> c.name = a.name;
>> rule A2A
>> to t : CModel!A {
>> rule B2B
>> to t : CModel!B {
>> transformed/copied
>> Cheers,
>> Dimitris
>>> -- A.emf --
>>> class A
>>> { attr
>>> String name;
>>> -- B.emf --
>>> class B {
>>> -- C.emf --
>>> class C {
>>> attr String name;
>>> other).
>>> do it by hand).
>>>> Hi Juan-Pedro,
>>>> -- A.emf --
>>>> class A {
>>>> attr String name;
>>>> -- B.emf --
>>>> class B {
>>>> ref A a;
>>>> -- C.emf --
>>>> class C {
>>>> attr String name;
>>>> rule AB
>>>> match a : AModel!A
>>>> with b : BModel!B {
>>>> compare {
>>>> return b.a = a;
>>>> rule AB2C
>>>> merge a : AModel!A
>>>> with b : BModel!B
>>>> into c : CModel!C {
>>>> Cheers,
>>>> Dimitris
>>>>> Hi everybody.
>>>>> Thanks in advance.
>>>>> Regards,
>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #20415 is a reply to message #20401] |
Fri, 19 June 2009 04:56   |
--------------030009030702010506080707
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Hi Dimitris.<br>
Sure, here is one example that I can think of.<br>
<br>
Based on [1], we could deal with the inclusion of access control
concepts into functional models. They use SecureUML + ComponentUML in
particular.<br>
SecureUML is a RBAC metamodel. It defines "Resources", which have
"Actions", and "Permissions" for those actions. "Permissions" are then
associated to "Roles".<br>
ComponentUML is just a basic functional metamodel for component-based
software design.<br>
<br>
Forget about ComponentUML (it has a "Resource" metaclass, which should
be merged with SecureUML's "Resource"). <br>
Think of some other functional metamodel with no concepts of access
control (plain UML, for instance). Take the WS-I Supply Chain
Management Sample [2] as an example. <br>
You want to add access control permissions to purchase orders (only
employees and its owners can read them, only owners can change them),
or services (only registered users can execute them).<br>
You can define generic linking rules from SecureUML to UML (linking
"Resource" to operations, classes, attributes, etc.), but for this
particular case, only some actions are appropriate for some resources
(an execute action has no meaning on a purchase order, and a service
operation has no notion of "owner", for instance). So if you want to
reuse a generic supply chain security model (that corresponds to
SecureUML), and generic merging associations, in this particular case
of supply chain sample, you could make a modelink.<br>
<br>
<img src="cid:part1.06070708.03090105@gmail.com" alt=""><br>
<br>
The picture is not from a supply chain example, but it might be enough
to show my point.<br>
Yo see I define operations and entities (among other things), and I
link particular actions to them. My intention would be to get an ECL
saying that "AnOperation" must be merged with resource "R1" and
"AnEntity" with "R2".<br>
No other entities or operations should be merged. Semantics of the
merge are the same for both merges, weaving the actions into the
operation or entity, and the particular associations with the
permissions. The target metamodel must support this, of course.<br>
<br>
I hope this example is good enough. If not, please tell me and I will
find some other (although I don't know how long it'll take me, I'm on a
tight schedule right now).<br>
Regards,<br>
Juan Pedro<br>
<br>
[1] David Basin, Manuel Clavel, Jürgen Doser, and Marina Egea, <i>A
Metamodel-Based Approach for Analyzing</i><br>
<i>Security-Design Models</i>. Available at:
<a class="moz-txt-link-freetext" href="http://maude.sip.ucm.es/~marina/pubs/BDCE07.pdf">http://maude.sip.ucm.es/~marina/pubs/BDCE07.pdf</a><br>
[2] Martin Chapman, Marc Goodner, Brad Lund, Barbara McKee, Rimas
Rekasius,<i> Supply Chain Management Sample Application<br>
Architecture. </i>Available at:
<a class="moz-txt-link-freetext" href=" http://www.ws-i.org/SampleApplications/SupplyChainManagement /2003-12/SCMArchitecture1.01.pdf"> http://www.ws-i.org/SampleApplications/SupplyChainManagement /2003-12/SCMArchitecture1.01.pdf</a><br>
<br>
<blockquote cite="mid:h1e1pq$p8$3@build.eclipse.org" type="cite">Hi
Juan Pedro,
<br>
<br>
and then do the merging. I've found that this is particularly useful
for debugging complex compositions.
