Home » Eclipse Projects » GEF » Search connection under mouse
Search connection under mouse [message #210393] Mon, 27 February 2006 09:16 Go to next message
Originally posted by: fangrey.mail.ru
How I can determine, is mouse pointer locate in the neighbourhood of connection?
I thus far make as follows:
IFigure connectionLayer = ((ScalableFreeformRootEditPart) (getCurrentViewer().getRootEditPart())).
getLayer(LayerConstants.CONNECTION_LAYER);
      int delta = 5;
	IFigure findingFigure = null;
	int xScale = 0;
	int yScale = 0;
	for (int i = -delta; i <= delta; i++) {
		for (int j = -delta; j <= delta; j++) {
			Point relativePosition = getLocation();
			findingFigure = connectionLayer.findFigureAt(relativePosition.x + i, relativePosition.y + j);
			if (findingFigure != null) {
				yScale = j;
				break;
			xScale = i;
			break;
if (findingFigure != null && findingFigure instanceof PolylineConnection) {
	Object findingEditPart = getCurrentViewer().  findObjectAt(new Point(getLocation().x + xScale,
  getLocation().y + yScale));
But this solution does not work with the scaled images
Re: Search connection under mouse [message #210405 is a reply to message #210393] Mon, 27 February 2006 14:32 Go to previous message
Connections already have a delta +/- (2 + 1/2 linewidth) pixels (at 100%).
If you want this to be bigger, you could make the width of the line larger,
but paint at a smaller width. You could also override containsPoint to make
the threshold larger.
Your for loop has some issues.
"FanGrey" <fangrey@mail.ru> wrote in message
news:13779333.1141049833123.JavaMail.root@cp1.javalobby.org...
> connection?
>      int delta = 5;
> int xScale = 0;
> int yScale = 0;
> yScale = j;
> break;
> xScale = i;
> break;
Previous Topic:snapToGrip not working
Next Topic:Newbie Question Regarding The Display of Model
Current Time: Sat Jul 26 15:18:31 EDT 2025
Powered by FUDForum. Page generated in 0.03343 seconds
