Home » Eclipse Projects » GEF » Questions about Logic Editor Example in GEF
Questions about Logic Editor Example in GEF [message #20281] Tue, 24 September 2002 11:28 Go to next message
I have the following questions in Logic Editor Example:
1. The LED component has popup menu commands ("Increment", "Decremenet"),
can you tell me where in the code adds those command to the LED component?
The OR, XOR,... gate does NOT have those commands.
2. Where in the code draws the line for the Connection? If I want to change
the line style (e.g. make it a dash line, or an arrow line), where should I
look?
3. If I put components (e.g. XOR gate, OR gate) om Flow Container, it layout
in a flow layout. Can I change it so that it keeps the co-ordinates (the
ones tha user draw)?
Thank you for your help.
Sam
Re: Questions about Logic Editor Example in GEF [message #20299 is a reply to message #20281] Tue, 24 September 2002 13:07 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Sam Cheung" <scheung@novarra.com> wrote in message
news:ampv7u$3e2$1@rogue.oti.com...
The LogicContextMenuProvider is adding these to the menu.
change
I
> look?
WireEditPart.createFigure()
layout
Not in the example.
> Sam
Re: Questions about Logic Editor Example in GEF [message #20325 is a reply to message #20299] Tue, 24 September 2002 17:32 Go to previous messageGo to next message
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:amq50p$6s8$1@rogue.oti.com...
> layout
> Not in the example.
Randy,
Thanks.
But the LogicFlowContainer is a subclass of LogicDiagram, and logicDiagram
keeps the co-ordinate of each components in the diagram, could you please
tell me why the Flow Container does not?
Thank you.
Sam
Re: Questions about Logic Editor Example in GEF [message #20335 is a reply to message #20299] Tue, 24 September 2002 17:39 Go to previous messageGo to next message
And who can I support "Drag-and-Drop" components? In current example, I need
to click on the palette menu to select the components, and I click again on
the diagram to draw it. How can I change the example to do drag-and-drop? I
drag a component and when I drop it, it will place the component on the
location of where I release the mouse.
p.s. I am trying to learn the GEF by understanding /changing the logic
editor example. Thanks for any help.
> > Hi,
"Decremenet"),
component?
> change
should
> I
> > look?
> layout
> Not in the example.
> > Sam
Re: Questions about Logic Editor Example in GEF [message #20355 is a reply to message #20325] Tue, 24 September 2002 18:46 Go to previous messageGo to next message
Look at LogicFlowContainerEditPart.createFigure(). It uses a FlowLayout for its
figure. LogicDiagramEditPart uses FreeformLayout (a subclass of XYLayout).
Eric
news:amqkhr$ha0$1@rogue.oti.com...
> > layout
> > Not in the example.
> Randy,
> Thanks.
> Thank you.
> Sam
Re: Questions about Logic Editor Example in GEF [message #20365 is a reply to message #20325] Tue, 24 September 2002 18:59 Go to previous message
This is an example. We have a "flow" container not because it makes sense,
but to demonstrate the FlowLayout and the EditPolicy for it. Ignore the
details of the model ;-)
Previous Topic:Draw curve in GEF
Next Topic:Outline View in the Logic Editor Example
Current Time: Sat Jun 07 11:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