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<blockquote type="cite">Dimitris, you rock. ;-)
<br>
<br>
could feed the link model to an ETL and use that information, can't I?.
I see that as a bit more elegant (and reusable) than using name
matching in ECL and then EML.
<br>
<br>
<br>
<br>
Juan Pedro.
<br>
<br>
<br>
<blockquote type="cite">Hi Juan Pedro,
<br>
<br>
<br>
<br>
rule AB
<br>
match a : AModel!A
<br>
with b : BModel!B {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
rule AB2C
<br>
merge a : AModel!A
<br>
with b : BModel!B
<br>
into c : CModel!C {
<br>
<br>
c.name = a.name;
<br>
<br>
<br>
<br>
<br>
rule A2A
<br>
<br>
to t : CModel!A {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
rule B2B
<br>
<br>
to t : CModel!B {
<br>
<br>
transformed/copied
<br>
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<br>
<blockquote type="cite">Thank you very much Dimitris for you
quick reply.
<br>
<br>
<br>
<br>
-- A.emf --
class A
Re: Help on the steps to follow for a model composition. [message #20426 is a reply to message #20415] |
Fri, 19 June 2009 06:40   |
Hi Juan Pedro,
Thanks for your detailed example! I'll take a closer look at it later on
today and get back to you with comments.
Dimitris
> Hi Dimitris.
> Based on [1], we could deal with the inclusion of access control concepts into
> functional models. They use SecureUML + ComponentUML in particular.
> SecureUML is a RBAC metamodel. It defines "Resources", which have "Actions", and
> "Permissions" for those actions. "Permissions" are then associated to "Roles".
> ComponentUML is just a basic functional metamodel for component-based software
> design.
> Forget about ComponentUML (it has a "Resource" metaclass, which should be merged
> Think of some other functional metamodel with no concepts of access control
> (plain UML, for instance). Take the WS-I Supply Chain Management Sample [2] as
> an example.
> You want to add access control permissions to purchase orders (only employees
> and its owners can read them, only owners can change them), or services (only
> You can define generic linking rules from SecureUML to UML (linking "Resource"
> to operations, classes, attributes, etc.), but for this particular case, only
> some actions are appropriate for some resources (an execute action has no
> meaning on a purchase order, and a service operation has no notion of "owner",
> for instance). So if you want to reuse a generic supply chain security model
> (that corresponds to SecureUML), and generic merging associations, in this
> particular case of supply chain sample, you could make a modelink.
> The picture is not from a supply chain example, but it might be enough to show
> my point.
> Yo see I define operations and entities (among other things), and I link
> particular actions to them. My intention would be to get an ECL saying that
> "AnOperation" must be merged with resource "R1" and "AnEntity" with "R2".
> No other entities or operations should be merged. Semantics of the merge are the
> same for both merges, weaving the actions into the operation or entity, and the
> particular associations with the permissions. The target metamodel must support
> this, of course.
> I hope this example is good enough. If not, please tell me and I will find some
> other (although I don't know how long it'll take me, I'm on a tight schedule
> right now).
> Juan Pedro
> [1] David Basin, Manuel Clavel, Jürgen Doser, and Marina Egea, /A
> Metamodel-Based Approach for Analyzing/
> /Security-Design Models/. Available at:
> [2] Martin Chapman, Marc Goodner, Brad Lund, Barbara McKee, Rimas Rekasius,/
> Architecture. /Available at:
>> Hi Juan Pedro,
>> Sure. You can use the model from any language of Epsilon. It's probably a
>> matter of taste more than anything else, but I find it a bit more flexible to
>> split the process in to: first find the correspondences, and then do the
>> merging. I've found that this is particularly useful for debugging complex
>> compositions.
