Home » Language IDEs » C / C++ IDE (CDT) » Includes per configuration
Includes per configuration [message #209689] Thu, 14 February 2008 08:39 Go to next message
Originally posted by: sebastian.huber.embedded-brains.de
I set up a standard makefile project and want to use different
configurations to build artifacts for different hardware boards in a
cross-compiler environment. The build process works fine. Each
configuration uses header files in the standard include paths provided
by the cross-compiler (gcc) and header files in board specific include
paths. I added the path settings to Project Properties->C/C++
General->Paths and Symbols->Includes. The problem is now that if I
switch the configuration the project->Includes in the Project Explorer
won't be updated (= change of board specific include paths). This is bad
since many things seem to rely on this e.g. automatic opening of include
files from the file outline. Is there a way to update the project->Includes?
Ciao,
Sebastian Huber
Re: Includes per configuration [message #209961 is a reply to message #209689] Mon, 18 February 2008 17:32 Go to previous messageGo to next message
Hi Sebastian,
The "Includes" that show up in the C/C++ Projects view are controlled by
the "Build configuration for indexer" setting under C/C++ General ->
Indexer.
After you modify your configuration via "Paths and symbols" (like you
did), make sure the desired configuration is selected under C/C++
General -> Indexer / "Build configuration for the indexer."
Let me know if this works for you.
Angel Roman
MDE Systems, Inc.
Sebastian Huber wrote:
> project->Includes?
> Ciao,
> Sebastian Huber
Re: Includes per configuration [message #210015 is a reply to message #209961] Tue, 19 February 2008 10:18 Go to previous message
Angel Roman wrote:
> Hi Sebastian,
> Indexer.
Oh, I haven't checked that tab. Thanks for this hint. I use now the
active build configuration for the indexer.
The paths in the project->Includes will be updated now if I clean and
build the project (or vice versa). A Index->Rebuild has no effect.
> Angel Roman
> MDE Systems, Inc.
>> project->Includes?
>> Ciao,
>> Sebastian Huber
Previous Topic:How to hook into CDT toolchain conversion/update process.
Next Topic:Project Template Engine + Restore defaults button.
Current Time: Sat Jul 26 17:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.03150 seconds
