Home » Eclipse Projects » GEF » PropertySheet
PropertySheet [message #210226] Thu, 23 February 2006 08:07 Go to next message
Originally posted by: naughtyboy.symbi.gmail.com
I have a issue with the Property Sheet .
I have used IBM RedBook Example (Page no 206),as the base for the property
sheet.
Now according to the model i have Pool, which has a reference to process.
Now i want to incoroporate the features of process inside pool's
propertysheet.
If i do the way it is done in the example , in the place of process i get
the instance of process that i have added to pool. But what i want is
instead of just the instance all the features i.e attributes should be
visible in the propertysheet, so that i can edit them from the property
sheet at the same time as the pool
I welcome ideas & suggestions.
Sending you a link which gives a view of our EMF model
( http://geocities.com/onlymohabbat/Pool_Process_23_feb_06.JPG)
Satyam
Re: PropertySheet [message #210242 is a reply to message #210226] Thu, 23 February 2006 09:40 Go to previous message
If you want properties of a property, then the object that is returned as
the current value needs to be an IPropertySource. So, you should be able to
just wrap the process in the propertysrouce implementation that you have.
"Satyam Shukla" <naughtyboy.symbi@gmail.com> wrote in message
news:80e1d9a00b40a3495edd6be4f27a4722$1@www.eclipse.org...
> sheet.
> propertysheet.
> Thanks
> Satyam
Previous Topic:ComboBoxDescriptor
Next Topic:ANN: PropertySheet is provided by eclipse.platform (org.eclipse.ui)
Current Time: Mon Jun 30 15:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.04603 seconds