>> Your idea on generating ECL from a modelink sounds interesting. Could you
>> Cheers,
>> Dimitris
>>> One more doubt (this one is kind of rhetoric, but just in case): I could feed
>>> the link model to an ETL and use that information, can't I?. I see that as a
>>> bit more elegant (and reusable) than using name matching in ECL and then EML.
>>> One great add-on to Epsilon in this aspect would be the automatic generation
>>> of an ECL from a modelink. Is it planned?, should I file an enhancement
>>> Juan Pedro.
>>>> Hi Juan Pedro,
>>>> Oh I see! Yes, in this case, you should compare the names of A and B. EML
>>>> will then only merge those pairs of A-B that have been found to be matching.
>>>> Now, non-matched instances of A and B will go to the transform rules of EML
>>>> which are responsible for handling elements for which no match has been
>>>> found. For example your ECL comparison could look something like this:
>>>> rule AB
>>>> match a : AModel!A
>>>> with b : BModel!B {
>>>> rule AB2C
>>>> merge a : AModel!A
>>>> with b : BModel!B
>>>> into c : CModel!C {
>>>> c.name = a.name;
>>>> rule A2A
>>>> to t : CModel!A {
>>>> rule B2B
>>>> to t : CModel!B {
>>>> transformed/copied
>>>> Cheers,
>>>> Dimitris
>>>>> Is a little more complicated: MMA and MMB elements have no notion of each
>>>>> other whatsoever.
>>>>> -- A.emf -- class
>>>>> A { attr
>>>>> String name;
>>>>> -- B.emf --
>>>>> class B {
>>>>> -- C.emf --
>>>>> class C {
>>>>> attr String name;
>>>>> (particular elements, not all elements from two metaclasses with each other).
>>>>> I mean, not all "class A" elements are merged with all "class B" elements,
>>>>> In the ecl I matched the root elements (which are supposed to be merged),
>>>>> but the rest of the elements (all from model A, only some from model B)
>>>>> From your answer I get that (not completely sure I'm right) I should not
>>>>> use the model generated in the modelink for anything, but state the same in
>>>>> the ecl, right?
>>>>> (I get this because when you say "transform", I believe there is no actual
>>>>> means of generating the ecl from the other model, and I should do it by hand).
>>>>> If so, should I check for the different ids (names) of the elements and if
>>>>>> Hi Juan-Pedro,
>>>>>> ECL is used in order to establish a match trace (i.e. the correspondences
>>>>>> on which EML can then merge the models). Since you already have an
>>>>>> intermediate model, you can use ECL to "transform" it to a match trace.
>>>>>> -- A.emf --
>>>>>> class A {
>>>>>> attr String name;
>>>>>> -- B.emf --
>>>>>> class B {
>>>>>> ref A a;
>>>>>> -- C.emf --
>>>>>> class C {
>>>>>> attr String name;
>>>>>> rule AB
>>>>>> match a : AModel!A
>>>>>> with b : BModel!B {
>>>>>> compare {
>>>>>> return b.a = a;
>>>>>> rule AB2C
>>>>>> merge a : AModel!A
>>>>>> with b : BModel!B
>>>>>> into c : CModel!C {
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> Hi everybody.
>>>>>>> metamodels.
>>>>>>> Do I have to make rules for matching elements in Model A with elements in
>>>>>>> Model B?, or for matching elements in Model A with elements in Model C,
>>>>>>> and then rules for matching elements in Model B with elements in Model C?.
>>>>>>> Thanks in advance.
>>>>>>> Regards,
>>>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #21584 is a reply to message #20426] |
Tue, 30 June 2009 09:18   |
Hi Juan Pedro,
In this case, I'd define an intermediate metamodel where I'd capture the
permitted types of links (Operation<->Resource, Entity<->Resource), each
as a metaclass like this (in Emfatic):
class OperationResourceLink {
ref EntitiesOperations.Operation operation;
ref Resources.Resource resource;
Then I'd create a model that conforms to this metamodel and use Modelink
to populate it. The ECL comparison would then look something like this:
rule Operation2Resource
match o : EntitiesOperations!Operation
with r : Resources!Resource {
compare : Links!OperationResourceLink.all.exists(l|l.operation = o
and l.resource = r)
and then proceed with the merging using EML.
