Home » Modeling » GMF (Graphical Modeling Framework) » Need some EditPolicy related help
Need some EditPolicy related help [message #210527] Thu, 06 November 2008 02:42 Go to next message
Originally posted by: manojm.blr.interrasystems.com
Hi! All,
I have used DnD feature for dragging an element from treeviewer to
GMF editor.
When drop is occuring on rectangular figure (inside editor), i want to
create another child rectangular figure in it.
Could you please suggest - how to do that? Which EditPolicy should I
install?
If possible, please provide some code snippet.
Manoj
Re: Need some EditPolicy related help [message #210577 is a reply to message #210527] Thu, 06 November 2008 06:46 Go to previous messageGo to next message
Hello Manoj,
Try to handling D&D request for this particular child figure. You have to
install DiagramDragDropEditPolicy inside corresponding XXXEditPart.createDefaultEditPolicies()
method and handle drop request there. As an example you can use XXEditPart
generated for the diagram element - it has corresponding EditPolicy generated,
but you have to completely modify getDropObjectsCommand() to return a command
creating "copy" of the element being dropped.
Alex Shatalin
Re: Need some EditPolicy related help [message #210600 is a reply to message #210577] Thu, 06 November 2008 07:44 Go to previous messageGo to next message
Thanks Alex,
Manoj
Alex Shatalin wrote:
> Hello Manoj,
> to install DiagramDragDropEditPolicy inside corresponding
> XXXEditPart.createDefaultEditPolicies() method and handle drop request
> there. As an example you can use XXEditPart generated for the diagram
> element - it has corresponding EditPolicy generated, but you have to
> completely modify getDropObjectsCommand() to return a command creating
> Alex Shatalin
Re: Need some EditPolicy related help [message #210663 is a reply to message #210577] Thu, 06 November 2008 23:30 Go to previous messageGo to next message
Hi! Alex,
Could you please provide some code snippet or any reference to the same?
Manoj
> Hello Manoj,
> Alex Shatalin
Re: Need some EditPolicy related help [message #210789 is a reply to message #210663] Mon, 10 November 2008 06:41 Go to previous message
Hello Manoj,
> same?
Did you seen XXXEditPart.createDefaultEditPolicies() for the diagram EditPart
generated by GMF? You have to generate diagram code with shortcuts feature
enabled and then you’ll see examples of necessary code there.
Alex Shatalin
Previous Topic:Logic to calculate bendpoints for a polyline connection in rectilinear routing
Next Topic:Cannot open logic example diagram
Current Time: Sat Jul 26 15:16:08 EDT 2025
Powered by FUDForum. Page generated in 0.06742 seconds
