Home » Archived » BIRT » Birt2.1.1 problem with Xerces in Weblogic
Birt2.1.1 problem with Xerces in Weblogic [message #210553] Wed, 10 January 2007 20:33 Go to next message
The Birt example app WebViewerExample can run correctly in Weblogic8.1.5
and Weblogic9.2.
But if I put Xerces(xml-apis.jar,xercesImpl.jar) into
WebViewerExample\WEB-INF\lib directory, Birt show me
"java.lang.ClassCastException" message. Even i use the same version as
"WebViewerExample\WEB-INF\platform\plugins\org.apache.xerces ",the same
error occured.
How to resolve this problem, for my web application need Xerces jars at
\WEB-INF\lib directory.
There's no this problem in Tomcat.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #210658 is a reply to message #210553] Thu, 11 January 2007 10:58 Go to previous messageGo to next message
In fact, BIRT also use Xerces, so adding one more lib in web-inf is going
to cause some problems. BIRT is using the OSGi classloading to load Xerces,
so I would suggest you copy the xerces jar lib from the platform/plugins
dir in the WEB-INF/lib. Normally it should work. Let me know if you still
have problems.
David
> Weblogic8.1.5
> and Weblogic9.2.
> error occured.
> at \WEB-INF\lib directory.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #211006 is a reply to message #210658] Thu, 11 January 2007 20:39 Go to previous messageGo to next message
Thanks for your help.
I've tried as you say, but it has the same error.
In fact, if I delete the platform/plugins/org.apache.xerces, the same
error occured; and if I delete platform/plugins/org.apache.xerces
directory and delete Xerces lib from WEB-INF/lib also, Birt works correctly.
I surmise that some function cann't use Xerces lib from WEB-INF/lib,it's
some problem about ClassLoader. But I cann't know more about this
problem. How can I resolve this problem? Is it a bug of Birt(or Xerces,
or digester, or other component)?
David Michonneau :
> going to cause some problems. BIRT is using the OSGi classloading to
> load Xerces, so I would suggest you copy the xerces jar lib from the
> platform/plugins dir in the WEB-INF/lib. Normally it should work. Let me
> know if you still have problems.
> David
>> Weblogic8.1.5
>> and Weblogic9.2.
>> error occured.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #211168 is a reply to message #211006] Fri, 12 January 2007 07:23 Go to previous messageGo to next message
Are you using the weblogic.xml from the runtime package? It looks like it's
loading classes from weblogic internal libraries, which conflict with the
BIRT ones. The normal fix is to have prefer-web-inf-classes set to true in
weblogic.xml of the web app.
David
> correctly.
> WEB-INF/lib,it's some problem about ClassLoader. But I cann't know
> more about this problem. How can I resolve this problem? Is it a bug
> of Birt(or Xerces, or digester, or other component)?
> David Michonneau :
>> me know if you still have problems.
>> Thanks,
>> David
>>> Weblogic8.1.5
>>> and Weblogic9.2.
>>> as
>>> same
>>> error occured.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #211222 is a reply to message #210553] Fri, 12 January 2007 09:14 Go to previous messageGo to next message
We are trying to get BIRT211 running with weblogic 8.1.5 and have not
been able to do so. If possible, please share any special customization
or configuration that was required to get it working?
shweta
> and Weblogic9.2.
> error occured.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #211499 is a reply to message #211168] Mon, 15 January 2007 01:10 Go to previous messageGo to next message
Thanks for your fervor.
The WebViewerExample is a well defined application. The
prefer-web-inf-classes parameter is already exist in the sample.
I think this is a bug, and I've submit a bug report to Birt project.
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=170299
David Michonneau :
> it's loading classes from weblogic internal libraries, which conflict
> with the BIRT ones. The normal fix is to have prefer-web-inf-classes set
> to true in weblogic.xml of the web app.
> David
>> correctly.
>> David Michonneau :
>>> Thanks,
>>> David
>>>> Weblogic8.1.5
>>>> and Weblogic9.2.
>>>> as
>>>> same
>>>> error occured.
Re: Birt2.1.1 problem with Xerces in Weblogic [message #211507 is a reply to message #211222] Mon, 15 January 2007 05:18 Go to previous message
The WebViewerExample can run with weblogic 8.1.5 without any modify. You
can try it.
shweta kautia :
> shweta
>> and Weblogic9.2.
>> error occured.
Previous Topic:Inserting data into text using <value-of>
Next Topic:Deployed WebViewer in SWING Application
Current Time: Sat Jul 26 14:08:20 EDT 2025
Powered by FUDForum. Page generated in 0.09082 seconds