Now if you'd like to generate the above ECL instead of writing it, you
could annotate the metamodel like this:
@link
@link.end
@link.end
and use EGL (the model-to-text language of Epsilon) in order to generate
the ECL above automatically from your metamodel.
I hope this helps...
Dimitris
Dimitris Kolovos wrote:
> Hi Juan Pedro,
> Cheers,
> Dimitris
>> Hi Dimitris.
>> particular.
>> software design.
>> to show my point.
>> a tight schedule right now).
>> Regards,
>> Juan Pedro
>> Rekasius,/ Supply Chain Management Sample Application
>>> Hi Juan Pedro,
>>> probably a matter of taste more than anything else, but I find it a
>>> bit more flexible to split the process in to: first find the
>>> correspondences, and then do the merging. I've found that this is
>>> particularly useful for debugging complex compositions.
>>> Cheers,
>>> Dimitris
>>>> I?. I see that as a bit more elegant (and reusable) than using name
>>>> an enhancement request into bugzilla for it?.
>>>> Juan Pedro.
>>>>> Hi Juan Pedro,
>>>>> B. EML will then only merge those pairs of A-B that have been found
>>>>> to be matching. Now, non-matched instances of A and B will go to
>>>>> the transform rules of EML which are responsible for handling
>>>>> elements for which no match has been found. For example your ECL
>>>>> rule AB
>>>>> match a : AModel!A
>>>>> with b : BModel!B {
>>>>> rule AB2C
>>>>> merge a : AModel!A
>>>>> with b : BModel!B
>>>>> into c : CModel!C {
>>>>> c.name = a.name;
>>>>> rule A2A
>>>>> to t : CModel!A {
>>>>> rule B2B
>>>>> to t : CModel!B {
>>>>> transformed/copied
>>>>> Cheers,
>>>>> Dimitris
>>>>>> of each other whatsoever.
>>>>>> -- A.emf
>>>>>> -- class
>>>>>> A {
>>>>>> attr String name;
>>>>>> -- B.emf --
>>>>>> class B {
>>>>>> -- C.emf --
>>>>>> class C {
>>>>>> attr String name;
>>>>>> modelink (particular elements, not all elements from two
>>>>>> please apologize me if such ideas are wrong!!)
>>>>>> should not use the model generated in the modelink for anything,
>>>>>> but state the same in the ecl, right?
>>>>>> no actual means of generating the ecl from the other model, and I
>>>>>> elements and if thats the correct combination, return true in the
>>>>>> compare clause?. I believe there might be other way to do this.
>>>>>>> Hi Juan-Pedro,
>>>>>>> you already have an intermediate model, you can use ECL to
>>>>>>> -- A.emf --
>>>>>>> class A {
>>>>>>> attr String name;
>>>>>>> -- B.emf --
>>>>>>> class B {
>>>>>>> ref A a;
>>>>>>> -- C.emf --
>>>>>>> class C {
>>>>>>> attr String name;
>>>>>>> rule AB
>>>>>>> match a : AModel!A
>>>>>>> with b : BModel!B {
>>>>>>> compare {
>>>>>>> return b.a = a;
>>>>>>> rule AB2C
>>>>>>> merge a : AModel!A
>>>>>>> with b : BModel!B
>>>>>>> into c : CModel!C {
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> Hi everybody.
>>>>>>>> trying to compose Model A (from Metamodel A) and Model B (from
>>>>>>>> Metamodel B) into Model C (from Metamodel C). Two inputs, one
>>>>>>>> output, three different metamodels.
>>>>>>>> indicating the elements I want to combine (merge).
>>>>>>>> A with elements from B into C. Am I right?.
>>>>>>>> Thanks in advance.
>>>>>>>> Regards,
>>>>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #21675 is a reply to message #21584] |
Fri, 03 July 2009 07:07  |
Thanks Dimitris, I will take a look at this and then get back to you.
