Profiling Crash/Mem leak not seen? [message #20265] |
Wed, 15 June 2005 23:07  |
Originally posted by: lbmes2000.yahoo.com
Hi all
Im using tptp 4.0. When I start memory profiling everything works fine --
i am able to call up instance info and whatnot. After a number of
refreshes, however, the memory profiler claims there is no info and I have
to start recollecting info, losing all the previosly gathered info.
Eventually both eclipse and the program suffer OutOfMemoryError meessages.
While the profiler is working, it does not appear that the program is
leaking memory, the number of live instances for any particular class does
not grow. I get the OOM for the application when I run it from the
command line as well. I am running under linux. I am not clicking the
option that warns about exponential memory growth (instance level info),
and I do not have any limits set. Here is what shows up on the command
line when eclipse collapses.
java.lang.OutOfMemoryError
Unhandled event loop exception
Reason:
Failed to execute runnable (java.lang.OutOfMemoryError)
*** SWT nested exception
Reason:
Re: Profiling Crash/Mem leak not seen? [message #20293 is a reply to message #20265] |
Fri, 24 June 2005 03:26  |
Hi Michael,
There is a possibility that you are filtering out the type of instance that
causes the OOM. Check your filters under the profiler to ensure that you
are not filtering possible candidates that maybe causing the OOM.
You can adjust your filter under the profiler launcher > Profiling tab >
Select the desired profiling set > Click Edit > Next > Next > You can set
your filter set under this page
Sorry for the delay in response.
"Michael Harris" <lbmes2000@yahoo.com> wrote in message
news:affada3243a6dd210647e28f426b2994$1@www.eclipse.org...
> Hi all
> Reason:
> Reason:
FUDForum. Page generated in 0.03385 seconds
