Home » Eclipse Projects » Remote Application Platform (RAP) » Localized content in Browser widget
Localized content in Browser widget [message #20290] |
Thu, 26 April 2007 02:25  |
Originally posted by: roberto.sanchez.autonomind.com
--------------060805050406010104090504
Hi all, I'm having problems with "Spanish characters" when I try to
display them in Browser control.
I attach a html example file (test-locale.html) with these characters,
and a screenshot of my app with the result in a Browser control.
I'm using Windows XP (in Spanish language) and in Both tipical browsers,
Firefox and IExplorer, I can see this file without problems.
I set "charset" in file and in code when I read this file to convert to
String.
My code to pass it to Browser content is:
public static String resource2text(String resource) {
// I've used StringBuffer too, to store the file, with the same result
StringWriter sw = new StringWriter();
if (Util.class.getResource(resource) != null) {
BufferedInputStream reader = null;
try {
reader = new
BufferedInputStream(Util.class.getResourceAsStream(resource) );
byte[] buf = new byte[1024];
int bytes = 0;
do {
bytes = reader.read(buf);
// I've used to ways to instantiate String object, setting charset and
without set charset. My default charset in JVM is correctly setted.
sw.write(new String(buf, 0, bytes));
// sw.write(new String(buf, 0, bytes, "iso-8859-1"));
} while(bytes == buf.length);
} catch (IOException e) {
e.printStackTrace();
} finally {
if (reader != null)
try {reader.close(); } catch (IOException e) { e.printStackTrace(); }
return sw.toString();
Content-Type: text/html; charset=ISO-8859-1;
name="test-locale.html"
Content-Disposition: inline;
filename="test-locale.html"
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=iso-8859-1" />
<title>TEST</title>
</head>
<body>
<H2>Spanish characters:</h2>
<H3>á ==
Re: Localized content in Browser widget [message #20315 is a reply to message #20290] |
Thu, 26 April 2007 05:06   |
Hello again, I think that my problem is in BrowserLCA.registerHtml in
this method It is hardcoded "UTF-8" as charset for html content, I
wonder If could be possible customize content charset from Browser widget.
I don't know if this is planned or not, In any case I could create an
Enhancenment/Bug entry in Eclipse-Bugzilla for Browser widget.
Let me know what do you think about.
Regards.
Roberto.
//PD: The method where I think my problem is located (BrowserLCA):
private static String registerHtml( final String html ) throws
IOException {
String name = createUrlFromHtml( html );
byte[] bytes = html.getBytes( "UTF-8" );
InputStream inputStream = new ByteArrayInputStream( bytes );
try {
// TODO [rh] ResourceManager should be alble to deregister a
resource,
// thus we could cleanup the here registered resource when text
// is changed and in renderDispose
ResourceManager.getInstance().register( name, inputStream );
} finally {
inputStream.close();
return ResourceManager.getInstance().getLocation( name );
> String.
> try {
> reader = new
> int bytes = 0;
> do {
> } finally {
> if (reader != null)
> Spanish characters:
> á == á
> é == é
> í == í
> ó == ó
> ú == ú
> ñ == ñ
Re: Localized content in Browser widget [message #20405 is a reply to message #20290] |
Fri, 27 April 2007 09:35   |
Originally posted by: rherrmann.innoopract.com
Hi Roberto,
from what I understand You need to specify the charset when You read the
resource. You may use an InputStreamReader( stream, "iso-8859-1" ) to
read the content and then use Browser.setText.
If that doesn't do the trick, feel free to open a bug report with a
test-case or code snippet attached.
Rüdiger
> String.
> try {
> reader = new
> int bytes = 0;
> do {
> } finally {
> if (reader != null)
> Spanish characters:
> á == á
> é == é
> í == í
> ó == ó
> ú == ú
> ñ == ñ
Re: Localized content in Browser widget [message #20414 is a reply to message #20405] |
Fri, 27 April 2007 10:09   |
Hi Rüdiger, I've tested it but It doesn't work, my code (with your
recomendations):
InputStreamReader reader = null;
try {
reader = new
InputStreamReader(Util.class.getResourceAsStream(resource), "iso-8859-1");
char[] buf = new char[2048];
int chars = 0;
do {
chars = reader.read(buf);
sw.write(new String(buf));
} while(chars == buf.length);
} finally {
if (reader != null)
mybrowser.setText(sw.toString());
Besides, in debug mode, In Watch View the expression "sw.toString()"
shows the correct characters now and before, so I think that It's a
Browser charset problem
I'm going to create a new Entry in bugzilla. Thanks for your help.
Regards.
Rüdiger Herrmann wrote:
> Hi Roberto,
> Cheers,
> Rüdiger
>> browsers, Firefox and IExplorer, I can see this file without problems.
>> to String.
>> try {
>> reader = new
>> int bytes = 0;
>> do {
>> } while(bytes == buf.length); }
>> } finally {
>> if (reader != null)
>> } return sw.toString();
>> Spanish characters:
>> á == á
>> é == é
>> í == í
>> ó == ó
>> ú == ú
>> ñ == ñ
Re: Localized content in Browser widget [message #21029 is a reply to message #20405] |
Mon, 30 April 2007 05:24  |
I've created a new bug entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184670
Regards.
Roberto.
> Hi Roberto,
> Cheers,
> Rüdiger
>> to String.
>> try {
>> reader = new
>> int bytes = 0;
>> do {
>> } finally {
>> if (reader != null)
>> Spanish characters:
>> á == á
>> é == é
>> í == í
>> ó == ó
>> ú == ú
>> ñ == ñ
Current Time: Fri Jul 18 11:28:17 EDT 2025
Powered by FUDForum. Page generated in 0.07388 seconds
