Re: Scanning Root Directory Gives Java Error [message #210113 is a reply to message #209975] |
Thu, 10 May 2007 13:19 |
Originally posted by: eclipse5.rizzoweb.com
Cynthia wrote:
> Hello,
> I am trying to use the import wizard from File>Import>General>Existing
> Projects into Workspace.
> I then select the root directory to be the c:\ directory and click enter.
> It seems that the c:\ directory might be too big of a search area.
> The projects I know exist in c:\ don't show up in my Projects list and I get
> the error pasted below listed in my Error Log.
You're trying to import the entire contents of your c: drive?!
You need to use the Browse... button to individually select each
directory that holds a project, not the entire drive.
Hope this helps,
Eric
FUDForum. Page generated in 0.05362 seconds