Juan Pedro
> Hi Juan Pedro,
> the permitted types of links (Operation<->Resource,
> Entity<->Resource), each as a metaclass like this (in Emfatic):
> Modelink to populate it. The ECL comparison would then look something
> like this:
> and l.resource = r)
> @link
> @link.end
> @link.end
> generate the ECL above automatically from your metamodel.
> Cheers,
> Dimitris
>> Hi Juan Pedro,
>> on today and get back to you with comments.
>> Cheers,
>> Dimitris
>>> Hi Dimitris.
>>> in particular.
>>> component-based software design.
>>> should be merged with SecureUML's "Resource").
>>> them), or services (only registered users can execute them).
>>> resources (an execute action has no meaning on a purchase order, and
>>> a service operation has no notion of "owner", for instance). So if
>>> you want to reuse a generic supply chain security model (that
>>> enough to show my point.
>>> will find some other (although I don't know how long it'll take me,
>>> I'm on a tight schedule right now).
>>> Regards,
>>> Juan Pedro
>>>> Hi Juan Pedro,
>>>> Could you please post a concrete example which we can then discuss on?
>>>> Cheers,
>>>> Dimitris
>>>>> can't I?. I see that as a bit more elegant (and reusable) than
>>>>> file an enhancement request into bugzilla for it?.
>>>>> Juan Pedro.
>>>>>> Hi Juan Pedro,
>>>>>> and B. EML will then only merge those pairs of A-B that have been
>>>>>> found to be matching. Now, non-matched instances of A and B will
>>>>>> go to the transform rules of EML which are responsible for
>>>>>> handling elements for which no match has been found. For example
>>>>>> rule AB
>>>>>> match a : AModel!A
>>>>>> with b : BModel!B {
>>>>>> rule AB2C
>>>>>> merge a : AModel!A
>>>>>> with b : BModel!B
>>>>>> into c : CModel!C {
>>>>>> c.name = a.name;
>>>>>> rule A2A
>>>>>> to t : CModel!A {
>>>>>> rule B2B
>>>>>> to t : CModel!B {
>>>>>> transformed/copied
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> notion of each other whatsoever.
>>>>>>> -- A.emf
>>>>>>> class A
>>>>>>> attr String name;
>>>>>>> -- B.emf --
>>>>>>> class B {
>>>>>>> -- C.emf --
>>>>>>> class C {
>>>>>>> attr String name;
>>>>>>> some from model B) must be copied into model C.
>>>>>>> the compare clause?. I believe there might be other way to do this.
>>>>>>>> Hi Juan-Pedro,
>>>>>>>> -- A.emf --
>>>>>>>> class A {
>>>>>>>> attr String name;
>>>>>>>> -- B.emf --
>>>>>>>> class B {
>>>>>>>> ref A a;
>>>>>>>> -- C.emf --
>>>>>>>> class C {
>>>>>>>> attr String name;
>>>>>>>> rule AB
>>>>>>>> match a : AModel!A
>>>>>>>> with b : BModel!B {
>>>>>>>> compare {
>>>>>>>> return b.a = a;
>>>>>>>> rule AB2C
>>>>>>>> merge a : AModel!A
>>>>>>>> with b : BModel!B
>>>>>>>> into c : CModel!C {
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> Hi everybody.
>>>>>>>>> the relationships between the input metamodels, and generated
>>>>>>>>> the correspondent ecore model. I also created a ".modelink"
>>>>>>>>> the source (base), the aspect, and the target.
>>>>>>>>> the relationships resulting from it) as input, and according
>>>>>>>>> to the relationships modeled in it make the ".eml" merge
>>>>>>>>> elements from A with elements from B into C. Am I right?.
>>>>>>>>> Thanks in advance.
>>>>>>>>> Regards,
>>>>>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569390 is a reply to message #20353] |
Hi Juan-Pedro,
a match trace.
-- A.emf --
class A {
attr String name;
-- B.emf --
class B {
ref A a;
-- C.emf --
class C {
attr String name;
rule AB
match a : AModel!A
with b : BModel!B {
compare {
return b.a = a;
rule AB2C
merge a : AModel!A
with b : BModel!B
into c : CModel!C {
Dimitris
> Hi everybody.
> metamodels.
> Model C?.
> Thanks in advance.
> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569400 is a reply to message #20363] |
-- A.emf --
class A {
attr String name;
-- B.emf --
class B {
attr String name;
-- C.emf --
class C {
attr String name;
other).
it by hand).
> Hi Juan-Pedro,
> to a match trace.
> -- A.emf --
> class A {
> attr String name;
> -- B.emf --
> class B {
> ref A a;
> -- C.emf --
> class C {
> attr String name;
> rule AB
> match a : AModel!A
> with b : BModel!B {
> compare {
> return b.a = a;
> rule AB2C
> merge a : AModel!A
> with b : BModel!B
> into c : CModel!C {
> Cheers,
> Dimitris
>> Hi everybody.
>> Thanks in advance.
>> Regards,
>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569417 is a reply to message #20373] |
Hi Juan Pedro,
rule AB
match a : AModel!A
with b : BModel!B {
rule AB2C
merge a : AModel!A
with b : BModel!B
into c : CModel!C {
c.name = a.name;
rule A2A
to t : CModel!A {
rule B2B
to t : CModel!B {
transformed/copied
Dimitris
> -- A.emf --
> class A {
> attr String name;
> -- B.emf --
> class B {
> -- C.emf --
> class C {
> attr String name;
> other).
> it by hand).
>> Hi Juan-Pedro,
>> to a match trace.
>> -- A.emf --
>> class A {
>> attr String name;
>> -- B.emf --
>> class B {
>> ref A a;
>> -- C.emf --
>> class C {
>> attr String name;
>> rule AB
>> match a : AModel!A
>> with b : BModel!B {
>> compare {
>> return b.a = a;
>> rule AB2C
>> merge a : AModel!A
>> with b : BModel!B
>> into c : CModel!C {
>> Cheers,
>> Dimitris
>>> Hi everybody.
>>> Thanks in advance.
>>> Regards,
>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569447 is a reply to message #20383] |
ECL and then EML.
Juan Pedro.
> Hi Juan Pedro,
> rule AB
> match a : AModel!A
> with b : BModel!B {
> rule AB2C
> merge a : AModel!A
> with b : BModel!B
> into c : CModel!C {
> c.name = a.name;
> rule A2A
> to t : CModel!A {
> rule B2B
> to t : CModel!B {
> transformed/copied
> Cheers,
> Dimitris
>> -- A.emf --
>> class A
>> { attr
>> String name;
>> -- B.emf --
>> class B {
>> -- C.emf --
>> class C {
>> attr String name;
>> other).
>> do it by hand).
>>> Hi Juan-Pedro,
>>> -- A.emf --
>>> class A {
>>> attr String name;
>>> -- B.emf --
>>> class B {
>>> ref A a;
>>> -- C.emf --
>>> class C {
>>> attr String name;
>>> rule AB
>>> match a : AModel!A
>>> with b : BModel!B {
>>> compare {
>>> return b.a = a;
>>> rule AB2C
>>> merge a : AModel!A
>>> with b : BModel!B
>>> into c : CModel!C {
>>> Cheers,
>>> Dimitris
>>>> Hi everybody.
>>>> Thanks in advance.
>>>> Regards,
>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569473 is a reply to message #20392] |
Hi Juan Pedro,
Dimitris
> ECL and then EML.
> Juan Pedro.
>> Hi Juan Pedro,
>> rule AB
>> match a : AModel!A
>> with b : BModel!B {
>> rule AB2C
>> merge a : AModel!A
>> with b : BModel!B
>> into c : CModel!C {
>> c.name = a.name;
>> rule A2A
>> to t : CModel!A {
>> rule B2B
>> to t : CModel!B {
>> transformed/copied
>> Cheers,
>> Dimitris
>>> -- A.emf --
>>> class A
>>> { attr
>>> String name;
>>> -- B.emf --
>>> class B {
>>> -- C.emf --
>>> class C {
>>> attr String name;
>>> other).
>>> do it by hand).
>>>> Hi Juan-Pedro,
>>>> -- A.emf --
>>>> class A {
>>>> attr String name;
>>>> -- B.emf --
>>>> class B {
>>>> ref A a;
>>>> -- C.emf --
>>>> class C {
>>>> attr String name;
>>>> rule AB
>>>> match a : AModel!A
>>>> with b : BModel!B {
>>>> compare {
>>>> return b.a = a;
>>>> rule AB2C
>>>> merge a : AModel!A
>>>> with b : BModel!B
>>>> into c : CModel!C {
>>>> Cheers,
>>>> Dimitris
>>>>> Hi everybody.
>>>>> Thanks in advance.
>>>>> Regards,
>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #569505 is a reply to message #20401] |
<html>
<head>
</head>
Hi Dimitris.<br>
<br>
particular.<br>
<br>
<br>
<br>
<br>
Regards,<br>
Juan Pedro<br>
<br>
<br>
Juan Pedro,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Juan Pedro.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
rule AB
<br>
match a : AModel!A
<br>
with b : BModel!B {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
rule AB2C
<br>
merge a : AModel!A
<br>
with b : BModel!B
<br>
into c : CModel!C {
<br>
<br>
c.name = a.name;
<br>
<br>
<br>
<br>
<br>
rule A2A
<br>
<br>
to t : CModel!A {
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
rule B2B
<br>
<br>
to t : CModel!B {
<br>
<br>
transformed/copied
<br>
<br>
<br>
<br>
<br>
<br>
Dimitris
<br>
<br>
<br>
<br>
quick reply.
<br>
<br>
<br>
<br>
-- A.emf --
class A
Re: Help on the steps to follow for a model composition. [message #569540 is a reply to message #20415] |
Hi Juan Pedro,
Dimitris
> Hi Dimitris.
> design.
> an example.
> my point.
> this, of course.
> right now).
> Juan Pedro
>> Hi Juan Pedro,
>> compositions.
>> Cheers,
>> Dimitris
>>> Juan Pedro.
>>>> Hi Juan Pedro,
>>>> rule AB
>>>> match a : AModel!A
>>>> with b : BModel!B {
>>>> rule AB2C
>>>> merge a : AModel!A
>>>> with b : BModel!B
>>>> into c : CModel!C {
>>>> c.name = a.name;
>>>> rule A2A
>>>> to t : CModel!A {
>>>> rule B2B
>>>> to t : CModel!B {
>>>> transformed/copied
>>>> Cheers,
>>>> Dimitris
>>>>> other whatsoever.
>>>>> -- A.emf -- class
>>>>> A { attr
>>>>> String name;
>>>>> -- B.emf --
>>>>> class B {
>>>>> -- C.emf --
>>>>> class C {
>>>>> attr String name;
>>>>> the ecl, right?
>>>>>> Hi Juan-Pedro,
>>>>>> -- A.emf --
>>>>>> class A {
>>>>>> attr String name;
>>>>>> -- B.emf --
>>>>>> class B {
>>>>>> ref A a;
>>>>>> -- C.emf --
>>>>>> class C {
>>>>>> attr String name;
>>>>>> rule AB
>>>>>> match a : AModel!A
>>>>>> with b : BModel!B {
>>>>>> compare {
>>>>>> return b.a = a;
>>>>>> rule AB2C
>>>>>> merge a : AModel!A
>>>>>> with b : BModel!B
>>>>>> into c : CModel!C {
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> Hi everybody.
>>>>>>> metamodels.
>>>>>>> Thanks in advance.
>>>>>>> Regards,
>>>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #570325 is a reply to message #20426] |
Hi Juan Pedro,
and l.resource = r)
@link
@link.end
@link.end
Dimitris
> Hi Juan Pedro,
> Cheers,
> Dimitris
>> Hi Dimitris.
>> particular.
>> software design.
>> to show my point.
>> Regards,
>> Juan Pedro
>>> Hi Juan Pedro,
>>> Cheers,
>>> Dimitris
>>>> Juan Pedro.
>>>>> Hi Juan Pedro,
>>>>> rule AB
>>>>> match a : AModel!A
>>>>> with b : BModel!B {
>>>>> rule AB2C
>>>>> merge a : AModel!A
>>>>> with b : BModel!B
>>>>> into c : CModel!C {
>>>>> c.name = a.name;
>>>>> rule A2A
>>>>> to t : CModel!A {
>>>>> rule B2B
>>>>> to t : CModel!B {
>>>>> transformed/copied
>>>>> Cheers,
>>>>> Dimitris
>>>>>> -- A.emf
>>>>>> -- class
>>>>>> A {
>>>>>> attr String name;
>>>>>> -- B.emf --
>>>>>> class B {
>>>>>> -- C.emf --
>>>>>> class C {
>>>>>> attr String name;
>>>>>>> Hi Juan-Pedro,
>>>>>>> -- A.emf --
>>>>>>> class A {
>>>>>>> attr String name;
>>>>>>> -- B.emf --
>>>>>>> class B {
>>>>>>> ref A a;
>>>>>>> -- C.emf --
>>>>>>> class C {
>>>>>>> attr String name;
>>>>>>> rule AB
>>>>>>> match a : AModel!A
>>>>>>> with b : BModel!B {
>>>>>>> compare {
>>>>>>> return b.a = a;
>>>>>>> rule AB2C
>>>>>>> merge a : AModel!A
>>>>>>> with b : BModel!B
>>>>>>> into c : CModel!C {
>>>>>>> Cheers,
>>>>>>> Dimitris
>>>>>>>> Hi everybody.
>>>>>>>> Thanks in advance.
>>>>>>>> Regards,
>>>>>>>> Juan Pedro
Re: Help on the steps to follow for a model composition. [message #570350 is a reply to message #21584] |
Juan Pedro
> Hi Juan Pedro,
> like this:
> and l.resource = r)
> @link
> @link.end
> @link.end
> Cheers,
> Dimitris
>> Hi Juan Pedro,
>> Cheers,
>> Dimitris
>>> Hi Dimitris.
>>> in particular.
>>> Regards,
>>> Juan Pedro
>>>> Hi Juan Pedro,
>>>> Cheers,
>>>> Dimitris
>>>>> Juan Pedro.
>>>>>> Hi Juan Pedro,
>>>>>> rule AB
>>>>>> match a : AModel!A
>>>>>> with b : BModel!B {
>>>>>> rule AB2C
>>>>>> merge a : AModel!A
>>>>>> with b : BModel!B
>>>>>> into c : CModel!C {
>>>>>> c.name = a.name;
>>>>>> rule A2A
>>>>>> to t : CModel!A {
>>>>>> rule B2B
>>>>>> to t : CModel!B {
>>>>>> transformed/copied
>>>>>> Cheers,
>>>>>> Dimitris
>>>>>>> -- A.emf
>>>>>>> class A
>>>>>>> attr String name;
>>>>>>> -- B.emf --
>>>>>>> class B {
>>>>>>> -- C.emf --
>>>>>>> class C {
>>>>>>> attr String name;
>>>>>>>> Hi Juan-Pedro,
>>>>>>>> -- A.emf --
>>>>>>>> class A {
>>>>>>>> attr String name;
>>>>>>>> -- B.emf --
>>>>>>>> class B {
>>>>>>>> ref A a;
>>>>>>>> -- C.emf --
>>>>>>>> class C {
>>>>>>>> attr String name;
>>>>>>>> rule AB
>>>>>>>> match a : AModel!A
>>>>>>>> with b : BModel!B {
>>>>>>>> compare {
>>>>>>>> return b.a = a;
>>>>>>>> rule AB2C
>>>>>>>> merge a : AModel!A
>>>>>>>> with b : BModel!B
>>>>>>>> into c : CModel!C {
>>>>>>>> Cheers,
>>>>>>>> Dimitris
>>>>>>>>> Hi everybody.
>>>>>>>>> Thanks in advance.
>>>>>>>>> Regards,
>>>>>>>>> Juan Pedro
Current Time: Mon Jul 14 07:26:24 EDT 2025
Powered by FUDForum. Page generated in 0.08667 seconds
